View Full Version : Losi Monster Trucks
- lst2 spur gear
- roll cage
- What do you guys know about this motor? Novarossi N528XSA 3 port
- tips on installing single steering servo
- Futaba- 3PM or 3PK?
- muggy wheels wont spin
- My wife driving the LST
- How would a Novarossi 21 hold up in LST
- Accidental Epiphany on LST2 Brakes
- Siderail steering arm question
- Who wants some??
- Best motor in the $100-$200 range?
- M26SS runtime?
- New CP2.0 I painted for my LST2
- LST2 Transmisson problem, help!!
- HELP PLZZZZZzzzzz
- rb products in a lst2
- I'm officially gay.
- Does FOC make it single speed?
- A trick for removing the owb?
- header problems?!
- LST2 Body
- 23mm wheel adapter compatibility..
- Warrenty service?
- Nastiest Big Block !
- Long story need some help.
- electric problems
- LST and LST2 SHOCKS
- MEGA BAJA SCREW PROBLEMS!
- oil shocks
- Need help with a few summer fixes.
- New Aftershock
- lst tuning problem
- stalls
- Need a little info from a Losi man
- Shocks with an LST UPGRADE KIT!
- BATTERY
- ENGINES
- STAND AND EQUIPMENT??
- 2008 Roar SMT Champion
- shock oil?
- Lrp in the LST2
- what hexes???
- Does Anybody Have the Hard Ano Muggy Chassis?
- Forward only conversion instructions
- burnt clutch in aft
- The idle
- TUNING A LST MONSTER TRUCK
- lst racer body
- minimal losi roll bar??
- flipping over the lst2
- aftershock hex size options?
- Qusetion for you LST owners
- which is the best
- difference in ht pipe
- Will it work?
- spin to pull
- Good reading material...
- Compression
- Mega Baja Motor Break In Issue
- I finally Broke something
- lst2 cvd's
- broken diff?
- Brakes and Cleaning recomendations???
- Mach M26SS thoughts
- This is for 2DMaxLST!! and others (ebay scam)
- My aftershock
- FOC ... ?
- lst2 aftershock gear ratios?
- BIG BLOCK
- lst spring tune up
- New Platinum .28 SG engine break in help
- Mach .26 head fit on a Mach 427?
- aftershock .26 head
- HELP please!!
- Hardened diff outdrives for LST2?
- Losi Hard Anodized Shock Bodies, Aluminum Shock Caps
- Looking for a poor mans way to adjust camber and toe
- Pipe fitting
- LST AND LST2 PARTS MATCH
- OT:Mario Theme Played with RC Car and Bottles
- Aftershock help
- It's waking up...
- spin/pull start combo
- Mini LST 2 big problem
- BAC?
- i got a muggy
- fuel has gas
- Finicky engine in LST, does tuned exhaust pipe help??
- picco .28 in lst2
- Do you cut a hole in the front windshield?
- pull start repairs?
- Muggy Price Help!
- need to make it lighter????
- clutch questions on my Aftershock
- CP2
- not getting temps up + questions
- mega baja not shifting
- won't start
- Aftershock throttle/brake servo doesn't brake
- Glow Plug is it charged???
- Please help, quick, how to put a jp4 on aftershock?
- Annoying Aftershock clutch
- dynamite 427 problems, please help.0.
- Losi Lst2 twospeed owb
- A list of wheels you guys use for the lst2
- Breaking in the aftershock
- Hyperthetical ?
- aftershock first run soon!!
- Losi Lst rear wheel steer
- LST2 racing
- New diff cups
- plz guys help me as soon as possible
- Muggified LST2
- Raminator "must have" upgrades?
- Aftershock problem from box...
- Aftershock reverse???
- losi aftershock skipping out of gear?goes no where?
- hey
- Losi aftershock bumper upgrades?
- wow
- Couple Mega Baja problems
- RPM arms camber adjustment.
- SHould I keep replacing stock front spindles or upgrade?
- hello
- Mega Baja battery pack
- Blew up rear end on the mega baja any upgrades
- what monstertruck
- lrp .28 backplate problem
- LST update
- muggy
- single servo conversion
- clutch shoes and springs?
