View Full Version : Losi Monster Trucks
- MmMmMmMmMuggy!!!!!!!!!!!!!!!!!!!!!!!!!
- thinking of getting a new engine for my shock
- replacement to Losi pullstart/roto start?
- Roll cage / Handle
- I got a Losi muggy today... What parts to buy for smaller wheels/tires?
- aftershock with HPI aluminium polished tuned pipe
- lst axle problems
- Different Losi Pipes....?
- Suspension height in LST2?
- Muggy Diff noise.
- aftershock pull start to spin start converion instructions
- Painting bodies ?
- rpm a-arms???
- RPM A-arms
- LST to LST2
- Where can I find and buy a LST2??
- what exhaust
- truck comparison
- Where to get carbon fiber single servo tray for Muggy? Speedtech?
- Losi 454 Engine: What's the Verdict?
- Losi SmartDiff
- What is the best Truggy, MT engine for racing?
- losi or jammin?
- Setting Up An LST 2 to Race Questions....
- LST XXL release pushed back
- aftershock problems
- Thinking of going with an aftershock
- Need help with mach 427 engine!!!!
- Aftershock to LST2 Transmission
- lst2 weedeater
- aftershock
- different gearing
- LST2 stock where
- LRP On its Way
- LST2 motor temp?
- new clutch, dont want to screw it up
- Aftershock Wheels?
- some advice
- forward only
- why
- LST2 Tranny vs. Aftershock
- 1/8 Raminator
- google maps
- Good clutch system
- Big wheels for lst
- half tank lean
- Question about the new LST XXL
- LST2 manual mistake!
- Baja 5B shocks
- Aftershock HT pipe
- please help with losi aftershock
- Losi Claw MT Tires...Question.
- Uk guys help me out, where to get lunsford tb`s
- Transponder mount
- Sugafree ?
- LST2 Steering servos
- jr XR2i problems
- stock lst2 tire weight
- Anyone ran/running savage XL wheels
- remote start
- Winter Boredom Killing Me.. New LST2??
- Breaking in an Aftershock - by a newbie
- Transmission output shaft
- 427 Drop in?
- A Main Hobbies - Discount Codes
- Aftershock?
- Anybody used a Losi smart diff?
- Older LST
- Pissed at Horizon Hobby - LST2 Going Back for Warranty
- Failsafe on LST2, necessary or not?
- tranny problems???????
- LST2 Slipping in and out of gear
- Are you guys Lubing your one way bearing?The answer may suprise you!
- losi xxlst
- lrp vs. picco
- Probably a stupid question...
- Alum Fuel Tank?
- LST2 (Gold Head) Shift Issue?
- Lst-2 Engine Upgrade
- servo up-grade???
- Head Color - Does it matter?
- Best Glow Plug For the Teal head mach 427
- so i changed my mind....agian : )
- buku pipe
- Losi Raminator (good rig or not?)
- New LST2
- Losi muggy vs losi 8t vs hyper st. What should I get?
- How long will you let gas sit in your tank?
- New Era Parts
- rb tm928???
- Where can I get these, Thanks
- new tires question
- tire size difference
- to beadlock or not to beadlock?
- LST2 Allen Wrenches, EDS Gutted and Furious!!!!
- Lst2 Engine brace
- So ThunderbirdJunkie is getting a new (to him) truck
- 2spd one way bearing
- Aftershock / Muggy / LST2
- lrp z .28 spec 3 for my lst2???
- lst2 tranny???
- team losi LRP 28 spec 3
- Muggy Brushless Conversion???
- How is "Losi" pronounced?
- Truck keeps going into Neutral (Replace Clutch Shoes, Slipper Pads, OWB, and Spur Gears) Please help
- Help with LST2 Gearing
- New engine
- Spektrum Radios?
- OK IM RETARDED
- wheel shims
- Exhaust gaskets - non Losi
- LST2 alloy shock towers
- Aftershock vs lst2 vs t maxx 3.3
- problems mounting motor
- LST XXL Availability?
- LST2...mine has never really WORKED. HElp?
- that darn lst2 of mine???
- 1/8 scale differences
- active diff front rear muggy
- Help???
