PDA
View Full Version : Losi Monster Trucks
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. help tuning
  2. Muggy shock weight
  3. Two speed problems
  4. Where?
  5. Engine Tuning....Almost there.....
  6. Buying A Used LST2
  7. Aftershock problems
  8. Aftershock won't start
  9. Rims for LRP .28 Powered LST
  10. faster ?
  11. Where can I get exaust coupler springs?
  12. O.S. VG .30 or LRP Spec3
  13. How do I get more?
  14. Muggy shock set up
  15. Who hates flipping Revos at the track!?!
  16. Aftershock shocks and LST2 shocks
  17. Brushless Raminator? (LST/Aftershock/Mega Baja)
  18. SPUR GEAR SPRING WASHER!!
  19. LST2 clutch bell bearings
  20. Savage XL V.s. LST2
  21. LST-1 AXLE size?
  22. BEST CLUTCH FOR LST!!!!!
  23. Breaking in New Aftershock
  24. SLOW START LST
  25. LST2 abuse
  26. Lrp Spec 3 Z28R or the pico 28 p3
  27. Pull/Spin start problems
  28. xcelorin 7500 quit working?
  29. I need input on the LST2!!
  30. Bashing the 8ight-T
  31. gear issues..
  32. Good muggy clutch setup
  33. Beginner Truck
  34. Any Canadian Shops?
  35. Any one have a link to or a part number for the top side LST2 motor mount screws?
  36. CLUTCH BELL
  37. LST2 tires question
  38. LST2 with Savage xl tires
  39. LST2 Upgrade kit...ne1 used?
  40. NEED HELP SETTING UP LOSI XCELORIN?
  41. How long to charge?
  42. Muggy one piece motor mount problem..
  43. Lrp spec 3 or dynamite .28 platinum
  44. Post Custom Bodies Here!
  45. Aftershock Can't Keep a Tune
  46. whatmotor to make aftershock brushless???
  47. another bash vid (bigger jumps)
  48. sick bash vid
  49. Byron's Vs Trinity????
  50. Whisping noise in aftershock
  51. Muggy Diff's
  52. MOVED: look here
  53. Engine wont stay running
  54. PROBLEMS WITH SPUR GEARS!!!
  55. Aftershock 17mm hexes?
  56. How to put a clutch shoe on
  57. this cant be good!
  58. Aftershock takes gold!
  59. LST2 ONEWAY BEARING PROBS
  60. Engine cleaning
  61. lst 2 Probs
  62. LST1 Flywheel
  63. Aftershock header?
  64. is my lst2 tuned correctly?
  65. Basher to Racer(maybe..)
  66. What are my options?
  67. Flywheel spins but spur gears don't
  68. Single speed conversion
  69. Exaust upgrade on my Aftershock????
  70. 1/8 Raminator question
  71. Stuck throttle body?
  72. New aftershock questions.
  73. Paddles!!
  74. Spin Start Alternative
  75. Twitching
  76. Aftershocks Rocks The Richter Scale!! (with big pictures!)
  77. Broken Raminator Steering Servo
  78. DIFF's MAKING NOISE
  79. Lst2 shock boots?
  80. LST SHOCK UPGRADE
  81. mini Losi lst2 esc thermal shutdown -I don't believe it!
  82. upgraded shocks?????
  83. bearing+sillicone????
  84. stripped losi engine mount screw
  85. Mega Baja
  86. steering servos
  87. Spur Gear covers
  88. Muggy Questions
  89. What do I need for Spin Start on a Spec 3?
  90. the repairs thread!
  91. Team losi LST2 Fuel tank Problemo
  92. FUEL
  93. Aftershock, LST,LST2
  94. aftermarket brake kits? LST trucks
  95. 420 SIZE WHEELS
  96. BEST GLOW PLUG FOR MACH 26
  97. What body for Losi Muggy?
  98. Breaking in advice?
  99. I'm looking at the Mega Baja Monster Beetle
  100. Tires to wheels???
  101. LST gear options?
  102. Racing tires and wheels for LST
  103. Pissin Meh Off !!!!!!!!!!!!!!!!!!!!
  104. aftershock doesn't wheelie
  105. Engine problem? HELP?@?
  106. losi servoi saver question
  107. more problemes!
  108. Aftershock, very jumpy at low speed
  109. blue clutch bell?
  110. Aftershock pull start dead
  111. naughty savage!
  112. Wanting to install spin start on Aftershock
  113. Racing a Muggy
  114. Changing stock pipe to HT on Aftershock
  115. Stupid Question But.........
  116. MACH 427
  117. what bearings??????
  118. Aftershock rechargeable battery compartment install
  119. RC RACING BODIES
  120. Losi Muggy for 150$
  121. Rebuild or replace with other eng?
  122. gearing question
  123. xtm 457 vs lrp 28 spec3
  124. Im lost, PLEASE HELP!!!!!!!!!!
  125. lst2 shock shaft nut
  126. Problem with my LST2 engine starting
  127. Losi monster truck specs?
  128. what wing kit for lst 2 ?
