RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
the hyper st PRO thread!
Old 06-12-2008 | 05:22 AM
  #1226
Default RE: the hyper st PRO thread!
HI. first of all my name is justin and i am purchasing a hyper st pro with a jammin jpx 28 is there any mods to do to this truggy and is there any weak points thanks
Old 06-12-2008 | 07:28 AM
  #1227
spikeitaudi's Avatar
No must do's. But you can change out the battery/radio box mod, change out fuel tanks, the stock fuel tank posts are a bit weak.
Old 06-12-2008 | 08:17 AM
  #1228
I think the Fibre brake disc's are a must, especially if you are going to race
[8D]
Old 06-12-2008 | 08:21 AM
  #1229
ORIGINAL: cycleops1966
[8D]
I am running stock on mine and doing fine with racing. But your right this is also another good mods. But not a MUST.
Old 06-12-2008 | 08:34 AM
  #1230
supertib's Avatar
Hy Hyper just got a new heart !!!
http://www.neobuggy.net/images/News/nopl28-7t.jpg
Old 06-12-2008 | 01:45 PM
  #1231
Anyone having problems with the diffs leaking? I've had nothing but bad luck with the rear diff. I've tried filling it up to a certain point where the gears are barely covered. I have checked the o-rings and diff cup seal and I still get the same results. My front or center do not leak but the rear does. I'm currently running 7k/10k/3k. Is there any other way to seal the diffs? I have lubricated the seals as well and have sealed the grub screw.
Old 06-12-2008 | 02:38 PM
  #1232
liu's Avatar
liu
If never had my front or rear diffs leaking. The only diff that leaked on my hst was the center diff. But that was just because i didnt tighten it good..
Where does it leak at the diff? screwholes?
Old 06-12-2008 | 03:30 PM
  #1233
ORIGINAL: liu
I can see it leaking at the crown gear. Nothing is broken. It almost seems like the seal is not sealing the diff cup and crown gear. That is why I ordered a whole new diff.[&o]
Old 06-12-2008 | 03:45 PM
  #1234
ORIGINAL: darksoul242001
Yup. I used the Kyosho Diff Gasket and relubed and haven't had an issue since. The rubber o-ring between the crown gear and diff case is useless.
Old 06-12-2008 | 03:53 PM
  #1235
ORIGINAL: spikeitaudi
Finally got around to taking out my front and rear diffs due to them leaking. And boy did they leak. Both Empty. That red rubber band that seals the front and rear diff to the main gear is a joke. When taking it apart I compared it to my brother-in-laws Kyosho Inferno Buggy and guess what. The Front and rear diffs are identical down to every part. The thing about the Kyosho Inferno buggy diff is it also has a gasket inbetween the diff cup and the main gear. So I order it and it was a perfect fit. Cleaned out the diffs relubed put them back together plus the new gasket. So for anybody looking to fix the leak with the front and rear diffs here is the part I used.
[link=http://www.amainhobbies.com/product_info.php/products_id/4144]http://www.amainhobbies.com/product_info.php/products_id/4144[/link]
While we were at it my brother-in-law also fabricated some new gas tank posts as the stock ones just don't cut it. We made them alittle thicker and used small rubber orings to dampen the tank from vibration. Works like a charm.
Here are some pics of the new mounts.
After all the new mods went out for a test run and the mounts and new gaskets worked like a charm. Kudos to Jerzferno for making the new mounts.
Here was my orginal post Dark. It has the link to the gasket.
Old 06-12-2008 | 07:03 PM
  #1236
Hey thanks for the information I knew I had read about it before somewhere around here. I did order those gaskets. I had even tried the mugen ones because my LHS recommended them but they dont seem to seal right either. Are you still using the diff cup rubber ring or did you take that out and simply use the kyosho gaskets?
Old 06-12-2008 | 07:34 PM
  #1237
I am using the rubber ring and the gasket together. No shimming. Just added the gasket and it's tight as can be with no leaks. I was leaking like crazy without the gasket.
