- How to cut EPP?
- Anyone building Komet 163
- Next step up in wings
- Alfa FW-190
- Lets see your homemade planes!!!
- Scorpio Manta
- Mold - Pour Foam
- Great Planes "Super" Slinger
- Hitec Sky Scooter Wing Fill for Speed
- Sturdy board wings.
- Extra 260
- rocket boosted zagi
- Decals on GWS Foamies
- Alfa Mustang Factory Upgrade
- Okay wing pilots, lets see some videos!
- Foamie Skybolt 30" Bipe
- Corsair help
- Depron vs. EPP
- Hobby Lobby distributors?
- EPP Foam Question
- building with foam
- Where to get EPP foam
- Covering a Flying Wing
- i need pinion gear for himax motor
- Help! I need Dow Blucor in WA State.
- JUNK PLANES
- shock-flyer CG?
- C.G. for flat plate foam wings
- fan fold Piper Cherokee
- what can i use to cut this foam?? (pic)
- Great Planes slinger is toooo cool.
- Help I'm a Virgin Rookie and need help
- Prop size for a flying wing
- Zagi XS/Motor/ESC Combination
- CNC foam cutting machine. WHAT DO YOU THINK???
- New Review: GWS Tiger Moth 400
- Foam Safe CA?
- Super Terry meets ThunderPower
- Favorite brushless motor for foam wing
- Razor RZ2500 brushless on a foam wing?
- Hinge tape
- Multiplex Easy Star
- Foamy recommendation for EDF-50's
- Posts
- Formosa Side Thrust Help
- Alpha Corsair Cooling
- Battery location on zagi
- ZAGI XS on Lipoly Modifications
- Anyone tried an Axi in a Zagi?
- Astro 020 for ZAGI XS doesn't need a sleeve to fit!
- S&B TA152 Pix
- Mini Bird of Prey powered by Razor RZ2500
- Death of the Bird(of Pray)
- Foamies RULE!!
- WalMart Plane Flies
- Li-Po for Zagi?
- need help with a foamy
- Newb, HELP
- 1rst flight of my Slinger/ wingtip help
- Is it new or old
- Bird-of-Pray By Edgerc
- Second attempt at a fan fold plane
- astro 010 trouble
- Astro flight brushless 010 for wattage f-22??
- TBM extra 260 3D
- GWS corsiar scale fun mods
- Funtech Sky Scooter Pro 2 Landing Gear
- Help! My hot wire transformer keeps frying
- Looking to get a EPP Eagle ??? about li-poly
- Viper Twin Servos
- Looking for spray paint for depron
- CG for Wattage P-51
- Combat Wings XE2 setup
- Manufacturer
- PCW wont climb
- thin wing design
- Any one have plans for a zagi style wing?
- Troubles with zagi's 400 pusher motor :(
- Brushless for shockflier
- Foam P-38
- What Motor to make this fly?-Pics inside-
- has anyone converted the AIR STREAMX
- slinger and firebat
- Lego airplanes
- OK wing fliers, I need some advice.
- Seaplane
- Twin Viper and Receiver
- Zagi XS/Cobalt 400
- What is the best small motor for foamies
- Any pictures of your home built foamies out there?
- Glue for foam
- battery times twinjet
- Li-po
- Foamie as a trainer
- mini piper props.......
- bulding
- slow stick
- Zagi 400x, XS, or Tazz?
- My New Foamy VTO...
- EdgeRC Bird of Prey
- Brush less for the Scramblur 20" wing?
- graupner mini piper battery...
- To Break or Not to Break
- Stock Shock Flyer Setup?
- EPP foam filler Help
- can elmers wood glue be used...
- charging Nimh.with a small peak nicad charger
- Zagi XS Video
- Ikarus Shock Flyer in Stock Anywhere?
- trimming a wing
- Gear for 6.6 : 1
- modification to the mini piper...
- Projeti
- please help.....can anyone suggest a product
- Pull Pull Set up
- Plans for Foamies
- cracked foam
- My Zagi is Grounded
- Grr...Astro 020 Twitching
- Upgrading Zagi 400X motor
- 2 sided tape or glue for the Easy Star tail?
- graupner mini piper...
- the walmart..skyrider or sky raider......
- CLiC mini wing
- Seeking novice/trainer wing+tail design suggestions-Newby
- Ripmax Alienator! Electric or Nitro?
- BALSA PLANS TO FOAM WORKS?