  129. aftershock pipe options.
  130. LRP or 427?
  131. lst2 or bust
  132. pull start not working
  133. Losi Feedback
  134. lst radio problems?
  135. LST2 Tranny plugs?
  136. Servo Advice!?!
  137. MUGGY
  138. aftershock
  139. Axial 8 spoke oversize wheel AX8007 (white) acn I dye these wheels
  140. lst2 2nd gear
  141. lst upgrades?
  142. over heating problem
  143. LST SUPER TRUCK TIRES
  144. 1/8 Raminator
  145. sportwerks carb
  146. eight-t burning servos???
  147. 8ight T Engine decisions!!
  148. LRP homepage
  149. Still a problem with my Aftershock
  150. Aftershock Conversion
  151. MUST HAVE HOP UPS!?
  152. Has this happened to anyone?
  153. Can't give Aftershock full throttle
  154. lsi steering upgrade
  155. c/f hinge pins?
  156. LST2 kit or MIP CVDS?
  157. Temp lst2 First post :P
  158. losi one way bearing or go dynamite?
  159. aftershock gets some treats
  160. engine broken
  161. Receiver Battery Pack?
  162. LST2 VS aftershock
  163. LST Blown motor after 2.5 tanks!
  164. looking for alternate lst gear ratios?HELP!?
  165. Duratraxman1`s Aftershock
  166. Mach 427 glow plugs
  167. Losi 8ight-T Truggy RTR???
  168. best diff oil weight set up on an 8ight T?
  169. Replacing Front Servos - LST2
  170. LST2 receiver pack?
  171. aftershock wheel upgrade?
  172. 17mm vs 23mm conversion
  173. aftershock brake upgrade
  174. LST 2 Probs again
  175. Air leaks, etc...
  176. Truck keeps dying and hard starting...
  177. aftershock standing still
  178. Lst spur gear probs
  179. M26ss/LRP power upgrade
  180. Clutches
  181. Losi action picts
  182. Should i muggify my lst2?an to
  183. New Ramp
  184. How to get to BDC w/ pull start, and How important is After Run procedure?
  185. Aftershock Brake problems
  186. Another one bites the dust...
  187. Will this work?????
  188. aftershock hop recomendations
  189. The "new lid" is finally done!!!
  190. L8T clutch belol bearings
  191. Aftershock pipe?
  192. Can't belive this engine RUNS!?!?! W/ Pics
  193. New work desk pics
  194. anyone fix the Muggy clutch issues?
  195. receiver battery?
  196. high/low slector conversion?
  197. lst 2 or aftershock
  198. Muggy Or 8ight T?
  199. Spec 3 Rec. Temps
  200. battery
  201. New to Losi
  202. aftershock carbon fiber?
  203. whats the best 23mm hubs for the lst2????
  204. lst 2 overheating
  205. lst 2
  206. Converting my Aftershock to LST2...
  207. SPRINGS
  208. RD LOGICS AND INTEGY PIPES
  209. LRP Spec .28 Carb
  210. quick charge for LST2
  211. LOSI 8 T throttle servo
  212. 2wd monster
  213. LST keeps cracking fuel tanks on left side..
  214. Problems with 1 way bearing on Megabaja spur gear!!
  215. gear problem?
  216. back to stock tires and rims
  217. Well....
  218. Trashed my spur gears, how & Why?
  219. LST Roll Cage
  220. WHAT ENGINE TO UP GRADE WITH ON lST2
  221. WHAT'S REALLY THE DIFFERENCE DYNAMITE .28 vs. DYNAMITE PLATINUM .28
  222. Been away quite some time, but got the LST Mk1 out today....(But need some help!)
  223. Cheapest place to get LRP Spec3
  224. M26SS gloplug confusion
  225. LST2 Driveshafts + Axles will they work on a mammoth st???
  226. who makes the losi engines????
  227. Wheres the lst2 thread???
  228. RPM a-arms
  229. best place to get an lst2?
  230. I found this interesting
  231. [b]Lst2, Muggy, Or 8Ight T[/b]
  232. ? about stock lst 2 charger
  233. 427 silver head
  234. bead lock rims
  235. How to Pull a 427 Carb?
  236. Liquid Cooled and Supercharged Aftershock!
  237. Mach 427 flywheel getting stuck
  238. Mach 427 carb settings on mach 26 motor
  239. Aftershock stutters
  240. HELP!!
  241. Stalls When Shifting Lst2
  242. Pos or neg
  243. Having stalling issues with my s.26
  244. 2-speed problem
  245. werks motor?
  246. losi crankshaft differences??????
  247. Clutch springs look different
  248. Aftshock Tranny
  249. buying an lst2
  250. Help with Aftershock?
