Wagstaff Extra 300
#652
Originally posted by 232Cap-Tain
Andy,
That looks teriffic!!!! What's the leaf spring material made of? Where did you get such a great idea and finally have you used it on other planes before?
John
Andy,
John
John,
They are manufactured by a company called CB Tatone Inc. in Hayward CA. Phone number is 510-783-4868.
My LHS carries them. They come in different sizes for airplanes of different weights. Most come straight have have to be bent although others are available that are prebent. I drilled an extra hole between the original holes and bent the leaf springs a little longer to get the right length.
Yes I have used them before and the work very well and look good.
Andy
#653
Originally posted by DeadSticker
Thanks guys!!
Hey Andy, have you flown this beast w/the 3w48 yet? Now you have me thinking about that engine instead of the RCS44b2. And another reason is because I am in Frankfurt Germany right now and the 3W factory is only 11 miles from where I am at. Haven't gotten to pay it a visit yet, but definantly plan to. Thinking maybe that it would be cheaper to buy it on thier economy than to order it on the states. Plus who knows, factory direct prices???? Hmmmm....makes ya think,huh!!!!!
Thanks guys!!
If you could buy it there and get it home, I would.
Andy
#655
My Feedback: (7)
Originally posted by AndyF
Finally I bent the leafsprings to the correct shape and bolted them in place with 4-40 cap screws.
Andy
Andy
#659
First 2 flights on mine today, and at 17 lbs it lands like it's got a parachute attached. It just floats and floats. The sweetest bird i've ever had my hands on. Got a Fox 3.2 for power and it's all i could ask for and more. This is one GREATTTT flying plane. Just give me 4 clicks of throttle and 10 feet of runway and bye-bye baby. (airborne). Can't say enough about it. I think i'll keep her.
#660
Originally posted by dick Hanson
with a bit of careful planning - I bet one could get this kit up to --- 18 lbs?
Hmmmm....maybe I SHOULD get that DA 100 for it after all!!!
#661
NV
Andy,
I looked up the Tatone website and they don't show the actual picture of the assembly, only the description "Tail Wheel Assembly for 1/4 Scale" at a price of $20. Does that sound about right for the price?
#663
Andy,
Andy,
I believe the one that I used was in the 9-18 pound range. I have the exact part number at home. If you decide to do what I did, in order to make it the same length as the stock tail wheel, I had to drill an extra hole about an 1" away from the hole closest to the front of the plane. Then I made my bends between the second and third holes.
One of the tricks that I use when I bend these is to put a screw and nut through the first hole so the leaves line up. First I bend the longest piece that holds the tail wheel by clamping it in a vice (make sure that you square up the leaf and the jaw of the vice before you bend) and bend it to the angle that I want. (I use a hammer and hit it close to the jaws of the vice so I get a clean crease. Then I bend the tail wheel tab, but I always bend it a little less than I want because it will bend a little with he weight of the plane on it.
After I have the first piece bent I bolt the next leaf to the first and clamp both in the vice and start the bend on the second piece. Then I take them apart and put the second piece back in the vice and continue the bending process and I bend this leaf just a little more than the first. (When you assemble the leaf spring the second and subsequent leaves load the main leaf bending it slightly down, but once the weight of the plane is on it goes back to the desired position.)
Just continue the process for leaves 3 & 4. For lighter planes it is not necessary to use all of the leaves.
I hope this helps.
Andy
#664
Anybody questioning the quality of the 4" spinner that comes with the GR WP 300S. One of the, "so called retired engineers" at our flying field, looked at the spinner and said he would not trust the quality of this spinner, especially the backplate. He added that the backplate may crack when using a gas engine. He said that he would discard this spinner and use only A Tru-Turn or Cermark's brand spinner. Is this bull or a valid statement?
Also, on the BME 50, what is the nut size on the prop shaft. Is it 3/8-24?
#665
My Feedback: (7)
CA
Andy,
Tailwheel looks great! I was wondering if the pre-bent version on Tower would work(bend angle), or if I should get the straight one? Also you mention you used the 9-18 pond version. I saw that Tower has a 1/4 scale version as well. Any info on that? Thanks
#667
My Feedback: (22)
AZ
rcguy1,
I'm definitely not a big fan of plastic spinners regardless of the design.
Yes, they are lightweight, and the colors are nice. But....
They crack in many different areas; backplate, screw channels, etc. (and sometimes come apart hitting fellow club members -- very dangerous as well as very embarassing!)
They grind up when using an electric starter, unless your are super careful.
If you use plastic, inspect it often.
Metal is far better. Many brands to choose from.
Maybe CF, if weight is critical and your wallet is deep.
Just my 2 cents.
__________
jmboss
Just my 2 cents.
__________
jmboss
#668
My Feedback: (7)
Originally posted by jmboss
rcguy1,
Just my 2 cents.
__________
jmboss
rcguy1,
Just my 2 cents.
__________
jmboss
http://www.geocities.com/pierrejac/c..._spinners2.htm
#670
My Feedback: (22)
AZ
rcguy1,
My Bad! Hoping for a PW 300S under this year's Christmas tree.
Got the engine and servos, just need the plane.
With all the info in this thread, assembly and mods should be a breeze!
Roger,
Thanks for the web link on the CF spinners. COOL; VERY COOL!
____________
jmboss
Roger,
____________
jmboss
#671
Originally posted by KabarAV8
Andy,
Andy,
Andy
#672
My spinner was all aluminum, back plate and cone, but I replaced the spinner with a Dave Brown standard shape ultimate spinner. I didn't trust that wire bracket on the front of the 3W48B2.
Andy
#673
Originally posted by aerografixs
Here is a spinner worth looking at.
Oooooh!!! Ahhhhh! I love the shape of the 3 1/2 in version in the first picture. I think that it just about matches the Cessna classic spinner.
Andy
#674
My Feedback: (19)
I thought the aluminum spinner was a little cheesy myself but After 16 flights and 1 broken prop it is holding up fine. I did have to grind it out for the 22" prop. Nothing at all wrong with the stock tailwheel setup either so far. I assume you could drill out the support arms on the stock spinner and use a prop shaft nut to screw the spinner into if you really wanted to do that
#675
Smallfly:
Just wondering where your at in So. Ind? Maybe we could get together and compare notes on this bird. BTW I must say you've been a great help to a lot of people on this thread. Thanks.
Got first 2 flights on mine the other day but plan on many more this weekend. Hope mother nature cooperates..
