RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
the hyper st PRO thread!
Old 11-07-2007 | 03:24 AM
  #126
Default RE: the hyper st PRO thread!
I'm a noob at actualy driving nitro cars in anger but I guess you could put a heavier oil in the center diff so if the front has less traction the front wheels will not spin that uncontrolled. I think the heavier the oil the more the RPM of the front and rear center drive shafts are the same and sort of dictated by the axle with the most grip. Maybe you are still a bit trigger happy on the throttle or the engine has too much torque.
I'm going for a 3,5CC engine.
@j_blaze
I guess I didn't read your post well, so please ignore my previous remark about how I didn't understand how it would work. I thought you were talking about the front diff.
Old 11-07-2007 | 03:58 AM
  #127
nitro _ burner's Avatar
Just a heavier centre oil should fitx that!
Old 11-07-2007 | 07:29 AM
  #128
Hi,
Ive seen a few comments about a battery mod that people have done to their hypers - What is the mod and why is it needed? Pictures would be a great help as I dont have my hyper YET!
Thanks in advance
Old 11-07-2007 | 12:52 PM
  #129
vnmsgt's Avatar
The battery mod is from the hyper 8. People put it on because on the hyper ST has the battery exposed and not in a case.
Old 11-07-2007 | 01:11 PM
  #130
Is this also the case in a Hyper ST pro?
Old 11-07-2007 | 04:32 PM
  #131
yes, it's in both truggies, the hyper 8 box is sealed by a body clip, the hyper 8.5 box is sealed by 3 screws and you can put a bigger 5 AAA hump battery packs, for example, I use in my 8.5 buggy a Team Helotes 2600mAh Battery pack but it only fits in the H8.5 box and not in the H8 one.
Old 11-07-2007 | 08:11 PM
  #132
wrat's Avatar
ORIGINAL: droidswarm
Hi,
Thanks in advance
hello...this is my mod ive done..hope it helps...http://hypercentral.18.forumer.com/i...?showtopic=592
Old 11-07-2007 | 09:21 PM
  #133
vnmsgt's Avatar
Well just ran my new hyper st pro today for the first time since building it and all I can say is WOW!! I can see the difference in buying a car with all the upgrades compared to a rtr. This truggy felt like it was on rails and that is straight out of the box with no tuning or adjustments yet. Just point it to where you want to go and hit the gas and it goes there straight as an arrow! Have to do a little more tuning on the motor since i did not get a chance to run to long tonight due to some minor lighting problems. As far as hitting the jumps, it flies level as a can be and eats up rough sections of the track like you were on a flat surface. I could not believe it. My mantis was all over the place on the bumps but this thing felt like it was cutting through it.
I do have one question or concern:
I need to get it to steer more. I have my settings on my spektrum for the steering turned all the way up to 125% and it does not steer to sharp. With the car off I can turn the wheels with my hand more than the servo is turning them. I know on the steering plate there is 3 different holes for adjusting ackerman but I do not know which hole does what. Right now I have in in the center holes. Where should I put them. Is there also any other adjustment that can make it turn sharper?
Old 11-07-2007 | 09:54 PM
  #134
does it turn more in one side than the other? if yes then re-adjust the servo horn.
Old 11-07-2007 | 10:05 PM
  #135
vnmsgt's Avatar
it seems like it turns more the left than the right but only a very little difference. What do mean my adjusting the servo horn?[] I feel stupid asking that but my mind is blank.
Old 11-07-2007 | 10:31 PM
  #136
take the steering servo horn out, then turn the radio and truck on, make sure the steering servo is on the center position while it's on, also try to put the setting of the steering servo in the radio on default, then put the front wheels in the center and without moving them just screw back the servo horn, then start making adjustments with the EPA in the radio (End Point Adjustment).
I hope I explained myself well, I'm from Mexico and still having trouble with english
Old 11-08-2007 | 07:26 AM
  #137
vnmsgt's Avatar
oh, you mean the servo arm. that is what I call it. The arm that screws onto the servo. I already did what you said. I first put the car on with the horn off and I have my steering trim set at 0 or nuetral (straight ahead.) made sure the wheels were straight and then put the horn on and adjusted from there but I did not have to adjust. It was perfect and the wheels were straight. Any idea on the holes on the steering plate.
