View Full Version : Losi Monster Trucks
- Anybody using that new OS.30 yet?
- transmitter packs?
- LST Tonka Tuff?
- Different tyres for 40 series rims???
- IS THERE SOMEBODY THAT DOESN'T BELIEVE IN RE32 POWER?
- IS THE LST A GOOD TRUCK TO BUY?
- batts
- Home made shock tower support and roll bar !!
- RC Solutions roll cage
- Hot bodies 7.7" wheels on LST?
- My new LST looks wired and it is LST #000015
- Introduction, and Check out this Deal!!!!
- anyone in florida?
- So its official... Im back!
- LST Forward Only Tranny tip.......
- Should I get an LST-2??
- Da washer??
- LST mod with JR9000t servos
- Mini Lst?? Maxxtracks??? hmmm
- Any noticeable difference...
- New Shell.
- New LST overheats..
- Got the dybamite linkage.
- Do You Remember?
- Old Santa rocked up in Australia a Bit early this year!
- Losi White Lst Springs?
- Bad Ass Greations steering link??
- My LST finally got it!!
- THIEF!!
- destruction
- Is this grease okay??
- Anybody using the PL 23mm HD hex replacements?
- Servo Hitting Diff Case.
- LST STOCK wheel hex size!?!?
- I bought a lst today!
- Dynamite throttle linkage?
- Aftermarket Bodies for the LST
- ofna twin titan
- LST Bodies
- MY LST
- Upgrade for diff. retainers??
- LST 2 IS OUT!!!!
- confused
- Mach .28
- Bearings, would you spend the $$
- What kind of lube do i use in my DIFF
- SUCCESS!! I have Locked the diff. without messing the stock diff up!!
- LST hop-ups options!!!
- High traction tires for LST???
- Shock limiters about to be undone!!!
- LST 2 Engine size?
- LST INSANE suspension!!!
- LST TIRE ??'s HELP!!
- LST 2
- Idle issue
- .21 with rotostart for LST?
- lst 1 or 2 is better
- RLST
- Engine not working since rebuild
- LST Practice day goes horribly wrong....
- sure fire .32
- please help!!
- My new arms and extra stuff (scroll down for new stuff)
- Engine Break-In
- How do I adjust the slipper??
- Luv this LST!!
- where to get
- Lst
- Happy Thanksgiving!
- What else do i need to buy
- I overhauled my truck, but....
- Broke Shock Shaft
- LST center drive shaft issue!
- Good Pipe.
- Forward Only Conversion???'s
- MOVED: CEN GENISIS AND NEMISIS??????
- ? for 2DmaxLST
- Im Back!
- Stock LST tires on Pro-Line 40 series beadlocks
- BUYING LST ON EBAY!!!????
- LST2 or 4.6 Savage???!!!! Or LST 1
- Pro-Line tires on velocity rims
- LST 2 tire size?
- Clutch Problem?
- Roll Bar?
- Aluminum LST Parts from Integy
- Sportwerks Mixture Advice
- SH-28 in the LST??'s
- LST 2 Questions
- lst for racing
- Sway bar ????
- Wasp .26 or Hyper 21 8 Port?
- Additional LST newbie questions...
- Metal on Metal interference??
- Official LST 2 thread!!!!????
- Alright who won it? Fess up!!
- Getting an LST, Help??'s
- Aluminium Diff Case Help
- Can LST wheelie stock!!!!!?????
- Breaking CVD Pins
- I JUST DON"T KNOW
- Giving up the LST
- Wing for the LST?
- shifting issues?
- Colorless Wings
- replacement turnbuckles
- Crazy nut brakes
- More Power!!
- Newbie tempted to crack her open.
- steering ??
- new to sport
- engine help please.
- LST racer body again.
- pro-line beadlocks any good?
- Aluminum Clutch
- LST Original discontinued?
- Buzz from steering servo's
- Front Tires, All over the place!
- using Ebay alumi. gear cover and TiNi gear together???
- TEAM LOSI LST 2
- O.S. 30VG Is Almost HERE!
- LST WITH BALLS!!!
- Help with LST PLEASE Quick!!
