F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
#276
WA
RE: F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
ORIGINAL: critterhunter
Joe, the reason (I think) the APC 7x6 SF prop was selected as the best all around prop for the BP21 was to keep the amps tamed down a bit. A 7x6 is already pushing that motor over it's amp limits a bit and if you used an E prop you might red line it beyond return. Then again, I've heard of people running an 8x6E on the BP21 and a 3 cell. Just check the heat of the motor after flying full throttle for a few minutes. Land it right away so the motor doesn't have a chance to cool down and see if it's hot.
ORIGINAL: joe1
Hi Maine Flyer :-)
I looked at it just know looked at it again but it looks straight and I already gave it 1/4" of down on the thrust line by putting a shime under the front of motor mount that did help some.
I hate to get rid of it because it handles wind real good and it is strong.
P.S. There has been a few people that said they did not know if APC E Props came in a 7x6 and yes they do!
Hi Maine Flyer :-)
ORIGINAL: Maine_Flyer
you can raise the thrust-line by adding shimms in the front and or torquing down the rear motor mount screws..
#278
PA
ORIGINAL: somegeek
To which I award thee...
ORIGINAL: Buggygovroom
ITS FRIIIIDAY!!!
ITS FRIIIIDAY!!!
Finally!
#279
WA
Finally!
ORIGINAL: somegeek
ITS FRIIIIDAY!!!
ITS FRIIIIDAY!!!
Finally!
#280
AR
While checking my Stryker over for its maiden flight, I noticed what appeared as fixed incidence trim-tabs, at the trailing edge of the wing, and perpendicular to the tail fins. The tabs are on both sides of the tail fins, at the rear.
Sighting down the nose, you may see the incidence of these tabs, with a bit of "up" incidence built-in. They are part of the wing foam structure.
Anyone care to comment?[8D]
#281
ON, CANADA
Maybe the foam got bent up a bit in shipping. I would not worry about it, just toss the plane with a slight up angle at WOT with up elevator trim st to up elevator and it should fly right out of your hand. If you damage the airframe, it is only 20 bucks to replace. I have gone through many over the past few months. s
#282
AR
I'll just launch and deal with the trim. No biggie. Was curious if anyone elses was that way out-of-the box.
It won't launch today. Wind is gusting to 25 mph or more, and no relief 'til sundown. Tomorrow is forecast the same. May have to hit the field at daybreak.
#283
ON, CANADA
RIderbike: I never had a damaged one that came as RTF but I have seen the replacement fuses in bad shape from shipping. Best to try to get one as straight as possible. Once my fuses get too bent, they will tend to pull to one side at high speed. Everybody loves this plane who flies it, it floats at low speed and really moves when you get on it. If you have snow/ice, you can even do some touch and goes with the thing.
#284
ON, CANADA
#285
PA
Need a little advice on the wing loading on my AP plane. It's very near complete so I piled everything onto the digital scale to see where I was at for a ready to fly weight, camera and all. It was reading right around 36 ounces. It should stay near that but worse case let's say 40 ounces would put me at around 16 to 17 ounces per square foot for the 48" wing. Gliders are around 10 and trainers around 15. Do you think this plane is going to land and fly too fast to stay in the air? If the weight does hit 40 I guess I could increase the wingspan to around 56 inches and that should knock it down to 14 or so. I'm not too concerned about it wanting to fly a bit faster to stay in the air. Mainly I wanted to be able to keep the speed real low for good landing in tight areas where I plan to launch (hunting property, etc).
#286
AR
I'll see how it performs as-is. If unacceptable, will prolly tweak the foam. I'm hoping the typhoon 3D will have the same battery connector as the Stryker, when it arrives. I'd like to be able to use the Stryker battery in the Typhoon, so I don't have to buy another lipo battery. The typhoon is a X-mas bundle, with an extra battery, but judging from videos, it looks nice in lipo.
Charles
Charles
#287
PA
A few more pictures of the AP plane. Just have to cover the last bit of the fuse on the top near the rear once I get the one mile RX to install. Bottom of fuse/wing/tail is black. The rudder didn't show up well in the photo but it's black also. Top of fuse will be finished off in black as well. The compartment towards the nose is where the battery goes. Camera is mounted inside the belly directly at COG so the plane will fly right with or without it installed.
In the last photo you can see the 3V voltage regulator, servo plug, and dummy batteries to run the 5100M Aiptek pocket camcorder off of. The regulator servo plug plugs into another plug that is wired directly to the plane battery wires. The 3V regulator has a large heat sink on it to keep things cool and has a thermal shutdown switch for safety. Thus far on test bedding it the regulator only gets luke warm and it'll be getting plenty of airflow where it will sit.
The dummy AA batteries are dowl rod with a nail at the end and the output wires soldered to them. I could have drilled and installed a small DC jack onto the camera but didn't want to take it apart. I was thinking of powering the camera via it's mini USB jack but can't find the jacks alone and cables are like $15. Anybody know where to get them cheap? This setup weighs .8 ounces where as two AA batteries weigh 2.1 ounces so I'm saving well over an ounce of weight but ditching the AAs.
Getting better with the econocoat all the time but the plane isn't wrinkle free. Excuse the dark pictures as I work on my planes in a dungeon...my basement.
#288
WA
ORIGINAL: r1derbike
That was my first thought. The whole plane has an upward curve (think like teacup saucer) to it as well, not perfectly flat.
#289
MO
Hey there.... I just maidened my stryker today and had 6 great flights but I would like to change my electronics over to my Spektrum system. Does anyoone know how many amps the stock motor pulls so that I can add the right esc?
