Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Typhoon 2000 (TEMPEST) modifications thread >
Old 01-24-2005 | 01:17 AM
  #226
rodney tanner's Avatar
Default RE: Typhoon 2000 (TEMPEST) modifications thread
Mike: You will have them, never fear!! But I will be taking my time getting the Mintor 170 run in.
Old 01-24-2005 | 02:20 AM
  #227
ata
Hi,
I'm ready with planking the fuselage bottom side. I made wing and stab adjusters, and hyde mount and special engine mounting are in progress.
ID:	219869   Click image for larger version
Old 01-26-2005 | 09:24 PM
  #228
Nice work ata !
What type of the landing gear you are using?
Mike
Old 01-26-2005 | 09:39 PM
  #229
MTK
Mike if the model pitches to canopy in the vertical up line (power on), you can "fix" it with another degree or 2 of down thrust. If it pitches to gear on same vert line, reduce the down thrust. Don't be affraid to add upthrust if you have to.
Poweroff downlines are "fixed" with wing incidence. Thrust adjustmenst will not affect the knife edge hardly at all, but wing incidence changes will. If the plane pulls on the downline, increase the incidence and re-trim elevator or whole stab if adjustable. Vice versa for pushing on downline. Also to assist pulls on downlines, aft cg helps.
Matt
ORIGINAL: MHester
That's cool you guys are building a T2k and a Tempest. It'll be interesting to see how much different they are, and how alike they are in other areas. I'm really looking forward to some feedback. I know the Tempest isn't perfect, no plane is. But it's definitely competetive and agile. That fuse simply limits a few things. When you fix one thing, something else suffers a little.
I can say this about the Tempest, after darn near 1000 flights. When it's on, it's awesome. If you're off with it in just the right wind conditions, you'll have your hands full. But them most planes are like that. They have some things they do well and some not quite so good.
The snapping capability of this plane is awesome. It snaps and spins better than any plane I have ever flown, very precision and contollable. It's very stable inverted. It's very sensitive to rudder input, and all of the control throws are tamed on regular box flying, only cranked up for snaps and spins. It lands very easy for a pattern plane. It tracks well in 90% of wind conditions, and the other 10% you simply have to lead the rudder a little more than with other planes.
Which leads me to things I don't like, and couldn't really change with it. It's taken me a LOT of flying to find any real weaknesses, but here they are, in my opinion.
In certain wind conditions, especially turbulent crosswinds, it's a lot of work to keep the wings level. I believe this to be an effect of the radical taper. This is the trade off for doing other things so well. Stay on top of it and it's not an issue.
What little mix it needs is strange. While it pitches a bit noticably in up lines and somewhat on flat lines, it doesn't pitch much at all in knife edge. We're only talking 3-4% here, but it's noticable and if you want PERFECT, you'll need to get a little creative. The truth is it's very easy to just fly and ignore, it doesn't pitch nearly as hard as practically anything else I've ever flown. Again I think it's a trade off for the radical taper.
Since snaps and spins are such high K manuevers, and especially at advanced and above, I prefer the snapping capabilities and the smal touch of odd habit the taper displays. I took a little of it out on my new plane because I think it's on the very edge. Some people it may drive crazy, I guess. So far everyone that has flown it has loved it and marveled at how easy it does a lot of things. It's definitely a better plane than the T2K for the upper classes, no doubt. In sportsman, I'd prefer the T2K. Maybe intermediate too. But advanced and above, definitely the Tempest if I had to choose between the 2. Just fly advanced or masters in a high wind with both, then you tell me [8D]
I still love it, and won't get rid of mine. It's been the best plane I've ever had, hands down.
-Mike
Old 01-26-2005 | 10:19 PM
  #230
MHester's Avatar
Hey Matt, the up lines are perfect, the down lines pull to the canopy VERY slightly, like about 1-2% mix to idle gets rid of it totally. That's my typo and I see it now, I said up instead of down lemme fix it...
I did play with the incidence on this plane, I went as high as +1 full deg and low to about -1/4 deg. It likes about 1/10 of a degree to clean up any pitching and still break into a spin nice. When I had it down at 0 or lower, the plane would just hover. I would have to dial the throttle way way back, and it's idling at about 1500 right now.
But at 1/10 deg and higher, it breaks sweet. But any higher than +1/4 and it starts pitching both in down lines and in knife edge. So, after much play, I settled right about back where I started, 1/10 of a degree positive. Everything just seemed to balance there.
-Mike
Old 01-26-2005 | 11:16 PM
  #231
MTK
when you go to +1/4 degree WI which ways does it pitch in knife edge? to canopy or belly?
ORIGINAL: MHester
-Mike
Old 01-26-2005 | 11:42 PM
  #232
MHester's Avatar
canopy, but JUST barely. The more incidence I feed in, the more it pitches. If I stay at +1/10, the 4% rudder to elevator mix works both in level and knife edge, and verticals are fairly pure as well. If I go to a full degree, it pitches HARD...but spin breaks are on the dime Although at this incidence the thrust changes pitch pretty noticably as well. +1/4 deg is good all around with barely slight tendancies, but at +1/10 it seems to be a good balance between everything.
Whatcha thinkin? I'm all eyes.
-Mike
Old 01-27-2005 | 02:49 AM
  #233
ata
Hi Mike,
ORIGINAL: HuaChu
Nice work ata !
Mike
this is my home-made landing gear!
Attila
Old 01-27-2005 | 01:00 PM
  #234
MTK
That's what i wanted to hear. This is extremely close to neutral. On the next one, lower the tail about 1/4"-3/8" and use the 1/4 deg positive in the wing. It will eliminate canopy pitch in knife (or belly pitch for that matter) and will help spin entry. Keep engine offsets unchanged. This is nitpicking but would be worth the experiment. Any roll coupling?