- Big Daddy filter vs. stock LST2 filter....
- mega baja help
- lack of power to the wheels....
- lst2 wins!! pls help the newb
- LRP BUKU owners post your settings here...
- All I cab say is "HOLY CRAP!"
- LRP Z28 SPEC3
- raminator
- MUGGY: can I install a buggy (8ight) body?
- Starting an aftershock...
- losi servo upgrade.
- lst2 withl rp .28 spec 3
- body's for my aftershock?
- is a Losi good for me?
- Which 2.4ghz radio?
- HT Pipe v Muggy Pipe
- ? about Batteries for the Lst2
- ripped off
- Difference Between LST and LST2 A-ARMS.
- modify
- Aftershock....turnbuckles, a-arms, Bracebrace, pipe, cage, lst2 tank, shocks...help please.
- MUGGY: Which ON-ROAD tires/wheels?
- Will an LST2 hang with a Truggy?
- TEAM LOSI MUGGY
- Why convert a Nitro Muggy to electric/brushless?
- losi lst2
- Losi AFT worth?
- Lst 2 brake issues(jittering, sticking, dragging)
- Okay so I am sick of busting A-arms, suggestions?
- Amazing jump...only brke one thing, now how do I fix it? Please Help
- need help.. screw part number not listed
- losi shock rebuild????
- Can you charge AA's with the Prophet Plug charger?
- NEW Brakes!!!
- Have you guys seen these Losi copies
- Aftershock! How tough?
- What is the "K&N" of R/C Car Filters?
- Aftershock.... What are the best engine mounts/braces ou there?
- it took almost 3/4 of a gallon................
- Air Leak in fuel filter???
- I need some info on the Mach 427
- How bad can you beat your Aftershock?
- Shut down/end of day procedure?
- Aftershock Parts
- Best Roll Cage for Lst/Aft
- Jammin X1-CRT RTR stock pipe
- Adjusting the Servo Saver
- Help with tuned pipe
- Mini LST speed
- Hobby Shops
- Spur gear
- The Dynamite MACH 427? Pro's/Con's
- need to know.............
- Hello LST owners
- clutch shoes disintrigation
- lst 2 tranny help!
- Loose spur gears?
- LST2 diff oil
- Just a little help?
- things to know about lst2 mods
- tires and wheels??
- which battery pack?
- What the Crap!?
- Raminator, Aftershock, Baja Bug??????
- Best Wing Kit for LST2?
- new to Lst2 with ?
- Back after an absence
- LST Forum
- Found out why tranny shaft broke...
- Battery pack adapter?
- Muggy Diffs in LST2?
- new losi
- Is the LRP Spec 3 really the only "racing" engine for the LST2?
- Combo pull and spin start
- Broken tranny drive pin???
- LST Clutch Locking up
- which losi
- Help me find diff pins please...LOSB3540?
- Axial .32 reviews anyone????
- My LST 2 Video and screen shots
- 1/8 Raminator
- Making your truck go str8
- MUGGY QUESTION.. !!!!!!LOOK!!!!!
- Beadlocks
- Clutch bell overheating??!
- oiling outer air filter
- mega baja
- got me a muggy
- foc conversion question
- Damaged Parts on your LST2
- Looking for some new LST2 Tires - Panther Pythons??
- Who's Got a Buku Pipe on Their Losi MT??
- First Losi Purchase
- LST2 Axial .32 ?????????????????????????
- LST2 Diff. Retainer Upgrades????
- Low speed needle setting???
- mega baja brakes
- Axial .28 in AFT?
- Weak Servos or Weak RX Pack?
- LST DX2/3
- LST2 High Low Gear Setting Knob
- Yer kidding me...
- MUGGY VALUE
- battery question
- faster lst2???
- Soon to be LST2 owner
- quick questions
- Northern Michigan
- New era roll bar
- What is the Difference between the 4 Losi Monster Truck
- Do hpi bodies fit on a lst2?
- lst 2 carb. upgrade
- lst2 throttle/brake setup
- Aftershock, Mega Baja, Raminator, LST2
- LST2 kit ?
- Bigger Losi MT???
- RB Innovations air filter?
