Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 05-27-2015, 07:07 AM
  #3851
Hot Rod Todd
Hot Rod Todd's Avatar
Ordered it direct from the company at http://www.pneumadyne.com/. You'll also have to find two 10-32 to 1/16 barb fittings.
Old 06-13-2015, 10:16 PM
  #3852
vertical grimmace
vertical grimmace's Avatar
Could someone tell me what the weight is of the 2 bladed spinner that comes with this plane? The weight spec is no where to be found on the tower or Top flite sites.
Old 06-14-2015, 06:14 AM
  #3853
ForcesR
VG, the spinner including back plate weighs 10.10oz or (286g).
Roger
Old 06-14-2015, 07:49 AM
  #3854
vertical grimmace
Roger
Thanks so much.
Old 06-14-2015, 09:44 AM
  #3855
JSZ
My Feedback: (73)
JSZ's Avatar
Default Tf fw
Just recently completed and ready for maiden
Old 06-14-2015, 11:09 AM
  #3856
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
awesome, JSZ!!!
Old 06-14-2015, 11:45 AM
  #3857
Lifer
Lifer's Avatar
JSZ,
I don't know that much about the history of the FW-190, but is that Winter camo for the Russian Front?
Old 06-14-2015, 11:53 AM
  #3858
vertical grimmace
Yes. It was usually a white wash, overpainted in the field. should look nasty to be scale
Old 06-20-2015, 12:56 PM
  #3859
zadeda
Hi, everybody! Here also came true! I made the third flight! The first didn't manage to be photographed two on video. That I want to tell, the plane tremendous! I meanwhile fly highly, I am afraid below, for a motor cause of failure. The plane is quite obedient and predictable. Thanks to all who took part in discussion at a forum!
http://www.youtube.com/watch?t=178&v=rmx2lTENk_o
Old 06-20-2015, 01:36 PM
  #3860
zadeda
Некоторые фото
ID:	2104732   Click image for larger version
ID:	2104733   Click image for larger version
Old 06-21-2015, 05:51 AM
  #3861
sparky4lawndart
My Feedback: (10)
великолепные , поздравления
Originally Posted by zadeda
Некоторые фото
Old 06-21-2015, 07:10 AM
  #3862
Mpizpilot
My Feedback: (45)
I am so unbelievably sick of these robart retracts. They sent me the replacement trunion with supposedly harder pins and on my one landing yesterday they bent still. The plane made a perfect landing and made a slight turn on rollout and the gear bent......again.
Old 06-21-2015, 09:42 AM
  #3863
kwik
kwik's Avatar
What dia is that pin ? 1/4 inch perhaps? In that case; Why not take a long 1/4 inch bolt and cut it. Use the non-threaded part as a pin.
Then it will be the last thing that is bendt on that plane, forever.
Use a dremel for cutting...
Old 06-21-2015, 11:52 AM
  #3864
kwik
kwik's Avatar
I finally glassed the wings today. Been flying in bare wood underside for a long time now.
But now its done. Monokote; The invention of the Devil himself.
Old 06-21-2015, 04:33 PM
  #3865
Mpizpilot
My Feedback: (45)
Некоторые фото
what retracts are you using? I love my 190 also. On my 2nd summer with it, but I'm over these robart units.
Old 06-21-2015, 05:00 PM
  #3866
Mpizpilot
My Feedback: (45)
Robarts "upgrade"
Old 06-22-2015, 12:23 AM
  #3867
zadeda
Sparky, thanks for congratulations! Mpizpilot, I used the main ESM electric retrakta. There the same didn't do without problems. On the first landing, after a sharp turn one of drive axes broke. As in the retraktakt the inch carving is used, I had to make both details of an axis and a shaft, anew, with a metric carving. The main problem in axis thickness, it is equal 6 mm, after drilling of an opening, there are very thin walls of a detail and it breaks after side loading. You can look in pictures, the axis is allocated in red color. I made a detail with a diameter of 7 mm., I hope that it will well work. I ask to excuse for my English if something isn't clear, ask again!
ID:	2104964   Click image for larger version
ID:	2104965   Click image for larger version
ID:	2104966   Click image for larger version
ID:	2104967   Click image for larger version
ID:	2104968   Click image for larger version
ID:	2104969   Click image for larger version
Name:	2015-06-09 12-27-53.JPG
ID:	2104970   Click image for larger version
ID:	2104972   Click image for larger version
Name:	2015-05-28 18-31-52.JPG
Old 06-22-2015, 04:51 AM
  #3868
ENZ5573
My Feedback: (7)
Hi All,
I have not had a problem with my Gear yet! but, i will be making harden pins.I am a Machinist and i can make them in my shop.If someone can send me a pin or dimension of the pin i can start to make them for me and all that are having a problem!
Thanks,Vincent
Old 06-22-2015, 04:54 AM
  #3869
dasintex
My Feedback: (10)
dasintex's Avatar
How difficulty is it to remove the pins to replace with harder pins, if the need arises?
Old 06-24-2015, 06:35 AM
  #3870
Mpizpilot
My Feedback: (45)
They're welded in, so I guess you'd have to grind and drill them out.
Old 06-24-2015, 06:55 AM
  #3871
slembones
Very frustrating. I am sure you've done this but if not, check your wheels to make sure they are toed out. I too had this problem and after toeing out the wheels about 2 to 5 degrees the the pin bending stopped. I land on concrete runway. had my fw190 since 2012. I also have williams bros wheels.
Old 06-24-2015, 10:24 AM
  #3872
SWORDSN
My Feedback: (13)
The weld is on the back side,if you grind the spot weld off.you can knock out the pin.My friend has done this more than once
Old 06-24-2015, 10:30 AM
  #3873
Tony Gag Jr.
My Feedback: (124)
Tony Gag Jr.'s Avatar
I wish somebody else offered a drop in gear for this plane. I have one all ready to go but I don't want to waste my money on the Robarts.
Old 06-24-2015, 12:13 PM
  #3874
erwin peters
Hello friends, I end up using 3 pound weight, with a DEL61cc using electric Robarts. Is that sounds right to you??
What about the factory CG, it’s OK for flight or maybea nose heavy for start testing??
For the Robart electric mains retracts, the strutsneed to be file flat where the two clamping bolts in the retract adjust them?? Inorder to prevent the strut stars rotating??
Best regards
Erwin
Old 06-24-2015, 12:58 PM
  #3875
slembones
I did not file the struts and have had no rotation issues. The cg is correct. These planes need about 2500 g total to set up correctly. They are more nose heavy wheels down that with wheels up.
happy landings!
