Reload this Page >
CARF F4U-1 Corsair build thread
Old 05-05-2015, 07:21 PM
  #3026
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Time to get a couple sliders done. I'll go through the process again via pictures.
i locate the canopy on the fuselage and outline it.
Old 05-05-2015, 07:26 PM
  #3027
ram3500-RCU
My Feedback: (221)
You can see that the embossed lines of the rear rail locates it slightly low. I raise it up as shown. after it is cut in I use tri-stock to glue it in place, The ends are then taped and epoxy is spread over the inside.
ID:	2094223   Click image for larger version
ID:	2094224   Click image for larger version
Old 05-05-2015, 07:35 PM
  #3028
ram3500-RCU
My Feedback: (221)
For the front rails, I glue wood wedges to the inside of the sides as shown (the full scale has these as well). These wedges kept the rails parallel as the full scale canopy can't flex as our model canopies can I use the straight edge to keep them perpendicular to the opening, so the rails are not leaning in. Careful alignment at this stage makes for a true running rail system.
Old 05-05-2015, 07:42 PM
  #3029
ram3500-RCU
My Feedback: (221)
After tacked in place with CA, I use epoxy as with the rear rails, again taping the ends to keep them open.
ID:	2094227   Click image for larger version
Old 05-06-2015, 09:02 PM
  #3030
ram3500-RCU
My Feedback: (221)
Rails installed. Next comes the canopy. The drive rails go forward through the instrument panel, so once the canopy is mounted, that will need to be installed as well. I'll be using my aluminum panel.
ID:	2094426   Click image for larger version
Old 05-08-2015, 08:43 PM
  #3031
ram3500-RCU
My Feedback: (221)
With the rails installed the clear is fit to the canopy frame. A lip around the front of the moving section that interlocks into the front fixed section is useful. I use the clear plastic to make this lip by cutting it 3/32 long for the rear section. You can see the lip and how it guides the slider into place in these pictures.
ID:	2094743   Click image for larger version
Old 05-08-2015, 08:44 PM
  #3032
ram3500-RCU
My Feedback: (221)
First I mark on the inside where the frame will be cut apart. Then I tape the clear in place. Next I use tape to mark where that separation will be on the clear. Now I can cut the clear 3/32 in front of the tape, creating the lip when clued in place.
ID:	2094745   Click image for larger version
ID:	2094746   Click image for larger version
Old 05-08-2015, 09:02 PM
  #3033
ram3500-RCU
My Feedback: (221)
With the clear ready to be installed, I get the frame ready. I use (22) stainless steel bolts to secure the clear to the frame in addition to RC 56. The location is marked on this frame in black. They are Phillip flat head and the same size as the ones embossed in the frame. I'll use a counter sink on the spots I want to use. This is easier BEFORE you cut the frame apart.
ID:	2094748   Click image for larger version
Old 05-08-2015, 09:14 PM
  #3034
ram3500-RCU
My Feedback: (221)
For reinforcement, I install an aluminum doubler inside the sliding portion. This also has the mounting points connected to it in both the front and rear. Because through bolts like the ones attaching the frame to the clear would scrape on the fuselage, I drill and tap these 1/8" 2-56 bolts into the aluminum and make sure they are flush on the inside. The locations are noted here in blue. There will be one more in the rear that will also be the rear mount, and (2) more in the front that WILL be through bolts holding the front mounts.
I tape the inside of the clear during this process because when you grind the bolts flush to the aluminum, the tiny hot metal debris will pit the soft clear plastic if left exposed.
ID:	2094750   Click image for larger version
ID:	2094751   Click image for larger version
ID:	2094752   Click image for larger version
Old 05-08-2015, 09:17 PM
  #3035
ram3500-RCU
My Feedback: (221)
Some minor trimming may be needed to the aluminum doubler if you have a slider kit.
Note. This canopy system has been flown in the open position, as with scale take - offs and landings, with no harm to the canopy. It is very strong, and you WILL NOT lose it.
ID:	2094754   Click image for larger version
Old 05-10-2015, 04:54 PM
  #3036
woody242
Hey Gary,
Got the glass cutout of the wheel well for the gear install with the gear mounted as far forward per your recommendation. Looks to fit nicely if I adjust the axle so that it is not flush with the gear leg. About 1/4" sticks out which I expect I will cut off. Do you know what bag contains the gear mounting hardware? I don't really see hardware that matches, looks like I should be providing my own as all of the bags seem to be labeled for other uses. Do you have recommendations for screw lengths, looks like countersinking the forward inner screw would provide the best clearance for the permanent covers. Do you see any issues with this?
John
Old 05-10-2015, 06:30 PM
  #3037
ram3500-RCU
My Feedback: (221)
Originally Posted by woody242
Hey Gary,
John
Hello John.
