Black Magic VF3 Build Thread
Old 04-15-2009 | 01:28 PM
  #1126
cdodom's Avatar
Default RE: Black Magic VF3 Build Thread
That is an Awesome Report Arch. I hope to be getting one soon. was there a huge smoke trail like the regular DZ or is it almost gone?
I hope you can Make it to the Andersonville Contest or Prattville contest. so I can play around with the motor. AHHHHH I WANT A CDI!!!!!!!
Chris Odom
Team Black Magic
Team Dragon Fire
CAA
Old 04-15-2009 | 01:42 PM
  #1127
My Feedback: (45)
Very little smoke trail. Wind was blowing today so hard to get a really good account. I'll know more this evening when it is calm. It was definitely less than usual and that was on the normal fuel.
Arch
Old 04-15-2009 | 04:44 PM
  #1128
Arch,
Don't leave out the 19x11. It's my favorite on the 170 CDI.
Old 04-15-2009 | 07:00 PM
  #1129
My Feedback: (12)
Brett,
Does the 19x11 have the huge hub, or is it the same size as the 18.1x11?
Old 04-15-2009 | 10:24 PM
  #1130
Can't say if it's exactly the same size hub as the 18.1x11, but the 19x11 doesn't have the huge hub. It may actually be the 19.1x11, I don't really remember.
Old 04-16-2009 | 06:22 AM
  #1131
My Feedback: (45)
The 19X11 is basically the same size hub as the 18.1X11. The spinner will work with both props without any mods.
I actually didn't think I'd like the 19X11 as I thought it would be too slow. I was wrong. I REALLY like that prop. I played with it last night and so far I think I'm going to love it. I'm going to leave it on there this weekend for the contest.
Arch
Old 04-18-2009 | 12:34 AM
  #1132
handglider's Avatar
My Feedback: (23)
Hey Arch,
Thanks for lending me the 170 bro! Now I've gotta get my very own CDI
Old 04-18-2009 | 03:59 PM
  #1133
AmericanSpectre505's Avatar
Sweet Dude!!!!!!!!!!
Regards,
Bill Holsten
Advantage Hobby & Fliton RC Field Rep./Duralite Batteries/Custom Airframes of America/Dragon Fire Customs/Guardian America
Old 04-18-2009 | 09:47 PM
  #1134
My Feedback: (45)
No problem Dean. Glad the 1.60 is back. Send me the 1.70 whenever you get a chance. I want to get that one converted to CDI also. Flew it in my first contest with it today. Won all 3 rounds we flew. Weather was nasty storms and all here in Temple today, then after lunch it was perfect. Was chasing the needle valve on mine, but finally got it right. The CDI has a different, much smaller sweet spot, but when its right, it is incredible. I'm running the 19X11 and really like the all around feel of the plane. With CDI, my V3 weighs in at 10lbs, 10.5oz. Flies great.
Off to get some sleep,
Arch
Old 05-20-2009 | 06:09 AM
  #1135
My Feedback: (82)
I'm working on my VF3 and need some help with the Rudder Pull Pull Setup. First, what are you guys doing for a horn. Iwas thinking of making my own horn out of 4-40 threaded rod through a hard point. Whats the best?
Chris
Old 05-20-2009 | 06:42 AM
  #1136
My Feedback: (45)
Chris,</p>
The threaded rod works great, but I would use heavier than 4-40.  We are using the Dubro heavy duty setup on mine and it works great.</p>
</p>
Arch</p>
</p>
Old 05-20-2009 | 06:49 AM
  #1137
My Feedback: (82)
Thanks Arch. Ithink it would be simpler for me to just buy the HDDubro setup. Do you mount that rod pretty far back from the rudder hinge line so the piviot point lands on the hinge line?
Old 05-20-2009 | 06:53 AM
  #1138
My Feedback: (45)
We just used the rod.  We don't use the braces that come with it, just standard nuts to save weight, and also we used the small horns.  They have to be drilled out.  </p>
Mine is 8-32 and then the horns are what look to be aileron horns from an older torque rod aileron setup.  The rod is right at the back of the bevel in this setup.  Works great.</p>
Arch</p>
Old 05-20-2009 | 10:17 AM
  #1139
handglider's Avatar
My Feedback: (23)
HI Chris,
Here are a few pics of my install.
Iused 6-32 threaded steel rod and dubro aileron horns. bore the hole as close as you can so the hole in the horn is as close as you can get. We are using 1/2 dowel as a hard point. If your all concerned about getting the hole over thehingeline you can always bend the rod
Another tip is to drill and install the exit guilds after your glass - you won't get a bump orbulge. You will also get a cleaner exit. I've been using DEPS scraps for the exit tubes.
you can also see my retro fitted deps in thesepictures.
