- JR XP8103 channels
- JR 9303 Range Check
- dual elevator servos on 6102
- 549X
- Transmitter Module Pinout
- Rebuilding servos????
- one switch for dual rates for ail,elev, and rudder
- XP9303 PPM resolution - 10-bit?
- Lithium-ion voltage (8v) into JR reciever
- what is the best transmetter for twin engines
- JR 8511 servo slop
- JR 7202 throttle cut off?
- servo setup with watt meter
- 4721 torque ratings at 6.0V
- DX6 Not bullet Proof Definite Glitches?
- Throttle Activated Spoilerons
- 8103 and 549x
- Buddy Box & Battery Help
- JR8103 and ignition cut-off
- 2500mah ni-mh batteries for SX10 TX
- DX6 - Generating Interference?
- TX nicads or ni-mh ?
- Old X347 battery problem
- 8611 and 8611A differences
- Nearest Service Center
- Needed - Heli throttle spring
- R700 Receiver Lock Out?
- Nimh battery pack trickle charge?
- Apex 7 Transmitter
- JR XP7202 radio
- servo service
- 7202 transmitter available separately?
- R790 no light
- 7202 fuse
- 2721 servos
- JR 9303 switches
- servos for showtime ARF
- 10SX
- JR 9303 & snap rolls
- JR MX16 vs JR 7202
- Synthesizer Modual
- XP7202 - How do you add 2nd aileron servo on Aux channel?
- Spektrum DX6 On Blade CP Pro
- Matchbox endpoints
- 10x ultra stick programming
- How do I switch to mode 4 on my JR9303?
- 9303 dsc tech support
- 9301 blows fuse when charging
- 7202 timer
- Elevon on 7202?
- JR Pro Century vii
- JR R1 transmitter case
- refresh my memory on range check
- DS 8411 servos question
- JR X-388S transmitter
- XP-7202 - Flash Memory or Battery backup
- DX6 battery
- DX 6
- trim offset mode on JR 8103
- JR R649 RX antenna color
- This aint my day with JR: help
- JR 8103 Tx help
- 9303 Trainer switch doesn't work
- 8611a Replacement Case
- JR W125
- 7202 technology bound for any other JR radios?
- Help!
- Shift select on 9303
- How to set up flaps?
- 9303 Heli vs Air
- JR 9303, INVERTED HOVER SWITCH????
- Changing 6102 to mode 1?
- X2610/XP6102 PC connectivity
- JR 9X II Programming
- 7202 Throttle Recovery
- JR Receivers
- Duralite 11.1 V TX battery
- PCM10X as Master
- D/R on JR 7202
- Alternative rx's
- 9303 range test question
- 9303 Flight Mode Question
- jr radio + Ultra Stick
- 8103 + UltraStick Crow programming
- planning to buy jr 7202
- PLEASE HELP. Interaction of Ailerons and Flaps????
- Quatro/S400
- Replacement touch screen for 10S
- 8231 Servo oscillates around neutral
- jr mixing 2 throttles
- 3810 2nd hand Price
- 9303 programming- mate assignments
- 8611a torgue 240 vs 260
- Regulator ?
- 50cc Gas Engine Throttle Servo
- 9303 and matchbox programming
- DX-6 rudder expo?
- JR tansmitter battery
- 8103 question re 2 servos for elevator
- 8103 SPCM Fail Safe Settings
- Heli vs Aircraft
- New JR 16 channel radio...
- 8103 and retract help plz.....
- 9303 Blown Fuse
- JR "Z" PCM on 9303 - will the rx's work?
- PCM 10sx screen?
- 10X Throttle Detent?
- JR 9411 servos
- 9 x11 how do i free up aux4
- Glitch hunting
- burned up 8611's
- Jr Transmitter Springs
- JR 8611 programmable?