- lrp one way bearing
- STS .28 in LST2
- pull start / roto start OWB quck fix. LST AFT
- radios
- LST2,Need Help, Issues With No Rear Power
- LST2, what's needed
- RPM / turn bluckle help
- New Losi LST XXL!!
- lst2 problem???
- LST2/Aftershock Stiffest Springs
- rpm a arms
- Integy Sway Bar kit - Which is the stiffest bar?
- Drive cup/CVD boots for a Losi LST2
- lst2 high/low???
- Super Reving problem
- studded tyres(metal spikes, like ice tires) to LST2?
- Which LST2 spring rate for my running conditions?
- Track models?
- Vid of my Muggy on my track ......
- 2009 Losi catalog?
- Some vid of my LST2
- Stainless steel steering and shock balls for an LST2
- Aftershock Problems
- clutch bell
- Anybody here ever try the Hardcore Racing Ti skids ?
- lst2 carb screws backing out
- Same size shocks for Losi trucks??
- Shimming the drivetrain of an LST2
- Settings on LST2 after break in?
- sway bar kit
- glow plug for axial .28
- Common sense
- lst diff. fluid???
- Comparison Question?
- Losi Muggy newbie ?
- rb tm928 manifold for lst2???
- aftershock
- service
- New Xciter body I painted for my LST2
- My Muggy and pics of a new body I painted .
- New Losi trucks?
- Lst shocks to carry 16lb?
- brake pin
- New LST2 but no engine power.
- Stock Lst to SUPER Baja LST conversion ! "pics"
- Raminator?
- Losi spring rates - what is their tension?
- lst2 hop ups
- Muggy or After Shock
- Got my LST2 but I've got failsafe problems.
- repaired
- New engine ideas
- foc
- muggy or LSTS ?
- Giving up on LST2 and Nitro - Please help!
- Fuel?
- new engine?
- collection
- bent cvd
- tini spur and pinion opinions?
- Looking at Losi Aftershock
- check your fuel filter!!!!
- LRP spec 3 on LST2
- Mach 26 help!!
- LST2 hub frustration
- yet another problem
- LRP Spec 3 where cheapest?
- GPS Speed?
- funny running lst2
- Aftershock bash pictures
- Newbie need help with engine aftershock.
- Single servo steering?
- Aftershock hop ups-what to get?
- LST2 weight
- LST2 or XXX-NT 2? CAN'T DECIDE! OPINIONS?
- The blue smoke got out of my reciever
- lst2 hop-ups???
- In and our of gear
- Shock oil
- lst2 gearing problems???
- lst2 gear problems??
- lst tranny trouble
- Looking for advice on race engine for LST1
- Pull start?
- Ramunition - 2 Regular Motors or 1 Brusheless?
- Mach 427 bearing sizes?
- Bad Landing
- meja baja w/ lst2 tranny
- Whats the best thing to do?
- I need parts
- mega baja
- Dodge Ram MegaCab Aftershock
- FOC gear swap
- 23mm/Zombie Max/Rims???? on a LST2
- Got my Aftershock
- Best header for Picco P3 /086 pipe on LST2
- LST Fuel Problem
- OWB oil
- M26ss glowplugs?
- rx pack
- Rebuild Stock LST2 Engine or LRP Spec3
- Muggy LRP Spec 3 Pipe-test
- uggh...transmission help.
- what grease?
- Speaking of steering help............I need some
- 17mm for Aftershock
- Getting more low-end & torque from AFTERSHOCK ( LST / LST2 ) Gearing & Temp ?? [ TOPIC IS RESOLVED ]
- Quick question for engine performace.
- Aftershock ??
- need help with lst2 steering servo swap?????
- New F150 lid I painted for the LST2 !
- m26 trouble
- So I bought an LRP Z.28 Spec3 for my LST2 !
- M26ss. . .
- things to check...
- exploding bearings?!
- Electric conversion LST
- got my lst
- killer hobbies
- Stretch Bed LST!!!
- Fuel line ?
- please help
- Mach 26 seized - starter question
- mach 26 vs mach 427
- Losi 1/8th Excelorin 720 Brushless System
- I want to buy a LST 2.
- Is LST a solid Tranny or Diff'ed
- My "race" day
- need pic of LST2
