The unofficial Home of all that is Nitro Vee...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> The unofficial Home of all that is Nitro Vee... Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
The unofficial Home of all that is Nitro Vee... - 1/18/2006 11:06:03 PM
Vertical3-D
Status: offline
Ok first I'd like to state I love my nitro vee, great sport boat with the proper tweakings, second if the the shockwaves and others have there own thread why not the nitro vee, and third I believe the boat can be pushed to its limits and pass other rtr boats easily....Ill start this with my mods, I have a prop shaft kits from offshore electrics(40mm CF prop, works perfect), a macs 2.5cc tuned pipe(stock header pipe for now, tubed one later to come), a carb off a .25 magnum airplane motor(direct fit, tons better), upgraded cooling (see pics), and a 5 cell duratrax reciever battery which is 5 2/3A cells, works perfect even with the RTS, and finally a TQ transmitter(no more two stick garbage). it really flys now, Plenty fast for sprot boating, I'll GPS it when it gets nicer out, lots of wind now, which brings me to my story to start the thread...So I'm at the pond, 15-20mph winds blowing strait down the pond, I toss it out and get on the throttle, make a few slow laps, a little darty going into the wind whic was expected, so I start running it out, drop the hammer into the wind, speed peaks out, catches a wave, and we have LIFTOFF, It had 2 feet of day light under it as i watched it flip over and land upsidedown, runs a second, shuts off, and drifts in withough taking on much water at all(suprising, it was in the water 10-15 minutes) emptied it out(like half cup of water max). took about 5 minutes to get it to fire again, guess it got some water in it, dfired up and off it went again...this is why i love this boat so much, works great, it flips no prob, stall no prob...nice...below are pictures of my set up(will upload later) please if you have one of these or are interested, or just have an opinion heres the place...Thanks for the interest...
...Lets take these things to the next level...
< Message edited by Vertical3-D -- 1/18/2006 11:13:49 PM >
_____________________________
..."They took everything, even the stuff we didnt steal"..."They took the bar, The whole damn bar"...
       Post #: 1
RE: The unofficial Home of all that is Nitro Vee... - 1/19/2006 12:45:19 AM
wave waker
Status: online
sounds great,,pics pls.
losi,warhead,dirtbike,,HTB360-2 ,HS Dumas,Nitro hammer, H&M Tunnnel,hydrofoamie,nomadio sensor,cat31,OB SW36
(in reply to Vertical3-D)
       Post #: 2
RE: The unofficial Home of all that is Nitro Vee... - 1/19/2006 12:58:20 AM
Vertical3-D
Status: offline
Here they are, no running pics yet, I'll try and get some but i usually run alone, woulda loved to have that flip on video. anyway let me know what you think of it so far(far from done)...thanks...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to wave waker)
       Post #: 3
RE: The unofficial Home of all that is Nitro Vee... - 1/19/2006 4:01:38 AM
wave waker
Status: online
vertical3-D, nice mods, like the mac pipe look aggressive fast...
btw,where i can buy .25 magnum carb? it's a rotary carb,right?..thanks
       Post #: 4
RE: The unofficial Home of all that is Nitro Vee... - 1/19/2006 4:15:27 AM
Vertical3-D
Status: offline
yeah rotary, went right in with a sligh adjustment on the throttle linkage, kinda tough to sqeeze them bu the cooling inlet/outlet on the head but it doesn come in and out trust me,I'd check tower hobbies they may have it, also make sure if you can that its the right size, mine is from an older motor, dont know if they would have changed them but i dont think they would, i like them, good carbs, plus i hate traxxas carbs. and the pipe is a definate upgrade and good reason to fix the cooling and make it right, also take note to the placement of my turn fin, note its perpendicular with the hull on that side and lined up with the strake(i dont know hwo it handled stock but this way works pretty good)still can spin if pushed though(outdrives, i love to hate them)...I really hope ppl start getting into the modding of these, the boat recieves a bad rep. because of a few flaws in design that can be fixed easy enough...
       Post #: 5
RE: The unofficial Home of all that is Nitro Vee... - 1/19/2006 4:24:29 AM
Vertical3-D
Status: offline
doesnt look like tower has then, but the have s-loads of others, any carb for a larger airplane engine that will fit would probablly be good, because the dont limit the airplane carbs like they do on cars for racing purpose, and it looks like the carbs have changed(dunno if they are still same size though) OS engines run nice if you are familiar with airlbeed cabrs which most os plane engines(such as the LA series use)...I basically looked for something reliable that just happen to boost the power...
       Post #: 6
RE: The unofficial Home of all that is Nitro Vee... - 1/30/2006 12:12:41 PM
NITRO_VEEDRIVER
Status: offline
i too have the nitro vee. well not yet. sometime this week. the only one mod i have on it right now is a brass prop. i believe by looking at the pic is a 3 blade one. here is a pic of it. yes it needs repairs but in due time. and yes lets us nitro vee drivers keep this alive. and get more modding ideas.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by NITRO_VEEDRIVER -- 1/30/2006 12:13:52 PM >
Drive Dirty!
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN!
       Post #: 7
RE: The unofficial Home of all that is Nitro Vee... - 2/1/2006 4:49:27 PM
NITRO_VEEDRIVER
Status: offline
BOAT FINALLY SHOWED UP>>>> the before pics are already on here. i will update with more when i can.
so far all decals are off it. i will be buying an airbrush, along with met gold paint and gloss black. custom
made graphics are also being applied after paint. right now as she sits she is white as if she came right out from original box...also i made the mistake by saying she has a 3 blade prop on it. she is 2 blade .
Click for fullsize
Click for fullsize
< Message edited by NITRO_VEEDRIVER -- 2/3/2006 1:42:08 PM >
Drive Dirty!
(in reply to NITRO_VEEDRIVER)
       Post #: 8
RE: The unofficial Home of all that is Nitro Vee... - 2/3/2006 1:53:24 PM
NITRO_VEEDRIVER
Status: offline
well here she is with just the trim done...
Click for fullsize
Drive Dirty!
       Post #: 9
RE: The unofficial Home of all that is Nitro Vee... - 2/4/2006 12:09:47 AM
Vertical3-D
Status: offline
I take it that you took the exhaust coupling off there as it is on in the before pics, you may wanna think about a tuned pipe for it, I really like my macs 2.5cc pipe, it was 28 bucks at tower, takes a little work to mount it, you can see how i did mine in the pics i have one here....glad to see at least someone is talking about these boats....
       Post #: 10
RE: The unofficial Home of all that is Nitro Vee... - 2/4/2006 4:41:48 AM
NITRO_VEEDRIVER
Status: offline
well i did say lets keep it goin anyways what ya want for the pipe you have there besides yours?
Drive Dirty!
       Post #: 11
RE: The unofficial Home of all that is Nitro Vee... - 2/4/2006 5:03:26 PM
Vertical3-D
Status: offline
what did you mean, did you wanna know what else is the first things to upgrade...the pipes are 28 bucks from towerhobbies, and when you switch pipes it gives you a reason to redo the cooling system, which i also heavily suggest doing...
       Post #: 12
RE: The unofficial Home of all that is Nitro Vee... - 2/4/2006 8:46:55 PM