Old 11-08-2007 | 10:32 AM
  #138
what servo are you running?
Old 11-08-2007 | 01:41 PM
  #139
revopqrs's Avatar
the hyper turns like mad? maybe try a longer servo horn....
Old 11-08-2007 | 05:54 PM
  #140
vnmsgt's Avatar
I have a jr650 servo on it. I do have a long servo horn it but now that I think about it I do not have the steering arm on the top hole of the horn, I have it I think one up from the bottom so if I put it on the top hole it would turn the wheels more even with the servo turning the same amount! DUH![:@] I will have to try that. Thanks for the idea. Any other ideas in case does not work which I think it will.
I was wondering why it did not turn like I though when all the mags said it was like a buggy. It did feel like a buggy driving it except for the steering.
Old 11-08-2007 | 10:22 PM
  #141
vnmsgt's Avatar
Well I moved the arm up to the highest hole on the servo horn and the wheels do turn more than they did before but I did not get a chance to drive it yet. Does anyone still know anything about he 3 adjustment holes on the steering plate and which hole to put it the steering arms in? I have them set in the middle hole for now.
Old 11-09-2007 | 04:27 AM
  #142
wrat's Avatar
[quote]ORIGINAL: vnmsgt
that will be it mate..it will work..put it on the top hole..it will give you the max steering..then set ya epa so it stops just before..canrt go wrong
Old 11-09-2007 | 09:59 AM
  #143
supertib's Avatar
ORIGINAL: vnmsgt
glad to hear you like the Hyper ST Pro........... Untill someone owns and drives a top rank truggy they have no idea what to compare too... the cheaper truggies honestly dont hold a candle to the quality name brand units..... and untill someone drives both they will have no idea of what they are missing....
Old 11-09-2007 | 12:38 PM
  #144
blackrain's Avatar
that jr 650 isnt strong enough you need a servo with at least 200 oz or more of torque. the servo cam may be needed to tighten down more as well
Old 11-09-2007 | 07:27 PM
  #145
My summary of 2 months of ownership.
+It's strong, only broken a few parts
+It is fairly easy to work on
+Diffs don't leak
+Smooth over jumps
+handles well with some tweaking
+it looks good
-stripped a rear diff, no idea how
-exhaust a little exposed, my $100 Nosram pipe has some nasty dents and dings in it
-Stock battery holder is rubbish, was not easy converting to the better Hyper 8 battery box (Stoopid Hobao)
-Bodies a little thin, just ordered my 3rd after cracking the orginal 2 (I do crash a lot though)
-had some oversteer issues that took a while to resolve.
Still a good truggy, better than my HB Lightning Pro R, probably in the same top group as the Mugen MBX5 Prospect and the Hong Nor X1CRT Pro.
Old 11-09-2007 | 07:30 PM
  #146
what parts have you broken?
Old 11-10-2007 | 10:25 AM
  #147
jaywax's Avatar
ORIGINAL: Zonk
+Diffs don't leak
+Smooth over jumps
+it looks good
I noticed the same thing about my diffs. I went to check the fluids and there was no leakage at all. All my previous diffs leaked a little, but not the Hyper.
I noticed that I had a too much play in my rear diff, so I added a extra shim (gear side).
I have no problem with the battery box. The zip ties work fine.
Old 11-10-2007 | 05:15 PM
  #148
revopqrs's Avatar
the body is a little thin? for real dude? that damn thing is thicker than prolines or jconcepts!! its a freakin tank of a lid... weighs a ton even. i doubt a serious racer would even run it....
Old 11-10-2007 | 06:22 PM
  #149
Coopz's Avatar
Maybe its so thick it has no flex and cracks easily? Zonk might be refering to that.
Old 11-10-2007 | 09:38 PM
  #150
vnmsgt's Avatar
That body is as thick as a proline but will melt as easily as a thin one. Melted mine right onto the pipe my first run. I usually put heat shield on my bodies but ran out. Should have waited.
