CA Models Pass-Port Build
Old 03-04-2008 | 05:13 AM
toddblose's Avatar
My Feedback: (10)
Default RE: CA Models Pass-Port Build
Please weigh your parts Todd..
I think we are all waiting on this to order.. If this won't make weight with an outrunner and 5350's I will have to choose otherwise..
Chris I will get them on as soon as I can.
Old 03-04-2008 | 07:33 AM
My Feedback: (19)
ORIGINAL: toddblose
Ok so all pic's so far have been of Chip's Pass-Port. Mine just got here today so here it is, the scheme is the same except I have pearl red instead if pink. here is how the plane comes from CA Models
Did you request pearl red or did they change colors ? Looks better than the pink.
Jon
Old 03-04-2008 | 07:55 AM
toddblose's Avatar
My Feedback: (10)
I asked for the red
Old 03-04-2008 | 11:05 PM
toddblose's Avatar
My Feedback: (10)
Today I made and mounted the Hacker firewall. The first thing I do is trace out some blue foam cut it out and use it as the template. You will need to cut a little at a time so you don't get it to small. after you get the template where you need it, trace it out on to what you will be using for the firewall. (I used the 1/8in carbon sandwich panel from CST.) when I get the carbon where I want I will tack it in place with some CA to hold it in place. I then take the motor and get it set then mount it. after all adjustments are made I will glue the firewall in using BVM aeropoxy.
ID:	895197   Click image for larger version
ID:	895198   Click image for larger version
ID:	895199   Click image for larger version
ID:	895200   Click image for larger version
Old 03-04-2008 | 11:16 PM
toddblose's Avatar
My Feedback: (10)
Next I mounted the landing gear and wheel paints. I will start with gluing in the support plates in the wheel paints, this will help keep the wheel paint in place and I also use a small screw to mount the wheelpaint. I then take and drill the holes in the paints where the axel go through. Before putting the wheel on I will set the plane at 0 deg's and put the paints on and drill them for the mounting screw. After that is done I then put the wheel on and put the screw in that holds the paint on. The reason for not putting the wheel on is the paint will set on the wheel opening that is level.
ID:	895213   Click image for larger version
ID:	895214   Click image for larger version
ID:	895215   Click image for larger version
Old 03-05-2008 | 12:29 AM
  #31
patternflyer1's Avatar
Todd,
Looking great.. Keep up the thread.. Very interesting to those of us that want this plane..
Something to mention with your last post, when using ca to tack, I always use foam safe ca, therefore not heating up the fuse causing a bubble.. I'm sure most of you know this, just mentioning in case someone didn't.. Would hate for someone to have an issue..
Awesome plane.. Can't wait to see one fly..
Chris
Old 03-05-2008 | 03:52 PM
  #32
My Feedback: (8)
Here is some pics of the finished rudder servo installation. We used 9650 servos so we could mount it on its side to get rid of the up and down movement as the servo is moving. I just traced the servo and cut it out with a sharp X-acto. Then doubled it on the inside with some 1/8th lite ply. I use MK BB at the servo and a ball link at the surface. Its connected with 072 carbon rod that is glued at each end with med Zap. Do not use kicker on these connections it isn't nearly as strong as when allowed to dry on its own. More pics on the way.
Chip
ID:	895628   Click image for larger version
Old 03-05-2008 | 04:00 PM
  #33
My Feedback: (8)
These are just a couple showing the Hyde Mount and tail ring istallation.
ID:	895635   Click image for larger version
Old 03-05-2008 | 04:26 PM
  #34
MHester's Avatar
oooo I like the carbon facings on the rudder halves [8D]
One note about wood, since that's sorta my area.....LOL
The lighter the wood, the more it's likely to have "defects". The reason is simple, it's rare. Only about 1 out of 100 balsa trees produces contest grade balsa, and when you narrow that down even more to the lightest possible, the selection gets smaller and smaller.
So when I look at that picture with the knot in that rudder, my thought is "who cares"? it makes absolutely no difference, it just doesn't look as good. Doesn't make it bad, or worse, it's just a little unsightly. but again, it's on the inside of a rudder half...which is covered now with carbon....so who cares?
I'd just be glad the wood is light enough to have to pick through it like that! It would be a lot easier to use "pretty" wood for image sake, and produce a heavier and cheaper plane. I don't see the sense in that.
Great looking plane BTW. But I said that last summer
-Mike
Old 03-05-2008 | 05:19 PM
  #35
toddblose's Avatar
My Feedback: (10)
Thanks Mike
Old 03-05-2008 | 05:37 PM
  #36
Yep I agree with Mike
how the wood looks is secondary
light!! is more important
Todd,Chip ,,
that thing looks like a winner
can`t wait to see it fly
Bryan
Old 03-05-2008 | 07:02 PM
  #37
Do I see side force generators on the lower wing tips there?
