View Full Version : Losi Monster Trucks
- LST with a Cen Genesis .46 Clutch problem!
- First Body Attempt
- servo amps draw
- broken clutch springs
- I got my LST today
- LST Wont start!
- Savage roll bar for the LST
- 30%...To shim or not to shim, that is the question!
- Anyone got these springs?
- how to make shock socks
- Collari 32 install guide?
- Looks week? A-Arms
- New mach .26 clutch problems.
- gearing recommendations for .28
- Mini LST?
- What parts to lighten things up?
- Losi LST with some guts!!!!
- Aluminum Clutch Shoe Washers?
- Different Lst Setups (Tell us your secrets)???
- Optional Lst Gears
- Slipper nut size please!
- thoughts on Sirio .30?
- Justed Order My LST
- K&N Air Filters
- WERKS .32??? Supercharged???
- LST MUST HAVES
- Carbon Fiber Chassis
- New Hi Perf Brake
- Diff and trans questions
- REX PIPE
- About how many volts...
- removing flywheel
- losi lst pre painted body
- remember me?
- aluminum clutch shoe life
- Removing E-Clips.
- How long does 5-cell battery pack last?
- novarossi rotostart conversion to Losi LST rotostart
- New lst break in engine
- Anybody got these?
- Where to find serial number on LST
- How many amps?
- L. Collari .32 Monster Truck Engine w/ Roto-start NEW
- help my servos twiches and goes crasy
- lookin to purchase LST
- Slipper: How tight for wheelies?
- Air Bubbles
- i got some shock sleeves but...
- Anyone with tuned pipe
- Upgraded dropin motor for LST
- Its that time of the Year...Jumping!!!
- LST vidz?
- Ahhh when stupid little parts break...
- Brake pads
- LST or Savage limited edition?
- I just got bit, Racer bug!
- LST roto-start.
- servo help
- throttle jumping
- Factory radio settings...
- Engine Support Braces?
- Mach .26 Rear Bearing Outer Race Spins Against Crankcase
- LST Runs Erratically
- Endplay in Spur Gears
- LST break in Trouble
- casualties of war
- Axel nuts keep coming off
- Radio settings for the track
- Anybody else have this problem w/ the LST?
- Racers and track goers, to bumper or not to bumper?
- Why my engine wouldn't start.
- Engine won't start please help
- Proud new dad of 16609, stripped hex screw
- Maximizer Diff Cups.
- Help choose some engine
- dynamite linkage
- Sharing parts!!!
- 3 Wheels
- Broken con-rod warning.
- sirio 30 in a lst!!!
- Tuning LST engine, almost there...
- Lst or Revo?(for price)
- clutch springs
- NOOOOOOOOOOOOO!
- Piggyback shocks for LST
- Roll Cage/Bar?
- Losi LST Contest
- Left Rear Axle Damage AGAIN!
- IS THERE A WAY TO KEEP IT STRAIGHT IN THE AIR
- Hi Pefomronace Brake Question
- I bought my aluminum diff housings, but i'm afraid to install them...
- Airleaks with SH .28?
- Advanced Maintenance
- B3534 Gasket
- Broken Crankshaft on Mach 26
- What type of air cleaner?
- ER UH dust sucks, sucks dust, this just sucks!
- Break in.
- Gear mesh and wobble question.
- Clutch Maybe?
- LOSI LST
- Looking for long-term update on Hot Racing alu diff retainer rings
- Engine Maintenance (M26)
- Got the LST! Just Amazing!
- About to buy a Venom Temp/Failsafe anyone got any ideas good or bad....
- This thing rules!
- Brand new LST WON'T MOVE!
- No more Buggies i wanna TRUCK!!!!
- do stock LST tires fit?
- mounting a flat pack under the truck.
- tini gear mesh pic
- HELP!!!
- roto start removal
- 2-speed Fix.
- Two Questions
- LST vs XLB vx MAMMOTH ST for big air??
- Got all my lst hop-ups.
- little help needed
- Washer in Diff?
- Mach 26 replacement
- FM clash with AM
- Please help! asap!
- Hi/Lo Gearing
- Which Tyres for Racing
- Trinity monster nitro Fuel
- Roller or used LST...