- Hangar 9 Aluminum servo arms
- Can't Freq. Program new R790 RX
- CCPM Settings on X-388S
- Discontinued product specs
- JR 10S Radio
- JR Channel 12,13,14
- Aileron settings do not stay put
- NEW ER539 Servos noisy when moving
- PCM 10
- Programming question (MX-22)
- 8103 LCD
- XP652 & Hitec HFS-04MG Receiver
- 6102 retrac end points
- MX22
- How to change models on JR631
- Return policy
- Rudder Dual rate 6102
- gyros
- 8611a's And Titanium Gears
- 8611a servo arm screw size
- Transmitter trays
- JR X-388S problem
- 631 switch problem
- R945S dual conv.Rx
- Old SPCM Rx, New Tx?
- Dual Elevator setup
- XP8103 compatibility
- New synthesized module
- 9303 quad flap?
- MAJOR PROBLEM JR8611A
- Jr Tx-Hitec Rx compatibility
- JR/Graupner MX22 range test
- Charging JR XS3
- 9103/digital trims/expo
- R700 Receiver Problem
- Danny - Setting up Flaps on 10x to use Flap Switch and not side lever?
- 8611A Jitters
- 8103 TX Springs
- 8103 w/ Quattro Lite Buddy
- XP652 and a R600
- Spektrum radio in the UK
- JR PCM9XII questions
- 8611a Problems
- XP9303 Synthesized
- 10X aileron setup help
- What JR for Dual Ele
- compatibility
- JR PCM 9 SS TX
- 10x xmtr take apart
- Perhaps an old question.. about parts
- current Ham TX models?
- Problem with Turmoil Spectrum Radio
- Another 9303 programming ? pretty simple though
- 8103 problem
- JR PCM 9X series 1
- Is it normal?????????????
- JR 10X Battery?
- Any new "NEWS" on the 7202?
- Lihium Battery
- 9303 mode switch
- Trainer switch activating full flaps
- Buddy Box 9303
- 9303 Memory Problem
- 9303 problem
- What PCM rec?
- x-347 pcm spec
- Digital servos go crazy
- Century VII rcvr. crystal
- Spektrum Jr. R-1 Pro System--receivers
- Questions about JR 622/642 Setup
- Faulty JR 8511 servo
- jr r1 pro
- JR Matchbox
- Two JR Rcvr's are dual conversion-why?
- Euro Fighter setup on 10X
- 10X and 8103 trainer cord set up
- Older 8611 Question
- RS10DS Synth Rx
- Servo ATV @ 150%
- 9303 trainer button question
- New synthesized JR 9303 - dials on module?
- XP9303 or 10X System?
- mixer offset for 8103..........
- Crystal Swapping on 6102 - channel 35 t0 32
- jr xp783 tx
- Jr Flight Packs & futaba servos
- Throw problem with dual flap servos
- I made a careless, dumb mistake, please help!
- JR x-388s repair shop?
- JR 9XII memory problem
- Battery?
- Dual Elevators - Unequal Movement ?
- Xr2i glitching.. HELP!
- 9303 battery getting weak
- Is it possible to add new software in PCM 10 "Z"???
- Dual aileron servos - 9x
- 8103 module?
- Help with pcm 10!!!!
- DS 811 Jitter
- R610M Rx with Hitec Optic 6 (35Mhz)
- Danny Need help with XP-378
- Modifying sprung switches on 9xII Tx
- 9X PCM programing question
- 9303 manual error
- XP8103 trim offset
- 9X II throttle cut reverse
- JR X-2610 radio system
- whuch radio to get???
- Fail Safe
- voltage rating for RS300 Rx
- Danny
- Help range check
- 9303 physical differences heli/air?
- Sport sx600
- Glitching problem.
- Million Dollar question
- Crow/throttle toggle 8103, e-sailplane
- JR 347 and JETI Rex 5
- JR 2610 Travel Adj and sub trim Problem
- JR 8611 servos
- JR 7202
- JR 7202 Manual
- jr 9x glider mode
- Seting up crow function for aircraft with 8103
- Getting JR servos fixed
- 6102/9303 "Pilot Link"
- Re:singing sevo
- 9303 Questions?
- Timer/Engine kill Switch
- Jr 9x
- Charge jack plugs?
- PCM 9x2 Want the side lever to output to Aux 4 ??
- R790 and NET-J72P compatibility
- JR 8811
- shift select?