- LST racer body question???
- new to lst's and rc universe
- Stuck in Low Gear
- he
- Can't get it to turn in the corners.
- Question about removing the Mach .26
- I killed 2 Mach's in 3 days
- Radio or reciver may have died
- How many LBS
- Breaking in LST Tomorrow
- Diff case..
- In the Cold
- order
- Clean out rust from an engine?
- LST 1 or 2
- LST1 or 2?
- Steering wont turn.
- You have to see this!!
- ?????'s
- How is Losi product support?
- What do you think the best 5 upgrades for racing.
- Center HD Skid Plate with JP-1?
- SPEED?
- Race Engine
- This can't be good.
- Brakes catchy/binding/dragging?
- Aluminum Clutch Shoes?
- More bad Luck! Rod Ends
- Losi Bead Lock Wheels
- Good Pipe for a Picco 27 and Nova 28?
- 3.81 hp LRP Z-28 engine
- RPM Gear Cover problem
- **Official LST2 Thread**
- OMG.these TiNi gears drvie me Crazy
- Who has Losi Number 1? or closest?
- Does the LST have to be so loud!!
- Drivetrain question.
- Lst with collari .30
- missing steering servo part
- Broken Drive Shaft!
- T-maxx vs LST - Rolling grass drags
- Tired of cleaning my One-Way
- crowd pleazer w/ new era
- stock clutch problem!
- how about a bigger fuel tank?
- Can't figure this out...smoke from the glow plug
- Clutch and gears
- Brakes are crappin out on me.
- My LST in a 30 minute main from last night....
- Need help on running the LST...
- Busted
- New Tini gear-shifting question
- Collari help
- Bulkhead ???
- Any Truth to the rumor that we might see a special edition LST soon?
- Measurement?
- Who says the LST is not durable....
- 2wd Fun!
- Shifting into 2nd gear
- Header for Mach .26 W/pullstart
- UHHG! This part is a POS!
- Throttle Linkage tweaks (pics)
- Any News on O.S. LST motor?
- My LST has a new riding companion
- idle adjustment screw
- Not shure???
- Help me find Brt1's !!
- gear nd clutch question
- LST into a tree
- backfire
- LST with mach .28?
- Keeping Pull-Start String Dry.
- Better steering for the LST?
- better lst ?
- ANY PICS OF MTS
- LST QUESTIONS
- LST QUESTIONS
- whitch car to get? plese help
- revo versis Lst
- Mach.26 trashed
- Threaded Shock Bodies Question
- Shock limiters done !!
- lst vs mini lst
- lightest lst???
- Which 30% Fuel?
- Are these any good?????
- 5k vs 30k diff fluid??
- Slipper clutch adjustment
- Tower Hobbies?
- Sell me on this LST
- need help on removing the stock carb off
- New Team Losi Mini-LST
- quick help on LOSI polished pipe
- $70 for TiNi gears???
- Dual Rate Spings, Anybody using?
- More Engine Problems
- LST Setup
- Super King Pin
- R/C Solutions LST rollcage?
- ONE Way
- What was your best running engine ever?????
- One servo for steering
- Digital servos
- B.A.C. Steering Link
- What Truck to get
- Upgrade Question
- Reccomend me an LST engine please.
- Using 2 receiver packs...
- RPM parts (any good)
- How much is a LST worth?
- lower lst, stiffer springs???
- Serious ***** Kissin'
- LST with a CEN .46, to be or not to be!!
- Advise and help on a few upgrades that I'm about to buy....
- Sirio .30 w/ roto-start system?
- Stiffer springs..
- How do you remove the gears from the bell housing?
- Lunsford Tie-rods, Hot Racing Tie-rod ends, RPM A-arms, Bad-Ass drag link, New Era hub carriers
- What DIFF OIL for RECE setup?
- New Era front skid and bumper brace.
- Shocks and stock oil settings
- Diff Oil Viscosity (And Diff Shim)
- Full potential??
- New LST (or is it)
- 12 hours to go
- Loss power of Mach 26 Engine
- Zombie Maxx?BowTies?DirtBones?
