- Buying LST2 for $579?
- Putting the Losi Spin Start On An Axial.32?
- more tuning help please
- BREAKIN' SOMETHING IS A BAD THING???
- Anybody Run/Has Run Zombie Maxx Tires on an LST?
- Anybody else run-or-going to be running an Axial.32?
- LRP Z28R spec2 ?? and my 1st video
- f/r bumper options
- Engine brace options?????
- LST2 vs REVO???
- MOVED: important info for would be warhead owners
- sf3.2????
- Loctite?
- lst2 body
- Revo 3.3
- lst2 on the way
- Adaptors for the 40 series tires???
- Are aluminum parts worth the price???
- LST2 fuel filter leaking?
- LST2 Manual Wrong??
- BAD servo's
- Shock Adjustment
- Reciever Pack replacements
- First Gas truck
- Forward only W/O Low Gear
- Tuning help
- Engine warm up?
- lst jumping out of gear
- My new LST2 and some questions to boot...
- Stock spring rate LTS2?
- DIFF SHRED LST2
- The LST2
- Front Wheel Drive Only
- One piece Header?
- LST transmission
- Semi-new fuel filter mod
- is anybody into onroad cars?
- Worst Saturday ever...Hard lessons learned
- Replaced shift servo saver with Kimborough heavy duty.
- new era roll bar
- Stock Receiver Pack Runtime
- Servo chatter in center position.
- Engine Temp and Wheelies
- Have a question about brakes...
- few questions on the lst2
- First try at a body/ other pics of my LST
- LST2, should I buy it?
- manifold polished
- LST2 best price
- will not prime
- Slipper clutch assembly
- mach 26-427 ?
- performance update kit nessacery
- Billet Rims for LST-2
- LST video from Spain ;)
- Looking for RC Truck BOOKS
- Team Orion adjustable clutch
- bigger badder engine
- REVERSE ONLY...
- Help with Integy Parts
- LST 2 loose wheel/hub assemblies
- Lst2 came with locktight on grub screws
- diff oils
- Ring & Pinion help LST 1
- losi lst2 question
- spur gear need help
- lois lst, lst2
- 2dmaxlst ?
- Need some troubleshooting help
- e
- Reasons not to buy the LST2...
- LST vs. Tonka Dump Truck
- Bashers looking for bashers
- What is better for racing? LST2 Or REVO?
- few questions tunning ...
- Best LST aftermarket engine?
- Need some info on the locktite'ing !
- Nova Head for Surefire.32?
- unhappy with my new lst2
- LST2 Brake Help
- Wing
- WARPED
- No reverse with low range?
- sf3.2tuning ?
- Diff question
- LST2 Why?
- is there a 3 speed availible
- completely submerged my truck in water
- To go Wabash.. or not to go Wabash
- Roto Start?!?!?!?!?!?!?!- please reply fast!
- happy with my new lst2
- Need a STRONG servo saver
- What the..?!?!
- AXIAL 32 vs Sure fire 32
- Just bought an LST....
- foc ??
- A good idea/what it means to race
- new LST2 prob.
- steering problem
- OS30 in new LST2 - need some help!
- Reccomend me an LST hopup
- Roll cage?
- recever problems
- Help stripped screws! any options
- POLISHING
- An engine.. to race with.
- receaver pack life
- Applying brake leads to throttle opening right up
- Mach .26 Life Expectancy?
- smart temp?
- Collari.32 vs Surefire .32?
- Need some quick help on spindles!!
- twin receaver packs
- JR XS3 Battery and Charger
- LST2 Stock Engine?
- Update kit and tires..?
- Racing: Day vs. Night
- Upgrading LST2 Steering/Servos/and others
- Shock/Oil Combo's
- Mach 427 Glow Plug?
- aaqarghhh Help! LST doomed!
- Pin breakage and update...
- Considering buying a LST2
- good deal or bad deal?
- tanny
- Glow plug Help
- bent???