Old 03-05-2008 | 10:40 PM
  #38
toddblose's Avatar
My Feedback: (10)
Thanks Bryan, Hope to see you a Glen's contest in May.
Yes it is SFG's, they are also an option
Old 03-05-2008 | 10:45 PM
  #39
My Feedback: (8)
-Mike
[/quote]
Thanks Mike, I feel the same way personally about the wood, but I can also understand how others feel and want there stuff to look. My Passport is about done, but I need to go back to Tucson and will not be able to finish it until Fri. It looks like it will be 4950 grams as is which easily makes it under the limit. I have done nothing special to get it there, and can easily drop another ounce or two. Here are a few pics of the elevator servo install and what it looks like all put together. I will be glad to answer any Q's and will post in more detail tomorrow. Enjoy
Chip
ID:	895898   Click image for larger version
ID:	895899   Click image for larger version
ID:	895900   Click image for larger version
ID:	895901   Click image for larger version
ID:	895902   Click image for larger version
Old 03-05-2008 | 10:53 PM
  #40
My Feedback: (8)
I forgot this pic. Elev servo installation.
Chip
Old 03-06-2008 | 09:58 AM
  #41
Chip, a few questions about tha Hyde mount for the Hacker.
Is any web site to view te mount ?
Weight ?
Cost ?
Were can I buy it ?
Thanks.
Old 03-06-2008 | 10:23 AM
  #42
quist's Avatar
My Feedback: (198)
Is it going to be hard to balance with 4 servos in the tail? The Ultracote on the rudder inside looks better.
Old 03-06-2008 | 01:16 PM
  #43
toddblose's Avatar
My Feedback: (10)
Ricardo PM sent
It's not a problem all we will do is move the FlightPower 5350's forward if needed.
Old 03-06-2008 | 01:30 PM
  #44
toddblose's Avatar
My Feedback: (10)
Ok since Chip has shown how we mount the rudder and elevator servos I will show the wing.
After all hinging is done I cut out the covering over the servo cut out and leave extra to fold into the servo bay then shrink it. I use 1/4 x 3/8 spruce for the servo mount so after I cut and fit I glue them into place. After mounting the servo and horn I use some trim monokote to cover the servo
ID:	896217   Click image for larger version
ID:	896218   Click image for larger version
ID:	896219   Click image for larger version
ID:	896220   Click image for larger version
Old 03-06-2008 | 01:41 PM
  #45
toddblose's Avatar
My Feedback: (10)
Here are the weights on my pass-port.
Pass-Port
Fuse with canopy and chin cowl 1190 grams
stab 92 grams ea.
wing 396 grams ea.
rudder 56 grams
set of wheel paints 35 grams
total weight less gear and tubes 2257 grams
I check the weight on everything else and the total weight is 2526 grams.
The weight on my Pass-Port is 10lbs 14oz with FlightPower Evo 5350 5sp X 2. Just remember I am running the Hyde mount and tail ring, one extra servo and a 48in lead for the rudder. So I believe that running the standard rudder and the motor hard mounted will not be a problem.
Here is mine almost done.
ID:	896224   Click image for larger version
ID:	896225   Click image for larger version
ID:	896226   Click image for larger version
Old 03-06-2008 | 06:23 PM
  #46
My Feedback: (45)
Great job Todd. Plane looks great. I wont be at Temple...as I don't get back in the states til the 22nd of April, but I should be at Glen's contest in early May...can't wait to see it in person,
Arch
Old 03-07-2008 | 11:57 PM
  #47
My Feedback: (8)
ORIGINAL: quist
Tony
The first one was rigged almost exactly the same and balance was not a problem. Remember they are mini servos back there at something like 18 grams each, no where near the weight of a standard servo. I think the batteries will end up about an inch from the firewall when using 5300's and up against it with the lighter 4200's. I let you know for sure once I get it flown.
Chip
Old 03-08-2008 | 04:41 AM
  #48
ORIGINAL: toddblose
Pass-Port
stab 92 grams ea.
wing 396 grams ea.
rudder 56 grams
so what's the AUW in grams then?
Old 03-08-2008 | 07:21 AM
  #49
My Feedback: (27)
10lbs 14 oz=4932g
Old 03-08-2008 | 10:34 AM
  #50
apereira's Avatar
Hello,
Is the split rudder a proven concept or will it be tested for the first time?
