Byron Corsair Build
#828
My Feedback: (164)
CA
RE: Byron Corsair Build
Hi Scott:
Thank you, I know , she needs it, I wish I could, but I am not that good at dusting, Looking at a friend help with it, looks to new
Dave
Dave
ORIGINAL: Fly2XS
Looks Nice Dave!
I love the fabric detail on the elevators. Are you going to weather it, or give it a light wash to highlight those great panel lines?
Scott
Looks Nice Dave!
Scott
#829
My Feedback: (61)
ORIGINAL: AMA234
Craig,
Not sure if you have gotten to it yet or not, but I wanted to let you know of an issue I had with using the Dubro hinges for the tail wheel doors. I tried your same method, glueing the hinges to the inside of the fuse and the doors and the edge of the doors would hit the skin before opening even 1/2 inch. I even tried shimming the door side of the hinge with 3/32 inch ply but all that did was cause the door to stick out farther from the skin . What I ended up doing is ripping them off and I am thinking of using BVM offset door hinges. I will admit that rigging door hinges has not been my cup of tea, but I have found that the offset door hinges always work well for me. I guess if you were to use a continous strip of piano hinge as is on the full scale, the hinge line gap wouldn't be noticed as if you only use 3 Dubro hinges. Maybe you had better success with how you did it and can educate me on how to rig doors using the Dubro hinges?
Maybe I will opt for the piano hinge after all instead of the offset hinges... not sure...depends on what I can get the quickest. WhoDaMan?....... Need input.
Here are a few pics of the cover I made for the retracts.
Les
Craig,
Les
#830
My Feedback: (61)
ORIGINAL: AMA234
Craig,
Les
Craig,
Les
#831
My Feedback: (61)
ORIGINAL: Canuck1
Have been doing some fiddling around this weekend. I was looking at the cooling vents for the wing. They look ok, but I think I will scale them up, give it some relief to make it look more realistic. I glued the alum spar to the plywood insert. This will slide into the wing, and is epoxied in place. Just checking for fit right now. The starboard wing was not cut deep enough so I needed to remove 5/16th of an inch for a proper fit. A hacksaw blade made this an easy task. I hope tomorrow I will have a little time to do at least one wing, just need to make sure it is aligned well, so the sheeting will be flush with the fibreglassed part when it is attached.
Craig.
Craig.
#833
OK
I just picked up a built orig Byron Corsair for little bit of nothing, the old man whom I purcahsed it from was the orig owner and did a SUPERB job many many moons ago. He wasnt confident when it was built, but thought it was early 90's. Its powered with a Sach 4.2 on a Byron tube mount, but it does not have the "Purr-Pwr" setup either. To the guys that have/had the Sach's engine, are they reliable? Parts avail? Mine still has the orig CH mech advance ign setup...has anyone upgraded the Sach 4.2 to a auto-advance(current) CH ignition? Ill post pics tonight, but minus batts,prop its sitting at 22lbs...
#834
My Feedback: (65)
ORIGINAL: ColeTrane
I just picked up a built orig Byron Corsair for little bit of nothing, the old man whom I purcahsed it from was the orig owner and did a SUPERB job many many moons ago. He wasnt confident when it was built, but thought it was early 90's. Its powered with a Sach 4.2 on a Byron tube mount, but it does not have the ''Purr-Pwr'' setup either. To the guys that have/had the Sach's engine, are they reliable? Parts avail? Mine still has the orig CH mech advance ign setup...has anyone upgraded the Sach 4.2 to a auto-advance(current) CH ignition? Ill post pics tonight, but minus batts,prop its sitting at 22lbs...
I bought a second Byron Corsair that had the same set-up. It was clear that several people had owned it but all were too intimidated to get it to fly. I pulled the engine and removed the Byron's Powr Prop (too hard to get new blades) and sent it to C&H for a prop hub conversion and an electronic ignition conversion. They ran it up and it works great! I need to finish updating the airframe (lose the Futaba S148 servos on the ailerons!), rehinge the flaps and put a spar in the horizontal stab before its ready to fly.
Scott
#835
My Feedback: (61)
ORIGINAL: ColeTrane
#838
OK
ORIGINAL: Fly2XS
Nice!
Scott
Nice!
Scott
ORIGINAL: warbird_1
sachs had a good setup for it's day . the throttle coupled spark advance was nice because it made the engine tune able and let it start easy. but they do now have a new setup. which i'm sure is the way to go.
#839
My Feedback: (129)
WhoDaMan, has the Hellcat flown yet? I picked one up that needs a bit of repair and am wondering how yours flys. I have a new Walker Sachs 4.2 with C&H ignition for mine. Thanks, Mark
#840
My Feedback: (164)
CA
Hi Mark I have the same setup in the Hellcat, I am just finishing them up and have yet to fly them I did put belly tanks on the Corsair, just waiting for some magnets to hang them I will post pics when done, I like the three blade and I am running a three blade menz on the hellcat, My fist corsair that I owned lasted 10 years and I like the three blade, Less tail wag and it fly's around 100 MPH
Dave
Dave
#841
My Feedback: (61)
ORIGINAL: TripleDeucer
#842
My Feedback: (129)
Warbird 1, that is good to hear. As far as the Byron line goes, I think there were way less Hellcats sold in comparison to the Corsair, Mustang, and Zero. That makes them a bit more scarce to find. I was standing beside the owner/pilot when mine went in shortly after take-off. It had control problems in the tail. I'm going to rebuild some strength into the stab, like a strong spar. Right now it sits with both sides of the stab floping down.
#843
My Feedback: (65)
That was a common problem with the early designs. They thought that epoxying the stab halves to the fuse then binding them with a 1/16th inch thick ply trailing edge was enough. Some of the Byron Hellcats also had issues with the fuse flexing just in front of the tail. Many builders would reinforce the inside of the fuse with some CF strips.
If you look in Canuck's build in this thread you'll see he added the spar to the Corsairs stab. Starting at Post #33.
#846
My Feedback: (60)
AZ
Hellcat #1 photographed in 2004
And his recently completed second Hellcat from the Byron kit.
#847
My Feedback: (129)
Hey Chad, thanks for posting those two beautys. I can see three things I don't have. A scale tailwheel, sliding canopy option, and gear doors. I'll have to get to looking around. I might have the gear doors somewhere. It's been quite a few years since I got this thing. I did get a new cowl and canopy way back then. I also have the Byron tailwheel assy for the P-51/ P-47 that I might just use. I see a fork assembly on these two. Was that a Byron product?
#850
My Feedback: (53)
Hey Chad, thanks for posting those two beautys. I can see three things I don't have. A scale tailwheel, sliding canopy option, and gear doors. I'll have to get to looking around....
There is 1/6 hellcat construction article that used some Byron parts.
It shows the sliding canopy construction, and the gear door construction. The tail wheel did not retract, but looked good.
There are also detailed 3 vues (Bentley) and some pics of the full size.
Now, back to the Corsair.