ORIGINAL: MHester
-Mike
Old 01-27-2005 | 09:56 PM
  #235
MHester's Avatar
Extremely slight proverse coupling. So minor you can fly it pole-to-pole knife edge with rudder only, and the wing only rolls about 10 degrees or so. 1% mix is too much, so I left it alone. Basically, I guess the answer is no, it doesn't roll couple in knife edge.
Except inverted, it DOES roll couple slightly proverse when a lot of rudder is used inverted, like coming out of the bottom of a 2 of 4 triangle in a strong crosswind. None that I am aware of upright. I checked this afternoon. I wonder what would make it roll couple inverted, but nowhere else? Even in the top of a stall turn, with full rudder deflection, it rotates fairly flat. Could it be the sweep of the leading edge, or somthing more insidious?
Oddly enough, I find it needs less mix the more I fly it. As of today, I have 4% mix on the rudder to elevator and that's ALL, I increased it from 3 and removed everything else. I'm really not sure if it's just me subconsciously correcting or what. Like today, it was dead perfect in every attitude, except for the forementioned roll couple inverted. I'm beginning to think power setting and a 17.5" prop are playing a huge part. I'm flying a tad faster in the wind. Not screaming, but not as slow as usual. More constant I'd say. I think that's a good thing.
-Mike
Old 01-27-2005 | 10:25 PM
  #236
Attila ,
Nice work !
Mike
Old 01-28-2005 | 02:19 AM
  #237
ata
My engine mount is ready, special thaks to Ola Fremming for the idea!
Old 01-28-2005 | 06:18 AM
  #238
Hi all,
Just trowing my spoon into soup as well... Ata, why not shave a couple of grams from your hyde mount:
Picture tells more that my limited english can tell:
edit: here is my "hyde" for 160FX and similar version bolted on Syn 90 ARC (I´ll try this without nose-ring, rubber is same on both)
ID:	221638   Click image for larger version
ID:	221639   Click image for larger version
Old 01-28-2005 | 10:00 AM
  #239
ata
Hello Jatik,
my engine has rear intake and a Walbro carb, so I had to make such a big metal frame. But there is a good thing what I liked, the engine will be well mountable, you can see 3 bolts in easily reachable position. The hyde mount is lightened out (plywood), I think the whole assembly has up to 10-15 gramms overweight only.
Old 02-01-2005 | 08:48 AM
  #240
Jó estét kivánok,
Yes if your Aluminium part is 50 gr. then hyde part must be around 68 gr.
Petrol engine ... are you putting in ZDZ40RE or MVVS ?
Szia!
Old 02-01-2005 | 10:06 AM
  #241
ata
Päivää!
Anteeksi, ***** minä en puhu suomea.
Jatik, you speak hungarian better than me english... You are right the Al part is 50g, did you measure it ? I will put an AW moki into my plane, its not petrol but glow engine.
Näkemiin!
Old 02-03-2005 | 09:54 AM
  #242
HI Ata,
Just Curious.... Your AW, is it like this one:
http://www.airworld.online.de/Deutsc...i_20/index.htm
or this :
http://www.airworld.online.de/Deutsc...0_HD/index.htm
looks like one strong motor... These are Benzin ones, is there also rear exhaust methanol available?
Regards: Jari
Old 02-03-2005 | 12:30 PM
  #243
Any aluminum landing gear fits tempest ?
Thanks in advance
Mike
Old 02-04-2005 | 02:15 AM
  #244
ata
Hi Jatik,
My engine is like the first, but methanol version. Rear intake rear exhaust, ~750g, with different Walbro carb.
I glued the tube sockets into the fuse and mounted the homemade wing adjusters. The vertical stab glued on too, and I started planking fuselage upper rear section.
ID:	224729   Click image for larger version
Old 02-07-2005 | 03:07 AM
  #245
ata
Hi,
I finished setting up the adjusters. The fuse rear is planked, it needs a lot of sanding. Before I apply the second sheeting of wing I should make the wing retainer hooks. Could somebody give me any idea how should I make them?
Attila
ID:	225954   Click image for larger version
Old 02-07-2005 | 09:42 AM
  #246
MTK
Ata, surprised to see all the planking in the tail?! It's MUCH easier to take a whole sheet, wet it, and mold it around the structure without glue. Secure it with masking tape, leave it overnight to dry, then glue it the next day. MUCH nicer result with minimal sanding/filling.
You can actually do compound curves (engine cowlings and canopies) with this technique.
MattK
ORIGINAL: ata
Hi,
Attila
Old 02-07-2005 | 10:19 AM
  #247
ata
Hi MTK,
I have bad experiencies with your method, but maybe this was my failure. I feel the upper radius too sharp bending sheet around it, especially near to vertical stabilizer. But next time I will give it a try.
Attila
Old 02-07-2005 | 10:40 AM
  #248
MTK
Okay
MattK
ORIGINAL: ata
Hi MTK,
Attila
Old 02-07-2005 | 10:55 AM
  #249
MHester's Avatar
Atilla, what I do with this plane is make a solid sheet and wet it and mold it to the sides, tapered from 4" at the front to about 1.5" at the rear. Then plank over the top. It is a little lighter and requires less sanding, but you're already done [8D]
-Mike
Old 02-07-2005 | 11:59 AM
  #250
bokuda's Avatar
My Feedback: (7)
I used a combination of these methods on my T2K. I used the "wet sheet" method for the lower part of the turtle deck; I don't remember if I used 3" or 4" sheet. Then I planked the upper part because the sheet tended to split with the small radius there.