<br type="_moz" />
ID:	1202433   Click image for larger version
Old 05-20-2009 | 12:14 PM
  #1140
MHester's Avatar
I started using the dubro 60-91 sized pull pull system and I like it. I think the HD might be overkill, not sure...but it's heavier.</p>
Like Dean said we don't use the stand offs because it's dead weight. Just the threaded portion along with the nuts. Do NOT use all thread from the hardware store, it's too soft and WILL fail.</p>
-Mike</p>
</p>
Old 05-21-2009 | 12:13 PM
  #1141
My Feedback: (17)
Mike,
You also don't want to use stainless steel threaded rod or screws -stainless istoo brittle and it will eventually break. You can buy standard zinc plated 6-32 screws at the hardware store and cut the heads off for a ruddder setup. They seem to be about right except sometimes it's hard to findreally long ones.
John Pavlick
Team Black Magic, Tech-Aero Designs
Old 05-21-2009 | 12:43 PM
  #1142
My Feedback: (82)
Thanks for all the helpful hints guys. It turns out Ihad a HDDubro pull-pull horn in my control horn drawer...Iwill be using the rod and nuts for my horn. Ido need to figure out something to thread onto the ends of it to secure a clevis. Any ideas?
Old 05-21-2009 | 03:23 PM
  #1143
MHester's Avatar
Good question. if it's the HD version it's at least 8-32 if not 10-32 depending on which one. </p>
That's why I use the smaller one with the 6-32 and a goldberg horn end. (the white one). it's enough, and it's lighter. never had one break, and that's saying something on this plane.</p>
-Mike</p>
</p>
Old 05-21-2009 | 03:44 PM
  #1144
Jason Arnold's Avatar
Hi Mike,
What's been happening at Custom airframes over the last 5 months? Been a while since your last update in December...
Cheers
Jason.
Old 05-21-2009 | 06:17 PM
  #1145
Some photos of my VF3,...I did not do the hard stuff like the frame work, sheeting etc.Here are some of the things I've finished so far and now I have to pull the YS170 out of the Partner to get the cowling correct.
Best Regards,
Bill Holsten
Advantage Hobby &amp; Fliton Field Rep/Duaralite Batteries/Custom Airframes of America/Dragon Fire Customs/Guardian America.
ID:	1203265   Click image for larger version
ID:	1203266   Click image for larger version
ID:	1203267   Click image for larger version
ID:	1203268   Click image for larger version
ID:	1203269   Click image for larger version
Old 05-21-2009 | 06:20 PM
  #1146
MHester's Avatar
Slow and steady. Working on planes and new stuff. Keeping kits available. </p>
Right now, trying to get one built for the Nats for me. The VF3 prototype was totalled at Lakeland. So, after building 22 of these 3s, it's about time I had one for myself. That's priority one. Right this minute I don't have anything to fly. THAT ain't gonna work.</p>
There's stuff cooking over here, but I learned my lesson about saying anything too soon. So, I just haven't had anything to say really. Nothing before the nationals in July for certain. And more than likely not then either. But rest assured, I'm not sitting around watching TV over here, I'm busy [8D]</p>
-Mike</p>
</p>
Old 05-21-2009 | 06:21 PM
  #1147
MHester's Avatar
Oh yeah, looks GOOD Bill! You may beat me after all!!!! LOL</p>
</p>
-Mike</p>
</p>
Old 05-21-2009 | 06:53 PM
  #1148
Well Mike,...I had a huge head start,..........thanks. You need to take some time for yourself to get yours done. I know it's a difficult thing when you have to fill orders. You are always welcome to fly mine at the NATS if you need it,...really. I hope to have #2 painted before the NATS and done if I can get my hands on it in time.</p>
You can always fly my secret weapon,..........I'll bring the Partner for you,...LOL!!!</p>
</p>
Best Regards,
Bill Holsten
Advantage Hobby &amp; Fliton Field Rep/Duaralite Batteries/Custom Airframes of America/Dragon Fire Customs/Guardian America</p>
Old 05-21-2009 | 08:34 PM
  #1149
handglider's Avatar
My Feedback: (23)
Looks great Bill !
we need to work on your beverage choices - bud light and diet pepsi - LOL !!!!
Heinekenandmonsterswould be the correct choice
later bud....
<br type="_moz" />
Old 05-22-2009 | 12:07 AM
  #1150
That looks real good the Bill and the mount thing, was it on the money? I looks like it to me. I hope to get mine ready by Andersonville, it may be more of a back up for Chris at NATS. Great job and get some pics up soon.
Larry
