E-FLIGHT BLADE CP
#2577
Hi,
I'm a new CP owner and am concerned that the blades should be balanced. Could one of you experienced fellows point me in the direction of an appropriate tool for micro helis?
#2578
ORIGINAL: IMAC781
Hi,
Hi,
#2581
WV
Hello
Has anybody tried the cnc frame for the blade from helihobby.com. Im not sure if it would be too heavy or if anybody has any input on it. It looks nice and pretty rigid. Any feedback would be greatly appreciated.
Thanks Scott
Thanks Scott
#2582
Help! I just got a used Blade CP and have a take off question. I can apply full throttle and we are not going anywhere, just spinning blades. If I just apply a small amount of forward flight, up we go like a rocket. If I do the same thing on 1/2 throttle, little forward trim, it starts to take off just right, but if I stop the forward trim, down we come. One paddle bar was slightly off. Any suggestions? Thanks
#2584
Remove the canopy, unplug the motors, and operate the throttle, see how things are moving. At no throttle, blades should be level, and as you raise the throttle above 1/2 way, positive pitch should be added. You may want to hold the flybar level while doing this...
#2585
ORIGINAL: baddley
Hello
Thanks Scott
Hello
Thanks Scott
#2587
I am having trouble with my blade . When I plug in the battery with the transmitter on it does not go active it keep moving all its servos and them stops . I turned of my remote and it went crazy. WHat can it be ?
#2588
MN
ORIGINAL: ronaldpa
[link=http://www.bladecprepair.com/troubleshooting.php]BCP Troubleshooting[/link]
#2589
ORIGINAL: ronaldpa
Check to make sure the throttle and throttle trim are set to 0, all the way down. Then turn everything on. If that doesn't work, try re-seating the crystals. If that doesn't work, check you battery voltage in the transmitter. If that doesn't work, go to the link ILO64 gave.
#2590
NC
ORIGINAL: GTX SlotCar
Here's what I'd try.
ORIGINAL: ronaldpa
#2591
ORIGINAL: RamboSmurf
#2592
Thanks to all for the help. Upon further review, I think I have some major problems with the CP. When I apply right or left aileron, both the rear servos lift. According to the instructions, this ain't supposed to happen. When I apply throttle, 2 servos or moving. Any ideas? 4-in-1 Nuts? I think I'm gonna have to take it all apart and rebuild. Buy used, get what you pay for. But any help will be greatly appreciated. Thanks.
I'm tired of stealing my sons Lama2.
Dave
Dave
#2595
NC
Also check that your reversing switches have not been switched from the factory settings. Ail and Thr should be in the NOR position, and Ele and Rud should be in the REV position.
#2596
Again, Thanks for the help. Upon further review. It appears that I have a GWS Picco std servo on the left rear. E-Flite on the other 2. The GWS is working backward. Anybody have a Functional Heli Gunship, because I want to strafe the previous owners house. Would a Esky Honeybee servo work until I get the correct one from E-Flite. Again, Thanks to all.
RS
RS
#2598
I have an interesting senario... Just put new servo's, and swashplate on my BCP. When I went to set the head up, I see that even the new servo's have about 1/16" play in them, so I wound up having to adjust the swashplate height by making the link adjustments when holding the heli up by the swash as if it were hanging in the air by the blades and paddels. When I set the height by letting the swash rest down against the servo's and linkages, I didnt get enough lift to get it off the ground without excessive stick. My VNR3D has almost no slop in the servo's, swash and inkages, and the BCP has new stuff. What kind of nonsense is this ? Dennis
#2599
RS
RS
Dennis, did you get e-flite servos? I don't have any play in any of mine. Maybe you got a bad batch.