- BRAKES
- Lst2 some money to spend
- glow plugs onlst 1
- I'm just about done
- Is it goodbye BRT 1's
- New LST2 Top speed 7mph!
- LST2 wheels keep coming off...
- How old is everyone here?
- Pipe Mount
- Mugen Clutch?
- Once and for all...stock plug in the LST2
- LST2 Axle Shim Size
- spindle & carrier upgrades
- How you guys like your LST-2?
- Threaded Shock Bodies + Existing Caps = No Love
- How to cut weight on LST-2
- LST Wheel tire finder/how-to
- who makes the R3 plugs ?
- LST2 Secondary GC rubbing?
- LST2 axles on regular LST!
- 20mm hexs
- how does the tranny work on the LST
- MOAB XL
- LST Bashing Tire/Wheels
- My Entire LST-2 Setup with Pic's
- MOVED: This will Blow the Doors off the Revo
- mach 26 compression
- LST2 Steering Servos
- mach .28
- Reinforce Body
- Building New shocks
- Brake setup
- Recommendation on glow plugs?
- LST2 compatibility???
- Screw size, or part # please..
- LST2 production number?
- Glow plug ???
- SF .32
- RPM A arms
- LST2 Shocks
- 23mm Heavy Duty Hex Adapters Question?
- Help resetting my forward/reverse servo
- haha...12 times running my LST and not yet have I....
- engine ???
- LST offset wheels
- LST runs GREAT!! But...
- RCU's Review of the Team Losi Mini LST Truck now online!
- Sending an engine to EB mods...
- Properly setting up your toe makes a HUGE difference in handling!
- Clothes hangers for wheel hex pins?
- servo sticking
- fuel for breakin
- LST 2 wont start
- Causes of Glitching???
- Please Stop Feeding The Trolls and Don't Be One Either
- Did I miss anything
- wheels and tires
- What engine for lst?
- new lid
- reciever antena
- run time
- Best Ambient Temp to Break in Engine
- My clutch after just 1 gallon or so
- LST2 vs. REVO??
- Love my LHS!
- Engine Options for LST-2
- Having issues with the brakes on my LST.
- Ahh man! Damn dog!
- Issue a newbie didn't think about
- racing tire combos ???
- LST2 HELP PLEASE
- What are..?
- Phase 1 : Complete
- Werks Collari
- LRP .28
- Higher nitro %=cooler running?
- Power Hungry 2
- LST2 secondary gear cover.
- mac 427 engine
- Wheelie Bars
- Thought I was getting a Z590M servo with my LST2
- Shims for PL 23mm hexes..
- King Pin racing tires
- Two Thumbs Up for Team Losi
- Power Hungry
- how long would you wait?? yeah you!
- RPM with Lunsford Camber arm gap width
- How long will your LST 2 idle?
- Nasty Sputtering at High Speeds
- LST-2
- RPM arms and LST2
- Which Monster Truck
- Viscous diffs and other basic mods?
- Spur safe to run with? (Photos enclosed may disturb)
- Servo savers
- Nitro to Gasoline/Petrol conversion of LST
- racing report
- My LST 2 alignment off
- Holy *****: My LST-2 Just went BACK IN TIME
- bashing video
- aftermarket parts
- LST-2 Pull vs Roto Start
- MGT VS LOSI
- engine low compresion
- LST2 ATX Tires
- Novarossi .28 Engine.
- WHATS WRONG?
- Starts then dies
- Just got an lst2
- Mach 28 - Whats the latest
- Looking to make my LST race ready..
- What clutch will work?
- clutch problems
- LST shock shafts
- LITTLE HELP ... PLEASE
- WHICH FUEL
- One Way Bearing (Mach 427)
- First race this weekend, need some pointers
- got my lst today...wont run H-E-L-P!
- New LST2 Owners Please Let me Know How U Like it!
- Minor Lst2 throttle problem
- Help with Losi threaded shock bodys
- LST2 Wheels
