Official E-FIRESTORM thread
#7578
ON, CANADA
RE: Official E-FIRESTORM thread
It may be worth it if you get the parts cheap. The main difference is the main chassis, steering and the region around where the front suspension mounts. Body mounts are different too and the back bumper on the blitz is more extravagant. It should be easy.
#7579
AB, CANADA
i got my crimpers at safeway and they where like 2.50$ lol. but the seem to work good as i tried to pull the crimped wire apart but couldn't to it
so i guess there good
ORIGINAL: redfisher1974
Yeah you could do it with a rock if you had to, But you can not get the same quality of crimp. This being said a good pair of crimper's last a life time and are more then worth the money.
#7580
ON, CANADA
ORIGINAL: AL3xGR
Cannot somebody do it with pliers? I think 39$ to 400$ are too much for special pliers...
The Anderson Power Poles have to have a proper crimp so they don't pull apart easily and must be uniform so that the metal connector can fit properly into the plastic housing.
#7583
ON, CANADA
I'm old school - Deans, solder, done. Then again a good soldering iron (which I don't have) costs more than a crimper.
First day back to work since the 23rd. Man I forgot how much it sucks.....
I have a baja 5b SS coming.
#7584
ON, CANADA
Soldering's a snap once you've learned the knack of how to do it properly. With all my 1/8 stuff I use EC5 connectors and with my 1/10 rc's my preferred method is to plug the esc directly into the lipos as most of my lipos are the internal bullet plug style. In the past I've had great success using Power Poles. In my mind, for 1/10 scale, Power Poles are perfect when a connector is needed. Never ever had one fail or even heat up. I don't know if they'd hold up to a 9000kv motor, but I've run a 6.5t motor on Power Poles with no troubles at all.
#7585
1 Post
ORIGINAL: nitro-rob
#7587
ON, CANADA
I like deans too, But my solder station pissed me off for the last time.
ORIGINAL: nitro-rob
#7589
ON, CANADA
Will do. It should be here in 7-14 days. The show price was 875+ tax and the local shop quoted 900+ tax so lets see where this goes.
let us know what you have to pay for taxes and broker fees.
#7590
Hey Fellers,
Just wanted to pass on some info I found after about a week of searching. I ran my efirestorm flux for about a year with a NiMH battery and just got a new charger and lipo battery for Christmas. I remember reading about needing to set up the esc for "low voltage cutoff" but I lost the manual and haven't been able to find any info on here or on HPI's website on how to do it. Most people will tell you to get the Castle Link and do it with that but this is one of the few settings you can do without the Link. I finally found the steps to do it on the hpieurope website. There was an extra instruction book with my car that focused on the esc and that info is included on the manual pdf file on the hpieurope site. (Page 40) For some reason the USA site doesn't include that when you download the manual from their site.
Anyways, if you're a looking for the steps to do it click here and go to page 40!
http://www.hpieurope.com/manuals/pdf/10554.pdf
FYI, I finally ran the car today with a lipo battery and wow!
#7591
ORIGINAL: nitro-rob
Never Tried the powerpoles, but CRIMPING is the worst thing you can possibly do for a good connection.
Please try to avoid crimping it's dangerous...
#7592
1 Post
ORIGINAL: ElectricGuy007
+3 on Dean Connectors, all my RC's have deans even my backyard bashers have deans....
ORIGINAL: nitro-rob
#7593
ON, CANADA
Unless he was talking about those cheap little crimps (not sure of the name) ??
But in a Power Pole there is absolutely nothing wrong with a good crimp.
#7594
1 Post
Crimping is done in the space shuttle, Air planes and All high amperage industrial substations. You need the proper tool and good crimps. Try Goggling crimping vs soldering and you will find alot of good reading.
*Note- I am not trying to say power poles are better then deans, Just crimp connections have been proved to be mechanically stronger then solder
#7597
ON, CANADA
Any "high current" connectors are good. Power Poles aren't very popular in the rc car/truck world but are definitely a viable alternative, especially if you can't or don't want to solder.
#7600
AB, CANADA
I gotz 200 hundred bucks and I'm torn between these two desisions:
-Buy A tamiya Sand Scorcher ( But doesnt come with a radio though, which will go beyond my budget, BUT I do have a battery pack for it)
-Buy a Spektrum DX2S Radio for my storm