They do NOT give you those screws (probably because the gear is not part of the kit). We add additional wood under the mounting rails and use #8 X 1" wood screws. You can use hex head hardened wood screws for extra strength. With most warbirds we use machine screws and T-nuts, but in the case of the CARF Corsair, the #8 screws are plenty strong and will not come loose, and are much easier to install with the proper pilot hole. With the #8 you may need to drill the gear holes just slightly, but we still prefer them to a smaller #6 that wood be slightly smaller than the holes.
If you are building a newer kit, the extra wood under the mounting rails is probably already installed.
Old 05-10-2015, 06:47 PM
  #3038
ram3500-RCU
My Feedback: (221)
Here are some pictures. No countersinking is necessary or recommended. Brian uses stainless steel pan heads, or button heads. I think the strongest would be hardened hex heads, but we have never broken any of the a fore mentioned screws.
ID:	2095277   Click image for larger version
ID:	2095278   Click image for larger version
ID:	2095279   Click image for larger version
ID:	2095281   Click image for larger version
Old 05-11-2015, 04:07 AM
  #3039
woody242
Old 05-11-2015, 06:02 PM
  #3040
ram3500-RCU
My Feedback: (221)
Always our pleasure John.
Old 05-13-2015, 08:27 PM
  #3041
ram3500-RCU
My Feedback: (221)
I'm always looking for better ways to do things. To that end, I am trying something different on the canopy I am doing. This time, before cutting the frame apart I drilled and counter sunk all the screw locations, then I painted the inside with flat black. I then Glued the front fixed part in the canopy with RC 56. Next I taped the slider section of clear in place. Now I finished drilling through the clear and installed all the 2-56 stainless bolts and nuts.
ID:	2095762   Click image for larger version
ID:	2095765   Click image for larger version
Old 05-13-2015, 08:32 PM
  #3042
ram3500-RCU
My Feedback: (221)
Now I installed the aluminum doubler. This is drilled and tapped because nuts would rub on the fuselage. I use (7) 2-56 X 1/8 stainless steel bolts on each side.
My plan is to mount the canopy as one piece this time, before cutting it apart. This should make alinement perfect and easy.
ID:	2095763   Click image for larger version
Old 05-13-2015, 08:46 PM
  #3043
ram3500-RCU
My Feedback: (221)
For those waiting on the inner gear door detail panels, the molds are in the final stages of being tweaked. Production should begin very shortly. I'll use these two currant builds to make sure all is well with the finished product and then we will make them available. I plan an initial discount to anyone who has already ordered parts from us in the past as thanks for your support.
The hinge covers are already in production.
Old 05-16-2015, 09:54 AM
  #3044
DrScoles
My Feedback: (18)
DrScoles's Avatar
awesome!
Old 05-18-2015, 07:03 AM
  #3045
Craig B.
Hi Gary,
What parts do you currently have available for the corsair?
Old 05-23-2015, 02:09 PM
  #3046
ram3500-RCU
My Feedback: (221)
Originally Posted by Craig B.
Hi Gary,
Here is the current list of options.
1. scale lighting system with all nav and formation lights with all custom lenses and LED lights with support supplies
2. complete gun system with lights and sound including the gun port fairings and simulated barrels
3. operational cowl flap system
4. scale wing intakes ready to install
5. canopy sliding kit with hardware to mount the clear to the frame
6. electric canopy drive system designed to work with our slider
7. top hatch kit including the parts to create the switch compartment
8. bottom hatch kit including the swing down panel for easy service of the wing systems
9. scale aluminum instrument panel with aluminum bezels and all dials
10. custom Moki engine standoffs set to create the proper thrust angles
11. main gear strut cover leather gap cover kit
12. scale stainless steel functional exhaust system with shrouds made for the Moki
13. wing gun port fairings (included with the gun system)
Things soon to be available include the gear door inner detail, wing hinges covers, resin break discs, and maybe a resin tail hook. Both my brother and I do this as a sideline to regular jobs, so time is really what limits our ability to do more. Maybe someday I will be able to retire to my hobby. :-)
Old 05-23-2015, 05:05 PM
  #3047
ram3500-RCU
My Feedback: (221)
More canopy work. OK, time to put the canopy back in place temporarily. Before I do, I mark where the rails are so I can locate where to drill for the rear bolts.
Old 05-23-2015, 05:10 PM
  #3048
ram3500-RCU
My Feedback: (221)
I tape the canopy back in place and drill for those rear bolts. Then I countersink and install those bolts with the modified nuts that travel in the rails.
You can also see the hole that needs to be opened up just behind the rails so that nut can be inserted in the rails.
ID:	2098097   Click image for larger version
ID:	2098098   Click image for larger version
Old 05-23-2015, 05:13 PM
  #3049
ram3500-RCU
My Feedback: (221)
With the rear of the canopy mounted, I taped it back in place and screwed the fixed section down to make it easy to relocate it after the parts are cut apart.
Old 05-23-2015, 05:17 PM
  #3050
ram3500-RCU
My Feedback: (221)
Now you can locate the front mounts on the slider. Once the hole is located for the shaft of the ball linc, I CA it to the canopy to hold it where it needs to be for drilling and tapping the 2-56 mounting bolts.