#290
ON, CANADA
C version pulls just over 22 amps static on an APC 6X4 prop. B version, no clue.
#291
I got some video of my Stryker today.Not real good quality.I didnt have my 1 gig card so had to use low setting on my Sony digital camara.My set up is a E-Flite 2000KV Six Series with a Silver Series 45 A ESC,3S hexTronik 1700mAh 11.1v 20-30C Lipo Pack with a 6X5.5 APC E.
http://www.youtube.com/watch?v=ACGyfdhiuYY
#292
MO
Thanks Mach..... I got bored and went ahead and installed one of my HiMax motors in the stryker. I am using a 2812-1080 which will give me a prop speed of about 60mph. I know that this isn't much compared to most of the guy's on here but I am new to this and I don't want to get too far ahead of my skills.
#293
PA
Anybody know how many amps typical servo wires can handle roughly? On my AP plane I'm planning on using a servo plug and wire to plug the camera's 3V regulator directly into the plane battery. Don't want the servo wires melting on me. Also have to do an amp reading on the camera to see how much juice it's drawing.
#294
MO
Check to see what gauge wire your servo leads are, then go here http://www.powerstream.com/Wire_Size.htm and you can see the max amps for that type of wire. Also it depends on the amp rating of the bec in your esc. Be careful not to go above that rating as if you do the esc will shut down.
#295
PA
Not powering it via the BEC. The 3V regulator I'm using to feed the camera is wired directly to the plane battery leads and not through the ESC or RX. The problem with matching gauge wire to amp ability is I don't know what size wire the servo plug is using. I was just told that typical servo wire can handle about 1 amp of current. If that's true then I should be good but have to check the amp draw of my camera to confirm it isn't over one amp to be safe. Rather than using the dummy dowl rod batteries I'm hoping to ditch those and power the camera via it's mini USB port. Message posted elsewhere...
If anybody is looking for a very cheap USB cable try Dollar Tree or some other local dollar store. I found this...30" rectractable USB cable type A to mini 5 pin. Connectors AM-MINI 5 pin. Instructions also say "This USB cable connects a computer or USB hub to any portable USB device using a 5 pin mini-B connection. Common applications include digital cameras, MP3 Players, PDAs, and mobile phones." Price: One dollar.
I am wanting to power my Aiptek 5100M digital pocket camcorder off it's USB port via a 3V regulator. Even just a mini USB plug would have been fine, since I'm going to solder it up to the regulator. Was shocked to find that all the stores I went to wanted $20 to $40 for a cable that I planned to cut up anyway. On a whim I hit Dollar Tree and there they were. Neat little device. It has a retracting thin cord and is very small. Not that it matters since I only needed the mini plug.
Figured it would be less weight and hassle than the dummy dowl rod AA rig I have hitched to the regulator right now. Just have to clear up a few things. USB devices usually need a 5V input via the USB port. Not sure if my camera's stock cable has a voltage regulator to step it down to 3V or if the camera will power up on 3V via that port. Going to use a voltmeter on the stock cable to check. Also, not sure if the camera will go into some kind of PC mode when power is supplied via the USB port and not give me any control via it's buttons. Have to check that as well.
Either way, if you are looking for a cheap USB cable or just need the plug off one for some other purpose that's where you'll find a good price on it.
#296
ORIGINAL: Cali11
#297
PA
ORIGINAL: somegeek
Interesting... from what I've read the SF props produce more drag at the higher RPMs vs the E series props?
ORIGINAL: joe1
Hi Maine Flyer :-)
Hi Maine Flyer :-)
#298
AR
Maidened the Stryker today, in spite of wind gusts over 25 mph. Did a lot of hovering (not really hovering, but zero ground speed flying) and flying backward into the wind. This thing handles wind quite well. Much better than I had anticipated. Speed of the thing was OK downwind, guess I was just expecting much more, after flying nitro powered combat deltas. Upwind was a "pull" (technically, it is a "push" with this bird), bucking the ferocious headwind. Landing was simply a small vertical hover to the ground. Can't say anything about final glide ratio. Had to keep throttle up a bit for zero ground speed hover, drop it vertically to near the ground, and cut power to save the prop. Wind was blowing that hard.
This thing may achieve 80 mph airspeed in a dive, but seat-of-the pants radar, when the wind lulled a bit felt more like 65 mph WOT straight-n-level.
Estimated speed at 85 mph ground speed downwind, with the up to 25 mph tailwind. Upwind was prolly no more than 35 mph ground speed, with headwind. Looked like I could nearly run as fast as it was flying, upwind.
Anyway, I'll know more about it on a near calm day. All that was required was a little downtrim.
EDIT: Went back a few hours later to get some more practice in the wind, and during a pullout, I heard a loud pop. Landed, and a 1/4 X 1/4 in. chunk of foam was missing underneath one of the pushrods. Must have stressed the area a bit, around the servo area (was dinking around on high-rates, WOT). It felt solid, as the other wing, so ignored it and flew around some more. Had one rough landing due to the wind, but just scuffed the underside of the nose a bit. It's going to get scuffed-up under there anyway, right?
#299
ON, CANADA
Glad to here it went well.
Yeah, it will scuff. I have gone through many airframes over the months. Might want to clear tape the parts that hit the ground most often. I agree on the speed. I have dopplered this C version many times and the best it will get straight and level is 65 mph in no wind. I once hit 137km per hour coming out of a slight dive in a slight tailwind but it is really a 65mph plane, not 80mph as advertised. But ain't that the fun of modifying it?
#300
AR