Old 06-13-2008 | 03:06 AM
  #1238
I had problems with leaky diffs too, like spikeit I used an extra gasket, but I used an XRay one (Scan back a few pages to find the part no). I also ended up putting PTFE tape on the screws - Since then not a drop has leaked.
Old 06-13-2008 | 03:18 AM
  #1239
can some1 please tell me where the best place to get a new piston and sleeve for the LRP spec 3 from?
cheers people
Old 06-13-2008 | 07:47 AM
  #1240
You might want to create a new thread and ask that question instead of the Hyper ST pro Thread. Might get more hits.
Old 06-13-2008 | 08:58 PM
  #1241
eirk66's Avatar
[sm=punching.gif] .
Old 06-14-2008 | 12:33 PM
  #1242
here is my mugen tank mod in progress just need to cut the carbon for the splash shield...
Old 06-15-2008 | 10:05 AM
  #1243
strutz52's Avatar
laynlow, dude that body is sweet[sm=thumbup.gif][sm=thumbup.gif]
Old 06-15-2008 | 10:20 AM
  #1244
thanks man i painted the body for my savage to match as well ..
And here is my other body for my hyper
Old 06-15-2008 | 10:36 AM
  #1245
strutz52's Avatar
that chrome/green one is cool to, but i really like the one with orange, it just adds an extra, BOOM to it! who painted it?
Old 06-15-2008 | 09:27 PM
  #1246
j_blaze's Avatar
i found some super cheep hyper st pro parts on ebay, seems like a chop house. i've been buying from him since he had hyper 7 parts, then hyper 8.5 parts and now hyper st parts. i found a whole diff for $14, crown gear and all! the body was like $27 too, not bad. fast ship too, got to fl in 3 days. here's the link, plcman1 is the seller.
http://search.ebay.com/search/search...e=search&fgtp=
Old 06-15-2008 | 09:32 PM
  #1247
14 bucks for the front or rear diff is about the going rate on Ebay. If you can get the Center for that much that is a different story.
On a different note, raced the Hyper today with new 2060sc pipe and header on my OS 21 V-Spec and was running ok in the qualifier, but in the Mains it ran real lean all the sudden. Not sure if I got bite by the Hyper fuel tank bug. But I might be doing the Mugen tank convertion.
Old 06-15-2008 | 11:13 PM
  #1248
i painted it myself.... the chrome was my first try at painting.. hopefully the modded vspec is ready soon!
Old 06-15-2008 | 11:31 PM
  #1249
Check that gas tank for sure at the lid and see if it is leaking. The small screw inside the lid tends to strip really easy. I simply installed a bigger screw with a washer and haven't had any issues. I remember that I was having issues with fuel leaking out of it when I would pick up the truck. And after trying to run qualifiers at the local track this weekend I simply gave up.[&o] I was wondering what the issue was. This time it was not the gas tank but a pinhole size leak in the fuel lines. So check those fuel lines and fuel filter. Make sure that the fuel line isn't getting pinched under the tank too. I've seen it happen before. I'm also on my way to installing that mugen tank anyways. It seems a lot stronger and can definitely make your ride have a better tune. So how did you like the engine and pipe combo? Was it crazy fast?? Thanks for the tip on the diff gaskets. No more leakage!!!
Old 06-16-2008 | 09:33 AM
  #1250
I ran the OS V-spec before on it before in the last race and took 5th in the AMain. And that was with the Stock Hyper .28 pipe that comes with the kit. As I was going through plugs to quickly I changed out to the 2060sc pipe which was ony 70 bucks with the pipe and header combo. It was a steal I couldn't pass up so put it on and retuned. It was fine in the qualifer, but then in the Main it was just so lean. And I didn't touch a thing and conditions didn't really change so I am thinking it might of been the tank. I am going to change out the fuel lines anyway thou. That is cheap and quick. But I will have my LHS but in the order for the Mugen tank also. Still finished 5th in the AMain
