PDA
View Full Version : Losi Monster Trucks
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. Aftershock upgrade report
  2. deciding on a price...
  3. motor question
  4. spring rate??
  5. muggy
  6. Used LST
  7. GOOD DEAL???
  8. Mega Baja Question... Stumped
  9. can you do foc without buying the gears
  10. LST2 - making it go faster!
  11. SWAP SH PRO 28 FOR A LRP Z28 SPEC3
  12. lst to muggy
  13. Raminator
  14. parting out LST2's
  15. Muggy wheels/tires on the LST2 ?
  16. 20% vs 30%
  17. muggy clutch bell upgrade
  18. 427 in LST & 427 in 8T
  19. TX Antenna
  20. Aftershock advice
  21. Aftershock or Savage 25
  22. M26SS & LRP
  23. AFT Spends the night in oxygen tent!
  24. I am a beliver !
  25. Innovative RC Shocks..
  26. Steering mods or upgrades
  27. LST XS3 RADIO
  28. LST Tran`s ?
  29. Muggy / Fioroni clutch (wear after 1 race)
  30. LOSI LST
  31. losi lst2 wheels
  32. Aftershock/Mega Baja Questions
  33. running lst2 in the winter
  34. fearlst2's lst2
  35. Used LST
  36. New Guy with a Losi Monster
  37. die hard racer
  38. aftershock carbonfiber chassis
  39. reciever pack question
  40. LRP CARB ON MY MACH 427 ?
  41. have my dream truck LST2 is there any mods upgrades i should look into?
  42. Loving the new LST2
  43. Fuel pressure problem
  44. aftershock/lst
  45. after mach 427 what engine should i upgrade to
  46. P3 monster 26 vs modded mach 26?
  47. lst2 or muggy
  48. Engine Question
  49. Tubbed Aftershock Pro-Stock!
  50. clutch problems
  51. LST2 mods make HUGE difference
  52. 2007 RC Pro Finals JR Wins w/LST2!
  53. Cold Start Problem LST2
  54. can't tune this damn motor
  55. brakes
  56. lst2 or hpi savage x ss
  57. LST...? Aftershock..?
  58. clicking,popping noise
  59. Accurate temperature results
  60. low speed needle?
  61. battery?
  62. Extremley Dusty Conditions
  63. Starting the Mega Baja
  64. Broken clutch Spring
  65. help with wheelies please
  66. differences between aftershock and lst2?
  67. just got my lst 2 am i missing something?
  68. Need a charger
  69. Whats a good Mid Range Pipe For The LRP Z.28R Spec 3
  70. MOVED: HELP PLEASE I DONT KNOW WHO TO ASK
  71. can't get muggy to fly!!!!
  72. Muggy Vid..
  73. Size of LST2 and Aftershock Wheel Hex Things
  74. JR Z650M life expectancy
  75. have you seen this.
  76. RC fuel injections? - sorry about the missing link
  77. what effects fuel's performance?
  78. lst2 fuel
  79. JR Z650M
  80. lst2 servo savers
  81. my brakes suck
  82. Information on LST2 Problem
  83. Bump box
  84. LOST SOME TOP SPEED
  85. which should I get the mgt or mega baja
  86. Bump start back plate
  87. aftershock reverse
  88. steering linkage
  89. sts .30
  90. first lil bash with my LST2
  91. HRD ANO sid plates - i've heard some complaints
  92. 427 question
  93. servo question
  94. would the aftershock be a good starter truck
  95. screamer
  96. need your opinion on an aftershock
  97. upgrading to lst 2 spindles and hubs
  98. Super Trans Conversion
  99. The Mach 427, Is a .27?
  100. LST2 - Mach 26 or Hyper 21
  101. Lost compression?
  102. Lst-2 clicking when braking
  103. bac steering link
  104. Help With XS3 settings.....
  105. Engine break in? Circle ride or let it idle for couple of tanks
  106. more new losi labels + their website is different! - pic of labels
  107. New LST2 Owner Looking for Tips on upgrades
  108. New Body for my Muggy
  109. shock 2 speed
  110. starting problems
  111. Gear Ratios?
  112. better battery for lst-2
  113. 427 or .28RR ?
  114. new one way bearing to tight?
  115. air filter
  116. raminator 1/8th scale ???
  117. Lst-2 won't shift into 2nd gear
  118. Aftershock Steering Question
  119. Mega Baja Servos
  120. 2 Speed Muggy what motor should i buy ???
  121. Engine Problems LST2 Engine SOunds Werid
  122. LOSI BAJA
  123. 2 spd Muggy.
