Demon Cortex Gyro question
#126
I have to admit to being disappointed with my Cortex feeling I have been misled. Before purchase I emailed Demon to ask if it was compatible with the 18MZ Robbe 2018 and sBus, the reply was "yes". Shortly after unboxing I find it has no sBus output which if used would totally negate the principal of sBus.
i spoke to the factory guy at Jetpower who told me it would be 12 months for them to drag themselves into the twenty first century!
#127
My Feedback: (57)
#128
It is still a very good gyro if you can work around the lack of S-Bus output. If this is a critical feature then if you speak to Bavarian Demon (or whoever you purchased it from) and explain your disappointment then I am sure they will look after you.
#130
Bob B, I'm certain its connected properly, the two elevators wouldn't work if it wasn't. Zero chance the polarity is wrong on the leads. Even if I had them wrong, the rudder would physically move. I did not go through the learn process because the ailerons, rudder and aux did not work. I did plug the jumper in and watched it go through the steps, and the rudder did jerk. But it won't allow me to give input. Do I need to reset the gyro since it was already set up in another plane? The directions say no, but that could be it? I have not used the software yet confirmed which version of software/firmware I have. Again, it worked fine in another plane, so doubt that would be a factor either.
Depending on how your electric test plane was setup ie: "y" harnesses could part of the problem you are having. You said you plugged in the jumper and watched the the gyro go through its steps, if you do not move the sticks once in programming mode the gyro will ignore any of those channels that are plugged in. As Wayne suggested check the basic radio setup, then reintroduce the gyro to the install. Here to help, just let me know,
Bob
#131
Hi guys,
OK all well but I cannot switch between Bank 1, Off and Bank. I can only switch between Bank 1 and Bank 2. So the only way to switch off the gyro is to set Bank 2 to off using my PC. So now when the Orange led is on, the gyro is working and when the green led is on, the gyro don't work.
Another question I have, is how do I control gyro gain from my TX?
Gyro has been update to v15 using latest software on my PC.
What am I doing wrong?
Jan
Jan
#132
It is also incompatible with CAA requirements (twin Rx input) another request for information answered incorrectly. I remain interested to understand how to integrate the Cortex into the 18/2018 setup and at witch point does the PWM output become sBus!
m
m
#133
If you remain unhappy then please contact Bavarian Demon and explain to to them. They are good people and I'm 100 per cent sure they haven't intentionally supplied false information; that would not be in their interests.
#134
Hi guys,
Jan
Jan
#135
Jan
#136
The Aux channel is the gyro gain channel. Varying the value of that input varies the gain, on one side of the travel it is in bank 1, on the other side it is in bank 2 and with a zero input the gain is zero (i.e. gyro off).
I hope that makes sense.
#137
How many gyro channels do I need? I thought the only one is the Aux one? So in simple language, I have 5 leads plugged into 5 servo positions on my Rx - two ailerons, two elevators and one rudder. Then I have Aux plugged into a seperate channel - this is the only gyro channel from what I understand. So where do I get a gyro gain channel from?
Jan
Jan
You only require 1 channel to run the gyro. You may be 'over thinking' it all.
You need a 3 position switch if you want to use both banks (Or 2 different gains in the same bank) AND have an 'off' switch. For example:
Switch position A = OFF,
Switch position B = Bank 1
Switch position C = Bank 2
You could also just use one bank. For example:
Switch position B = Bank 1 (20% Gain)
Switch position C = Bank 1 (40% Gain)
It's completely up to you. If you only plan on using 1 bank and you don't need 2 different gain settings, then you could just use a 2 position switch. For example:
You mention above that you can't turn it off??? Check your servo travel page on your TX that it is actually going to 0 (zero). Anything other than zero, will mean the gyro is on.
Also, If you are interested in changing the gain whilst flying, you need to setup a switch which changes the travel on your GYRO CHANNEL.
Clear as mud????
Cheers,
Morten
#138
OK got it. Had to take the aux from my ch14 to another as it only handles 0 to 100 % switching.
I have the default gain settings at the moment. By varying the end points on my gyro channel I can reduce the gain from 82%t to 3% (as per my PC display when I move the gyro channel on my TX) - this is obviously the % gain within the default setting on the gyro - right? Should I reduce the end points on my TX to reduce to 82%?
#139
The 2018 has four sBus outputs and two receiver inputs satisfying the CAA requirement, the Cortex doesn’t slot into the system at anypoint. The iGyro for instance slots in between the Rx’s and the power expander,the Cortex cannot do this. It seems to me they have ignored the full extent of the sBus system or misunderstood it, the people on the Demon stand at Jetpower admitted these shortcomings, reluctantly, and said the full compatible system would take a year to come to market!
I am only disappointed with the response to my questions,not with the gyro, the gyro will be used in another of my models, an Airworld Hunter which is all PWM and under 20Kgs. I’m only pointing this out to forwarn anyone else who may be under the impression the Cortex is fully sBus compatible.
m
m
#141
[QUOTE=Springbok Flyer;11889872]OK got it. Had to take the aux from my ch14 to another as it only handles 0 to 100 % switching.
I have the default gain settings at the moment. By varying the end points on my gyro channel I can reduce the gain from 82%t to 3% (as per my PC display when I move the gyro channel on my TX) - this is obviously the % gain within the default setting on the gyro - right? Should I reduce the end points on my TX to reduce to 82%?[/QUOTE
What Tx do you use?
What Tx do you use?
#142
Hi Bob,
I use a Futaba 18MZ and Futaba 14 ch RX. I took the aux out of the 14ch on the RX and put it into ch11. Now the 3 way switch is working and all I wish to confirm, is that if I reduce the end points on ch11 that I will end up with that % gain as the % of whatever the gain setting is on bank1 and bank2 in the gyro.
Jan
Jan
#143
My Feedback: (7)
Hi Bob,
Jan
Jan
Yes, that is correct, the higher the end point value, the higher the gain for the associated bank and since the scale is 0% - 100%, gain should match the end point values very closely. However, I don't think you have any need to worry about values near the high end of the scale as you will never be able to run your gains anywhere near that high of a value. If i recall correctly, the setup guide recommends starting with a value of 20% in normal mode or 40% in hold mode. I don't personally use hold mode as it is best suited to hovering, etc, but in normal mode, I never get above 30% gain before oscillations begin. The amount of gain you will be able to use will be affected by servo speed and precision, airframe vibration, linkage slop, control surface size, etc. Start with a low value and work your way up. You'll be amazed at how locked in the plane is with a relatively low gain value.
#144
My Feedback: (18)
Bob
Bob
Thanks Bob, that could be it…. I will try it. Although I think I was putting them in one at a time and testing to see that they worked before the jumper came into play.
Another vote for S-bus! I have three Robbe 2018's, and a few power boxes that are S-bus. The srs has the igryo, but the others don't. Just programmed the nodes for a comp arf P-51 last night, one wire going down the fuse to address five servos is too cool :-)
#149
My Feedback: (7)
There is no need to reduce gain to maintain control authority. Normally, nothing more than reducing the expo on a channel is needed to give you the feel that you want. The Cortex doesn't fight your inputs the way gyros of old did. For example, the roll rate of the airplane at full stick deflection isn't reduced when the Cortex is enabled, regardless of gain. Still, there are settings that can be tuned with a PC to tailor the "feel" to better suit you if you can't get it quite the way you want by reducing / eliminating expo.
#150
Jan,
When oscillations begin, does it happen only on one axis or all. what if we need more gain on ailerons and less on elevator. whats the correct procedure for setup.
Chatty.
