the hyper st PRO thread!
#1501
NJ
ORIGINAL: McGivor
hey i like the 8T too but you dont see me ravin on about it. i thought this was the hyper st pro thread........... not the RC8T thread! if you guys like raving about it so much why don't you go post in there?
#1502
ORIGINAL: McGivor
#1504
hey lads..havnt been in here for a while but id thought id say hello..still running my hyper st pro..upgraded to bbshocks and still giving the sts d30m a bash...man this motor just keeps going..32+lires thru it now and it still goes bezurk...
just bought a hyper mini st rthat im going to do a brushless conversion on..will keep up to date with that...any how , later
#1505
SC
hi im looking for a kit for racing and will be buying around christmas time. I was wondering hw these ktis do racing. I heard its heavy but how does it compare to the rc9t, mugens, jammins, and losi's. Im would be coming from a thunder tiger st1 rtr is this going to be a big diff then the st1 rtr for racing. The kitsi have in mind are the rc8t, caster k8t, and hb d8t(still in making), and gs xut team pro kit. By the time i by s there gong to be a new one out of the hobao?
#1507
SC
400 to 450. I have found the hobao for 350 at nitrohouse. But i so far have 4 kits in mind im kind of iffy on the hobao. I like the caster k8t, hotbodies d8t (still in making), rc8t(if price goes down), and gs xut advanced pro team kit.
#1508
NJ
For the money I would either go Hyper ST Pro or the Caster K8t if I were to buy today. If you can afford the RC8t I would go that route as I have only heard good things but haven't seen one at any of the 3 tracks I race at. Hotbodies D8t, well who know when it will be out and will it be good? Can't say. I am not a fan of the GS.
If you do look at the RC8t for the price also look at the X2. If you aren't and those two are way over your price range this disregard
#1509
SC
ok thanks, why are you not a fan of the gs? And between the caster or hobao which is better? And if i can afford the rc8t i will get it
#1510
NJ
ORIGINAL: st1_racer
Part support for GS in my area is not easy. I haven't driven the Caster or even seen one in person, I can only go by whay I have seen on the boards here and the price. I have the Hyper ST Pro and it is built like a tank. I have one race year on it and the only thing I have flat out broke was one of the rear hub carriers landing over a massive jump. Over here on the east coast it mostly a Kyosho ST-RR's and Losi 8ight-T's and I fair very well against them at the track.
#1511
SC
Is there going to be a new hyper st out by christmas or in production, the motor i will be usng is a stock rtr ttr .28 engine. Do i use those motor mounts with the engine or the ones that come on the kt. So if i could get parts for gs should i consider it, i have the cl-1? Is thi a big step up from a rtr ttr st-1?
#1512
NJ
I honestly can't give you any direction on the GS cause NOBODY races them here. Not even any mention of them here in the NorthEast. U should be able to use the motor mount in the kit as it has multiple positions for different configs and sizes.
#1514
NJ
It might be heavy but I still place in the top 3 at every race (against X1, ST-RR, Losi 8ight-T, and lightnings) I have been too. It floats in the air and is easy to control. I can clear this triple on one of the tracks that I race at that most cannot. So maybe it's the driver maybe its the truggy. All in all I like the Hyper ST pro. The only other truggy that I would consider getting at this point is the ST-rr (which is rediculously priced) and the X2. But I might be getting out of the truggy class all together.
I know somebody on here loves to say the Hyper sucks on a Supercross style track and while that MAY be true I don't race on that kind of course here so its fine for what I need it for.
#1516
NJ
Sent you a PM. But I am moving to all electric/brushless and have a 1/8 scale buggy that I am converting. Don't want the expense of dealing with 3 classes for Lipo batteries, plus conversions. I would like to covert the Hyper to Brushless, but it would be costly and I don't think I want to dish out 600 Plus at least to convert it to electric.
#1518
NJ
ORIGINAL: cold_reboot
Caster has a factory electric 1/8th buggy available and an Elec Truggy in development =)
#1520
NJ
Does anybody know if the Hyper ST Pro platform or chassis is layed out the same as the Hyper 8 or 7. Or even the Ofna 9.5? I am thinking of converting the Hyper ST Pro to brushless but need to get a motor mount and novak makes it for those buggies. So I don't want to reinvent the wheel and if I can just use that motor mount I am good.
Hyper 8:
http://www.teamnovak.com/download/ot...emplate%20.pdf
Hyper 7:
I am thinking the hyper 8 but wasn't sure.
Hyper 8:
Hyper 7:
#1521
do those 4 holes mount on the exisitng motor mount holes? if so neither will fit, h8 will be too wide apart in the drection of the slots, and h7 to far apart 90 degrees to the slots. if ya' catch my drift? i had to elongate the existing slots to fit h8 mounts.
#1522
NJ
Yes that is the idea that the outer holes would match up to the motor mount holes on the chassis on the Hyper ST pro. So your saying nay! Wrong hole patterns for both. So neither would work and the Hyper ST Pro chassis isn't built like the 8 or 7 series buggies.
#1525
sounds like a plan.personally quite fond of mods like that... for example i am currently holding a mach .28 with a prop on it, and a nikko touring car... this ought to be a good one
