DL-50 engine
Old 04-02-2009 | 04:55 PM
  #4401
My Feedback: (29)
Default RE: DL-50 engine
I was able to get my engine running today. It ran very smoothly I noticed that it consumed fuel very quickly compared to my Fuji 50. Also, I noticed a black oily reside coming from the muffer and sticking on the airplane. Is it normal to get the black residue from this engine?
Old 04-02-2009 | 05:09 PM
  #4402
My Feedback: (42)
Souds like it is running to rich, you may want to lean the H & L end screws some, What RPM are you getting?
Old 04-02-2009 | 05:13 PM
  #4403
jedijody's Avatar
Some exhuast byproduct is normal for any gas engine but rich running new engines with poorly adjusted carburetors and unseated rings produce more than any other. Adjust your carb for optimum performance and you will get the fuel economy and power the engine is capable of, much less mess also. Give it some time to seat the rings and it will be even better.
Old 04-02-2009 | 05:18 PM
  #4404
My Feedback: (29)
Thanks for the response. The engine idles at ~1360 rpm. At full throtle, I'm getting 6600 rpm.
I guess it wouldn't hurt to run the engine rich for a while.
Old 04-02-2009 | 05:24 PM
  #4405
jedijody's Avatar
ORIGINAL: ply68
Won't help anything either.
Old 04-02-2009 | 06:05 PM
  #4406
GregT882762's Avatar
Have a question,im fairly new to gas,maiden my firsyt flight with my DL50 yesterday,ran great i have about 31/21 -4 tanks through it,my question is while in air between 1/4 and half throotle was burbling or missing sound often but when i hit t hrottle sounded greast i know its supposed to run rich for few gallons i think when should this go away or when should i help this go away ?
Old 04-02-2009 | 06:14 PM
  #4407
Can this engine swing a master screw 22-12 prop? I just bought the plane and the guy says it turns it good. Is that too much pitch. The plane is darn fast for a Sun Dancer Bi-plane. Also what is a good size tank for this engine.
Old 04-02-2009 | 06:27 PM
  #4408
no offense but most of the guys in my club call master airscrew props paint paddles try a xoar
Old 04-02-2009 | 06:32 PM
  #4409
ORIGINAL: GregT882762
Like Jody said, no need to run them rich. They're not glow engines, tune it and fly it
Old 04-02-2009 | 06:38 PM
  #4410
cool,just wanted to make sure it was broke in ok,what size spinner are you guys running on this motor?
Old 04-02-2009 | 06:57 PM
  #4411
ORIGINAL: jedijody
ORIGINAL: Helicam Oaxaca
Hi all I own a DL50 that I have installed in my EF Extra 300 88" and I´m very happy with the engine, so happy that I got two new DL50's for my Ziroli P38, I already have the plans and all the glass parts and I´m waiting for the wood that should be here next week, my question is, can I modify one of the engines to have counter rotating engines in my P38? is this posible? Has any one made this modification?
Thanks in advance
Rafael Castaneda
Oaxaca Mexico
This should be possible without to much trouble, 2 stroke engines really don't even know which way they are turning. All that really needs to be done is to relocate the sensor to achieve the required 28-30 degrees BTDC ignition timing while turning the other direction.
Thank you Jody, I will try to make the change and see what's the outcome I have time until I build the firewall of my Ziroli P38 and I will post the results.
Old 04-02-2009 | 07:31 PM
  #4412
JoeAirPort's Avatar
My Feedback: (41)
Does it do it more in the air than on the ground? If so your cowling drafts are hitting the carb plate vent and making it run rich. I installed an 8-32 barb and plumbed it into the fuse with tygon. Much better now. If it does it on the ground too then just lean the low needle.
Old 04-02-2009 | 07:46 PM
  #4413
just in air
Old 04-02-2009 | 08:04 PM
  #4414
Greg,
Did you run a line from the diaphram into the fuse like the picture of mine? You may need to to help the burbling.
Also I have a 3.5" spinner on mine. If you don't need any nose weight I have a "carbon fiber like" 3.5" spinner cut for a xoar 22-8 that I will make you a real deal on. If you look on Valley View RC you can see them. If you want aluminum look at TBM http://www.troybuiltmodels.com/ns/acce/spinners/mpial/. Only $28. I have this one and it is really nice. Also lighter than True Turn.
Is anyone from your club going to Franks this weekend?
Old 04-02-2009 | 08:14 PM
  #4415
hey naw i didnt run the line didnt want to void the warranty but may have to,as far as the spinner how much you want got a pic?We are gonna start burning tomorrow and sat during day so prob not anyone going to franks
Old 04-02-2009 | 10:08 PM
  #4416
I just now ordered a Xoar silver painted 22-8 and a Vess 22B prop. I will try both and see which is better. What are the flight envelopes between the two? I need to also find a loud prop. Most people want a quiet prop. I like a a loud prop noise to make a more realistic sound. The
Greg, Master Airscrew is wide enough to stir and mix paint well. I believe you have something there.
Old 04-02-2009 | 10:13 PM
  #4417
No pun intended just what ive been told
Old 04-02-2009 | 10:45 PM
  #4418
Thanks for the help. That`s why i ordered the props. I am new to gas. I want the best wood prop i can get.
Old 04-02-2009 | 10:52 PM
  #4419
giddyuperic's Avatar
Hey guys I am sorry to but in but for some reason I lost all of my links. I mean about 160 of them so I am lost. I need vally view rc and dl usa please? I don't know if those are even right. Thanks. Eric
Old 04-02-2009 | 11:00 PM
  #4420
jedijody's Avatar
ORIGINAL: giddyuperic
Don't know why you need the DLUSA one but here you go.
http://www.valleyviewrc.com/
http://www.dlusa.net/index.htm
Old 04-02-2009 | 11:01 PM
  #4421
JoeAirPort's Avatar
My Feedback: (41)
Dam Jodi, I'll just call you quick draw...you beat me by a minute.
PS: Eric, I've had better luck with Valleyview than DLUSA. Valleyview RC had engines in stock (DLUSA did not) and Jodi helped me right away with a carb rotation question.
Old 04-02-2009 | 11:12 PM
  #4422
paul5992's Avatar
I'll step in here. Valley view RC is the one to call. Jodi always answers the phone and doesn't give you the I'm to busy or I'm to good to Talk to you attitude that Bob does at DL USA.
Old 04-02-2009 | 11:33 PM
  #4423
jedijody's Avatar
Thanks guys, Let me know if I get in the way at all. I've been gettin into the forums lately for some reason, maybe it's the company.
Old 04-02-2009 | 11:47 PM
  #4424
Yes Jody you have been the most helpful to me. That is why I bought my props and batteries from you guys. Just trying to get back most of my list. Thanks Eric
Old 04-03-2009 | 07:01 AM
  #4425
that tells you alot about a pearson and there company when you ask for two different companies website that are peddeling the same thing, and one company gives you both!. jody you guys at valley view or a class act i cant wait to get the dle 100 i wish you guys would come out with a 160 but i will have to go to another good company and get a zdz , but you guys are class act.
