Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Composite-ARF Integral, kinda build thread >
Old 07-22-2007 | 03:02 AM
  #301
ram_z's Avatar
Default RE: Composite-ARF Integral, kinda build thread
Hi all.
I just test flew my new Integral.
My setup is:
YS 1.60 DZ with hatori short muffler
APC 18.1X10 prop
TP 1320 LI-PO and powerbox digi-switch
JR 8241 for rudder
2 X JR 3401 for elevator
2 X JR 9401 for ailerons
JR 341 for throttle
Scan select R790 is the receiver
CG is a bit forward so I will try a lighter prop like mejzlik modellbau 18X10
After 6 flights I have only one problem so far, I can not hear the horrible whistles!
Is there any way to prevent it?
Thanks in advance
Ram
Old 07-22-2007 | 10:17 PM
  #302
chris j's Avatar
My Feedback: (22)
I see my pal, just back for the nats is reading up on the build thread. Ya go back to the nats buy a new plane cheap and don't bring anything back for the wife? Shame, shame. I know your name. and it's Mr. Tape.
Old 07-23-2007 | 11:17 AM
  #303
Great to see Integral at first and second at the NATS!!!! Congrats to Jason and Andrew.
Jason
Can you share the set-up difference between your NATs plane and the original one in this thread?
Where was the CG?
Colin.
Old 07-24-2007 | 01:25 AM
  #304
JPZ
Jason and Andrew
Congratulations for your performance
ZN line team
Old 07-24-2007 | 06:30 AM
  #305
darkvader's Avatar
I've a CARF Integral all White.
Does anyone has measured the wing and tail incidence, as it come? Values?
Whats your opinion about changing the wing and tail fixed incidence, to variable incidence with Gator adjusters?
Old 07-24-2007 | 07:35 AM
  #306
I found no need to do it.
The plane locks in and flies very nicely as set up at the factory.
Carl
Old 07-24-2007 | 04:34 PM
  #307
BJM
Mine flys great as it comes from the factory.
Billy
Old 07-25-2007 | 07:02 PM
  #308
My Feedback: (7)
Has anyone been flying the Integral on an OS-160 Two-Stroke or an OS-200 (non-FI) engine?
How do the compare on power?
I am trying to put together a budget for this airplane and would like some information.
The F.N.G.
Bret
Old 07-26-2007 | 04:44 PM
  #309
Jas / Andrew
Any chance of pictures of your model inside and out with details of your setup, flying weight etc.......
Is their an electric version of the Comp ARF Integral coming out??????
Did you both fly the stock comp arf model.
Thanks.
Old 07-26-2007 | 08:22 PM
  #310
My Feedback: (7)
The stock version of the Integral can be setup as Electric with parts included in the kit!!!
Very cool!
Old 07-27-2007 | 03:57 AM
  #311
bzrogers,
Thanks for your reply I am aware it can be set-up for electric, but their may be weight issues. I was wondering would a lighter electric version be produced.
Old 07-27-2007 | 10:35 AM
  #312
flylulu737's Avatar
I think you should check ZNline and or Composite ARF web sites.
http://www.composite-arf.com.hk/ar/Product?701000
Click on Electric power Hacker.
It's JPz' Integral, stock airplane with the hacker engine, most popular engine set up in europe !
Well below 5 kg no stress, don't try to reinvent anything, just do like JPZ !
Rgds
Laurent
Old 07-27-2007 | 01:30 PM
  #313
Hey all,
I will post some pics of my pattern plane when I can get some pics. The kits that I got were not special just normal kits that come out of the mold. My integrals that were flown at the Nats weighed in at 10.8 pounds and 10.7. This is with C-50 Comp's, spin 99 speed controls, futaba 9155 on rudder, 9650 on elevator, 9550 on wings and a 10s1p 5000 Extreme. I would bet to say that if you flew with the old 5300's that the plane could come in at about 10 and a quarter pounds.
I will post some more info on the plane when I get home from work.
Thanks for all the congrats I know I was very excited to be on the team with two people that are great friends and heros of mine.