- sirio.30
- LST on short track
- Problems w/ Losi LST Mach 26 Engine Startup
- Have you ever...?
- problems with my wasp (orion .28)
- Clutch for lst
- Steering Woes
- LST Recall
- My new LST. Grins and Woes.
- Do I need foam inserts for these proline wheels and tires?
- Do I need 1 or 2 servo savers (killerhobbies) for the lst?
- Is it ok to break in the mach 26 lst motor with 35% nitro fuel?
- Aftermarket Engines
- Kimbrough Servo-Saver Mod
- trade for aircraft stuff
- What pipe are you Sirio .30 and Collari .32 guys running?
- Best removal of tires from rims
- 'bout had it
- sportswerk carb
- LST stock servos need to be replaced?
- Lovin' the CP 2.0, hatin' the HPI rims.
- know your truck
- Damn, this SUCKS.
- sigh...when will the bling end???
- Just bought LST and have $500 for hopups. Which to buy and where?
- MUST-KNOW THINGS for owners of a Team LOSI LST
- Air Filter Broke
- engine
- Who has got their Werks 32 runnin yet?
- Glow plug fall off
- Shifting problem with upgraded Pinion gears
- What makes the LST so much better than a revo or savage?
- LST Transmiter setup, NEED HELP PLEASE..........
- Bolt on Wing
- Can't find forward only kit.
- Steering servo
- Forward only tranny gear ratio?
- Customer Service
- LST must-have optional parts or hop-ups?
- Rough Coasting
- Collari .32 or Nova Rossi .28?
- LST...Basher.? Racer.???
- Hate to start a new thread but HELP!!!!!
- Hesitation with silver clutch springs
- con rod issue
- Finally getting an LST
- RB Mods or EB Mods
- AGAIN TIRES!
- HELP! Losi JRX-T parts and manuals needed!
- Mach 26 piston and sleeve upgrade to 28?
- LOVE HATE RELATIONSHIP
- Broken Axle
- Thinking of trading my REVO in for LST...
- Need help,a bit undecided
- LST Runnin
- Oww!
- wheels
- LST not running right any help
- Collari 32 Install
- Pimped Up LST Pics
- LST Best Hopups
- Venom Racing
- Engine stalling
- Silver spring Rate
- hump pack mounting.
- What kind of glow plugs?
- sway bar
- Roto Start.
- motor recommendations
- Question about Tops
- Forward only kit installation...
- Shifting Problem
- About ready to use the mach as a paper weight
- Oh smack.........it's here! Bwwwwaaahhaaaa
- Storm .25mt carb
- Temp problem
- Threaded Shock Ajusters
- Proline Crime Fighter MT Tires
- What are you guys doing for servo savers (hitech servos)
- 23 mm adapter & wheel play
- Forward / Reverse problems
- how many tanks to a full charge?
- Heeeres Your Sign....
- one wqy bearing
- lst diff gears
- Tuneing queston
- Clutch Bell noise?
- A Non Synth Radio
- Monster Truxk Stand
- Low profile wheel nuts
- LST vs. Revo
- Jumping Basics
- always something
- LST Exhaust Header
- Dynamite Linkage
- SKP's -- what rims?
- KILLER HOBBIES QUESTION
- ???? about Mach/Sportwerks carb
- MACH .26 V2?
- Wheel axle Upgrade - Need HELP
- What's New
- Best Spring and Clutch combination?
- OK GUYS I PROMISE, LAST HELP ? FOR NOW
- enya glow plugs
- four-stroke for lst?
- OS .30 engine
- what are some good LST chassis
- SORRY BUT AGAIN I ASK FOR HELP
- Tuneing when the weather is hot and humid?
- Getting the Collari .32, have a couple questions
- Trouble with idle when changing high to low
- Z590M Steering servo lock up?
- How many of you have no engine trouble?
- What's the trick to geting to the LSN
- at my lhs i notice that the mammoth and the lst..
- LST OWNERS HELP. PLEASE HELP ME
- New version of LST coming out soon?
- nasty glitch
- clutch problems
- Super-Charger
- 5-10mins to restart
- part# help......
- Any BRT1 gluing tips?
- Stalls at full throttle
