Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Typhoon 2000 (TEMPEST) modifications thread >
Old 01-03-2005 | 05:42 AM
  #151
ata
Default RE: Typhoon 2000 (TEMPEST) modifications thread
Unfortunatelly these parts are different from the original Typhoon parts, they won't fit!
And here are the final products:
ID:	209971   Click image for larger version
ID:	209972   Click image for larger version
Old 01-03-2005 | 05:50 AM
  #152
ata
I build an all wood version with some material change. I use double tapered pine spars (for wing 5x10 mm -> 2x4 mm) and longerons (for fuse 5x5 -> 3x3). It adds only a little weight but a lot of strength. Here are all manual cut parts:
ID:	209974   Click image for larger version
ID:	209975   Click image for larger version
Old 01-03-2005 | 05:58 AM
  #153
ata
I built the wing structure and glued the sheeting on (one side). I'm using rubber bands to hold the sheeting in place. It works good if you put weight on flat surfaces (near TE). I'm using a wood template to support TE in correct position.
ID:	209977   Click image for larger version
ID:	209978   Click image for larger version
Old 01-03-2005 | 07:30 PM
  #154
ATA, your parts look great! Good job. How much would you charge me for a cowl assembly and canopy? I hate for you to go to the trouble of making molds only for one part!
Steve
Old 01-03-2005 | 08:49 PM
  #155
MHester's Avatar
Man, you guys do some sweet work! Makes me envious. Keep em coming!
-Mike
Old 01-03-2005 | 08:58 PM
  #156
My Feedback: (12)
I wish there was a short kit of the fuse parts like that left photo.
Old 01-03-2005 | 10:33 PM
  #157
Hi Everyone
I asked ata if he sold the pieces he made last night. Hes reply was he made a mistake when making the molds so they dont fit the typhoon/tempest as standard and he had to modify his plans instead. Im sure he will answer himself but that is the reply that I got
Troy
Old 01-04-2005 | 12:48 AM
  #158
Hey ata, very good looking parts....
GO, DO IT.....
Old 01-04-2005 | 05:10 AM
  #159
My Feedback: (7)
I´m designing my own 2M plane... Please could you inform me how much is the Typhoon wide. Mine will came out at about 4" at the widest point at the fuse.
Old 01-04-2005 | 06:12 AM
  #160
Hi
The typhoon is approx five and half inches at the widest point f2. Hope that answers your questions
Troy
Old 01-04-2005 | 04:46 PM
  #161
ata
Hi,
for everybody who would like composite parts: like Troy mentioned, this parts not compatible with original Typhoon parts (actually they not Typhoon parts) and they are prototypes. I don't know if they long lasting or are they too heavy or not so be patient. I have not planned to sell them, but maybe one day in the future ...
Other news: my wings are ready to accept wing adjusters and upside sheeting.
Old 01-06-2005 | 12:14 PM
  #162
sigk's Avatar
I am using an extended aileron facing, it gives a little more strength and distributes the stresses of the wing past the aileron cut out section.
It's also important when using a very thin sheeting like paper.
ID:	211376   Click image for larger version
Old 01-06-2005 | 12:17 PM
  #163
sigk's Avatar
The fin/rudder and stab has been sheeted with 135gr m2 paper and I like the result. It certainly is strong enough, just need to be careful with the razor plane when working on the leading and trailing edges not to accidentally cut into the thin sheeting.
ID:	211378   Click image for larger version
ID:	211379   Click image for larger version
Old 01-06-2005 | 12:19 PM
  #164
sigk's Avatar
For the sockets I used the same paper. Six layers seems to be the right thickness.
ID:	211383   Click image for larger version
ID:	211384   Click image for larger version
ID:	211385   Click image for larger version
Old 01-06-2005 | 12:21 PM
  #165
sigk's Avatar
Sockets
ID:	211387   Click image for larger version
ID:	211388   Click image for larger version
Old 01-06-2005 | 09:01 PM
  #166
Hey sigk, what a great kind of materials you use....
Can it be painted over paper or need be glassed?
I mind when sheeted over control surfaces
Old 01-07-2005 | 03:13 PM
  #167
sigk's Avatar
Roberto,
No you don't have to glass it before painting. Just needs a little sanding and that's the beauty of it, it takes very little work to prepare it for covering and/or painting.
Old 01-07-2005 | 07:09 PM
  #168
Is this paper sheeted more stiff and resistant than balsa and glass?
Looks like a good armour....
I'll use this next project for wing and stab, must be cheap...
Old 01-08-2005 | 10:37 AM
  #169
sigk's Avatar
No Roberto, it's not as stiff as balsa and glass but it's much lighter. What I especially like is to use paper and a thin glass cloth together. Usually I have used obechi veneer or koto for sheeting foam wings but the paper is only 1/3 of the weight.
My only concern is because the paper is so thin, there is a danger of the trailing edge warping. But thin strip of glass cloth and a little wider balsa trailing edge might take care of that, I hope.
Yes you are right it is cheap, one 50 meter roll of paper cost me the same as 3 sheets of 1,5 balsa. 50 meters of paper is enough for 12 sets of wings so it's almost a joke. A 2 meter wing costs me no more than a new fuel tank so it is affordable if I want to try many different wings. Sure it is the most cost effective and the quickest way to build wings. I'm using Bob Smith Industries Finish-Cure epoxy and that gives me a very nice semi hard finish.
Old 01-10-2005 | 02:21 AM
  #170
ata
Hi,
the elevator halves almost ready for the second sheeting. But after making the servo places I'm sure I don't know should I use one servo with pushrods or two servos in the elevator... Maybe I will decide later.
Old 01-10-2005 | 11:37 AM
  #171
MHester's Avatar
Atilla, the plane is designed to have 2 servos in the tail. If you use one servo with a pushrod, you may have to add some tail weight. To my thinking, that's just more dead weight. But it's been done both ways.
Just oen note: DO NOT use an MK bellcrank on this plane. For some reason, the failure rate is extremely high with this airplane. I know of far too many cases first hand.
Hope that helps,
-Mike
Old 01-13-2005 | 02:47 AM
  #172
ata
Hi Mike,
I thinked about putting both rudder and elevator servos back to the tail. In this way the weight doesn't missing. I won't use MK bellcrank, I would choose something low cost, homemade solution. I think that a stiff T pushrod is a good solution (I saw one on Bob Pastorello's web site, but I can't find anymore). But right now I prefer the original 2 servos in the stab version again (this plane will be my prototype, so I shouldn't change a lot of thing).
How do you mount the "Hyde mount" to the firewall? How do you adjust it sideway?
The fin are almost ready to glue on LE:
ID:	214480   Click image for larger version
Old 01-13-2005 | 10:37 AM
  #173
My Feedback: (10)
Is there any word on the Gator Cowl?
Old 01-13-2005 | 11:54 AM
  #174
rodney tanner's Avatar
My local guy can do a fg set of TK2 Conopy, Chin Cowl, and cheeks for just under $US 80. They are well made and lighter than the Gator origionals.
Two Gator Canopies have just shown up from Radio South. I no longer need them so will sell them at the same cost plus shipping to anybody who wants one.
I also have a full cowl we can pull copies from if needed. Don´t have a cost but would come out under the Gator price.
Old 01-13-2005 | 07:34 PM
  #175
bokuda's Avatar
My Feedback: (7)
Rodney: I and at least one other person I know would be interested in a full cowl.