Andrew
Old 07-27-2007 | 02:37 PM
  #314
GREAT FLYING ANDREW!!!
what makes your airplane different from Jasons ,,
his was 11 pounds even
did he have a early version ?
Bryan
Old 07-27-2007 | 02:38 PM
  #315
Hi Andrew,
Congratulations.
Could you comment on the 9550 servos on the wings? I am also interested in trying them out on mine, but some inputs on how well they function in this application would help to finalize the decision.
TIA,
Kevin
Old 07-27-2007 | 03:43 PM
  #316
My Feedback: (45)
Kevin,
The 9550's work great as aileron servos. I've flown them for years. Small and compact. I will say that over the course of a season flying glow you will probably have to change the gears. The metal gears wear quite a bit flying glow. If you are flying electric, you probably wont have any problems,
Archie Stafford
Old 07-27-2007 | 04:02 PM
  #317
Archie,
Thank you for the input, and I will give them a try. Small and compact is the main motivation, plus they are a little lighter at 1.6oz each.
Since I am running glow, I will pay attention to the gears towards later part of the season to see how long they will last - hopefully longer than one season.
Kevin
Old 07-27-2007 | 06:03 PM
  #318
woodie's Avatar
ORIGINAL: flyboy91
Hey all,
Andrew
Andrew, congrats on your placing at the Nats!!!!
I have a quick question on your Integral. Did you retrofit wing or stab adjusters into your planes or just fly factory settings? How about CG?
thanks and congrats again
Don Atwood
Old 07-27-2007 | 10:47 PM
  #319
Bryan,
Thanks, I think the only difference between my kit and Jason's is how thick the paint was put on and his full size servos in the wings. He was running 9156's. I do know that they came at about the same time from the same container.
Don,
As far as wing and stab incidence, I left it how it was. It takes a little bit of mix to get the plane flying knife edge true but other then the pitch to the belly its not bad at all. It also presents very well and seems to not fly with a tail down attitude like my brio did.
Andrew
Old 07-28-2007 | 11:45 PM
  #320
My Feedback: (45)
Kevin,
You'll be able to tell when they start to wear when you will have to start retrimming the ailerons from flight to flight. I got about half a season out of mine, but I tend to fly quite a bit, at least I was then. They do work great though, and changing the gears isnt that hard. Expensive since you have to change the metal gear, but really not that hard to do.
Arch
Old 07-30-2007 | 05:34 PM
  #321
Slideshow new Integral.
http://airtoimedia.nl/web/upload/vdVechten/Integral.wmv
My setup:
Motor = Plettenberg Xtra 30 EVO in the Spinner 82mm!
Prop = Rasa MAG ONE 21x15,5
Controller = Schulze Future 32-55 KA-F3A
Radio = DX-7 Spektrum
Servo = JR 8715 4x
Rx accu = TP 2s-1p 1320 mAh
Emcotec = DPSI micro MPS-RV
Flight accu = FlightPower F3A 10s-1p 5350 mAh (17C-28C)
T/O weight = 4955 gram.
Dick van der Vecht
Holland
Old 07-31-2007 | 01:43 AM
  #322
ram_z's Avatar
Hi friends, nice model!
Old 07-31-2007 | 10:17 AM
  #323
Andrew
Where did you place your CG?
In earlier posts Jason flew the OS200 powered version at 205mm but some on the list said that this was too far aft. I'm going to set mine up using a DZ and would l ike to know if I need the servos in the tail for the best CG.
Colin.
Old 07-31-2007 | 11:23 AM
  #324
Any pictures of Jas & Andrew's electric setup yet? Batteries, servo's, linkages,motor installation, weights etc.....
Would really appreciate it.
Old 07-31-2007 | 02:07 PM
  #325
ram_z's Avatar
Hi Colin
My Integral powered by DZ 1.60 and my elevator servos are in the tail.
After 7 flights I felt that my model is nose heavy so I moved for an 18X10 carbon prop which lighter then APC 18.1X10. Now the CG is better but yet not sure if it is the best CG.
I will check it again this weekend and update here.
Ram