- Easy Star
- Questions for a sctratch built foam flying wing
- Anybody seen this in Ebay?Lodestar 79" R/C RC Sailplane Glider
- Anybody Fly Accipiter Badius? Video/questions/setup/parts/mods
- i was gonna buy the ...
- can anyone suggest the best .....
- Zagi XS won't fly
- zagi turned to rocket : new pic
- adhesion of the foam
- slow/park flyer question
- C/G point for a delta?
- My first foamie pix
- Sky Scooter Pro 2???
- New Review: GWS Stearman PT-17
- New Review: Watt Age HyperWing - EP
- Can EPP foam be covered with heat-shrink covering?
- Superflea
- Trainer / Newbie 3D Foam
- 3M Spray Adhesive for Styrofoam (6070)
- zaggi with motor pod -prop pitch
- The dogfighters
- edf epp plane?
- FS P40 Engine Swap
- Lipo Battery setup for astro 020 or aveox 4 turn 8 cell
- NEW REVIEW: Alfa Models F4U-1 Corsair
- Flight characteristics and dimension help
- good paint for a fan fold plane
- will this work?
- Krylon "Fusion" paint
- A good Cheep power sorce for foam cutting
- Coloring a foamie all black
- Fan Fold Or Depron
- Sureflite
- Control throws for Lazy Bee
- Scaled up Zagi for Turbo 600
- foamie trainer or top wing plans who has em
- blue foam
- 45" or bigger foamie plans
- Potensky "PAF"
- Wally World Foamie
- Beaver Float Project
- radio/servo setup
- Australian EPP Foam Supplier
- LIPOLY FOR ZAGI XS???!!!??!!!!!
- foamies
- EPP sheets found
- Zagi XS maiden flight
- Projeti or PicoJet? Advice needed!!
- folding prop on wing
- Increase Voltage for More Power?
- trick 800
- Fan Fold question
- delta wing and prop (stealth sport)
- My Latest Foamy...
- Finishing Wingtips
- zag1 400 motor tray
- First attempt at a fan fold plane
- First electric plane
- Refinish Formosa
- where to find poly tape
- zagi tape
- Bulk Depron Order going in... Get in on it for Cheep!
- Poly tape vs Duct tape
- love that noise
- ff 40" ultimate bipe
- Flat carbon fiber source
- help please with multiplex easystar
- Battery comparison
- Zagi Battery lifespan
- Combatwings UK - WEBSITE
- Hyperwing mods/tips?
- XE2 Motor Selection
- Mega 16/15/4 ele-bee
- The IMA Twin Otter - Give me your opinion
- Carbon Fiber
- Robbe Airliner info
- Say Hello to my Lil Friend...!
- Finishing foam
- Foam fuselege assembly
- Foamie Brushless-NiMh Recommendation?
- Zagi 400X Battery replacement
- EZ fix
- GWS P51 Mustang EPS300C
- electric pbf
- Zagi question
- New Review: Fan-Tastic Models AT-6 Texan - EP
- NSP Trick 800 building advise?
- Help!! Foam in the UK?
- Scotch transparent duct tape
- HELP! Which li-poly's work best on the Zagi XS????
- Flying wing shootout
- Micro Receivers
- Foam Adhesive (MPX TwinJet question)
- I Love This Hobby!! Brushless Projeti Rocks! Resurrecting the Projeti!
- I NEED YOUR HELP
- Brushless for a Wing/Unicorn upgrade??
- what li-poly is good for the Zagi XS???
- Anyone seen any Zagi XS videos yet???
- Flying a wing in the front yard
- HELP!!!! Fan Fold Flier and GWS 350 or 400
- GWS A-10 hopup?
- Is normal Elmers good for EPP? Is Elmer same as 'white glue'?
- Zagi XS Root Uneven??
- Re skined a EL Bee (Windrider)
- fold foam
- fan fold foam
- Pocket Combat Wing Edge R/C
- Kavan WWI ARF Thoughts?
- Windrider Ele Bee Construction
- Pink foam vs. white polystyrene
- SR Hobbies
- 3DX "Fat Boy"
- Sky Scooter 2 3DX mods
- Plane for Sky Scooter 2 parts
- Razor wing foamie
- 30" Ultimate
- GWS B-2 Bomber
- Foam F4B-4 - I can't believe this stuff!
- Unicorn Wings 48" Brushless Photodocumentary
- Kontronik Fun 400-23
- Fan-Fold or Pink Foam Sloper?
- Alfa Models F4U-1 Corsair ARF
- Depron 6oz plane