  124. Titanium VS. Steel Density - finished conversion
  125. Aftershock screw size question
  126. nNew Muggy..
  127. e-lst
  128. Muggy aluminum bulkheads
  129. front wheels turn when suspention compresses?
  130. Short vid I made of me AFT
  131. Diff outdrive o-rings
  132. More stuff broken :)
  133. starting an aftershock
  134. AMain Coupon
  135. best placement of on board temp sensors?
  136. classified ads ????????
  137. Aftershock tank pressure problem
  138. hub size ?
  139. LST2 260F-280F
  140. shock tower ?
  141. new engine problem
  142. Was this a good Deal???
  143. New lst2 body?
  144. to wing, or not to wing?
  145. which fuel do you use
  146. just a small concept....
  147. im still alive
  148. My LST2 finally broke something
  149. suggestions, anyone?
  150. 427 vs. 427 venturi measurements p.3
  151. aftershock stalling problem
  152. lst2 stock battery?
  153. f.a.q....one more
  154. Bigger flywheel for Aftershock?
  155. replace m26ss with xtm 24.7
  156. mega baja idle
  157. No reverse
  158. Haven’t run my trucks for a while…what should I do or know?
  159. newbie questions
  160. More LST2 video
  161. Transmission Ratio Formula
  162. 40 series tires and rims
  163. Plane engine ona a RC car???
  164. sleeve pinch
  165. what is up with the idle
  166. o rings
  167. Muggy Breaks, will this work better than stock?
  168. BYRON 30% FUEL
  169. LST2 glow plugs?
  170. LST2 or Mega Baja???
  171. Tires
  172. hi low selector knob?
  173. Single 142oz/in enough for Muggy and LST?
  174. Supercharger?????
  175. great lst2
  176. anyone modded their engines w/dremel?
  177. what does smoke mean?
  178. Brakes!!!!
  179. Muggy LST2 will cen 23mm work?
  180. Muggy w/mods RTR & XS3 for $300 shipped? Deal/no deal?
  181. new engine for the LST2
  182. 427
  183. Anyone Tried Trinity's Platinum .21/.28 Draked Racers?
  184. Gas tank seems leak
  185. Aftershock Touring Truck
  186. lst2 bac steering
  187. got me a nice second hand LST2
  188. Finally got My lst2
  189. LST 2 WILL NOT MOVE
  190. aftershock or baja?
  191. Anyone Else use Savage Clutch Shoes???
  192. LRP Spec 3 & Muggy - Clutch Fit Issues - Please Help....
  193. Need opinions of possible purchase.
  194. You think muggy part one was bad well check it out.
  195. muggy
  196. new body pics added
  197. Trying to get the "tuning ear"
  198. Muggy Wheels/Tires on an LST2??
  199. Jumping my LST2
  200. lst2 body
  201. runaway radio problem
  202. i need your guys opinion
  203. Confusion about break in.
  204. lst rec problems
  205. carb insert
  206. best pipe
  207. New wheels and tires
  208. steering servo?
  209. Aftershock wingmount
  210. After run oil?
  211. clutch bell
  212. pipe
  213. Muggy Project - STRUCK GOLD!!!!!
  214. Question about break in.
  215. cleaning the dirty ole trucks
  216. Truck is hard to start
  217. The final check before i get my lst2.
  218. after run or wd40
  219. anyone running picco 28 p3
  220. Sick bashing pics
  221. JR Racing: isn't it about time they make a DSM surface radio system?
  222. Acer asked me to donate or keep these, anyone want them?
  223. Mach 427 HSN problem
  224. New (to me) LST, what now??
  225. Setup Station
  226. returning new wheels
  227. Needle settings
  228. thickest shock oil i can run without busting shock bodies?
  229. Ok totally freaked out need some advice.
  230. trade in engine
  231. oil at idle screw
  232. My conversion to LST2 from Muggy
  233. New here and was looking for some advice
  234. Before and After on the LST2
  235. COMING SOON! LOSI 1/18 RAMINATOR Monster Truck!
  236. mach 427 compression
  237. Sts pipe is it worth the money?
  238. New Losi Labels!!!
  239. new to site need help
  240. Who lives close to Walnut Cove?
  241. Muggy screw..
  242. aftershock
  243. engine stalls
  244. LOSI LST2 HT PIPE
  245. Final answer
  246. what color?
  247. how do u install the DYNAMITE ALUM ENGINE BRACE
  248. Putting a gasoline engine in a LST/Muggy/LST2 etc?
  249. Muggy Pics
  250. how about this
