Reload this Page >
Great planes ultimate 160
Old 02-09-2010, 05:36 PM
  #6251
aussieflyer2214
Default RE: Great planes ultimate 160
Hey all:
Can you post what kind of hardware you all are using? Did you upgrade to turnbuckle, HD, ball link, etc? Please post sizes and brand to help me know which to purchase.
Thanks to all.
Regards,
Austin
Old 02-09-2010, 10:46 PM
  #6252
Robert Strouse
I used the 4-40 carbon/titanium rods for the tail group from central hobbies. For ball links I used Rocket City 4-40s. For clevises and I used dubro 4-40 safety locks with the brass pin and nylon body. I try to stay away from the steel connecters since vibration eventually loosens them up on their threads. On the ailerons I used the same clevises for the surface end and soldered a dubro steel clevis to the servo end. The distance is so short on the ailerons that there really is no need for carbon fiber. If you manage to bend an aileron rod my guess is that aileron is no longer connected to the wing. Probably due to a sudden stop and a one point landing.
As for the tail wires, use them they absolutely rock and the assembly for tightening them up gets the tension perfect on the first try. Be careful though its pretty easy to overtighten the set screw if you have a good set of allen wrenches. The brass will stretch and weaken the stud. I had to order a replacement set.
I rehinged the entilre plane using dubro 1/4 scale hinges. I just like how smooth the surface is after doing this and there isn't enough surface material in my opinion to support robart pin hinges. Some have done it but I won't do it unless the surface is built up and the shaft is supported by at least 3/8". As for CA hinges, I just can't bring myself to put whatever the brand on a bird where the control throws are going to be so dramatic. Not to mention the vibration.
I know some folks on this forum just used the stock hardware have had great success but I tend to throw all that stuff in a drawer and go get the stuff I like. With this bird I tossed everything except the wheels and regretted it later. The wheels should have gone too! Just let it sit on its legs for too long and you will find that the wheels will go square. I thought that they were hard enough at first but they are just like most ARF tires. A waste of space in the package that eventually makes your plane penguin waddle out to the EOR.
Robert
Old 02-11-2010, 03:07 PM
  #6253
tater1
Hello: slowly getting there,with a lot of good advice and help here,the slide pictures are invaluable,and help to show a lot of great install ideas[img][/img]
Old 02-11-2010, 03:25 PM
  #6254
bubbagates
My Feedback: (32)
bubbagates's Avatar
Nice, don't bring it down here, it would get lost in all the snow, besides I have my new one and haven't taken it out of the box, so to speak so I would sneak off with yours and leave you mine
Old 02-11-2010, 03:39 PM
  #6255
66-stang
66-stang's Avatar
Tater1, what did Bad Brad charge you for the graphics. looks good!
Old 02-11-2010, 04:05 PM
  #6256
aussieflyer2214
Tater,
Looks really good. Send some more pics! Engine, tail, wings, inside...Nice work!
Old 02-11-2010, 04:35 PM
  #6257
tater1
I purchased two sets one for the ultimate,and one for the AWyak,including pilot names 197.50,they are nice looking,good quality,he does great work
Old 02-12-2010, 03:28 PM
  #6258
tater1
Ok here are some more pictures,I can see the light at the end of the tunnel with this install
ID:	1377187   Click image for larger version
ID:	1377188   Click image for larger version
ID:	1377189   Click image for larger version
ID:	1377190   Click image for larger version
ID:	1377191   Click image for larger version
ID:	1377192   Click image for larger version
Old 02-12-2010, 03:44 PM
  #6259
kaboomski
Hitater1!
If Iwere you Iwould make a hole in the firewall for the carb. Iwould NOT want to find it out the hard way.
kaboomski;
Old 02-12-2010, 03:58 PM
  #6260
aussieflyer2214
Tater1,
Thanks for the pics! Looks great. kaboomski: That's a good point, however I understand that if you have more than one inch between carb and firewall, you don't need to cut hole. This would just spray fuel back into motorbox, no? Thoughts on this everyone? Cause I'm about to do the same setup soon w/ my DA.
I'll send pics of my ulti soon too.
A
Old 02-12-2010, 04:00 PM
  #6261
tater1
This is whats great about this forum,thank you for seeing that,I will drill the hole,will 3/4" be ok?
Old 02-12-2010, 04:03 PM
  #6262
tater1
I have just 1" clearance in my install,interesting observation I will look forward to what everyone has to say.
Old 02-12-2010, 04:06 PM
  #6263
kaboomski
I'm referring to the DA50 manual:
Make sure the carburetor has adequate clearance near the inlet to allow an unobstructed airflow into the carburetor. If the carburetor is located in front of the firewall, be sure there is at least 1" (25mm) of clearance from the carburetor inlet. If there is less than 1" clearance, make a hole larger than the carburetor inlet diameter in the firewall.
Try to breath while out of breath less than 1" to the wall
kaboomski;
Old 02-12-2010, 04:07 PM
  #6264
chuck l
My Feedback: (17)
tater1,
Looking good, but I have a couple of comments. Ditch the stock fuel tank, you're carrying at least an extra 8oz of fuel that just isn't needed with the gas engine, a 14-16oz tank is plenty. The supplied tank was intended for a glow sucking engine. You might need the rudder servo in the tail of the plane for balance with the gas engine.
Chuck
Old 02-12-2010, 04:11 PM
  #6265
kaboomski
Ihave a similar setup. Moved the receiver batteries (2) to the back.
kaboomski;
Old 02-12-2010, 04:13 PM
  #6266
66-stang
66-stang's Avatar
If your worried about spraying oil from the carb into the firewall. Cut a soda bottle and glue it to the inside.
Old 02-12-2010, 04:18 PM
  #6267
kaboomski
Here is a closeup of mine.
Old 02-12-2010, 04:29 PM
  #6268
aussieflyer2214
I plan on running the stock tank w/ DA50. I'd like as much flying time as possible. Have read others using stock tank w/ 50s also.
Old 02-12-2010, 04:31 PM
  #6269
tater1
Hello Kaboomski:your engine install looks good,what is the size of the hole in the firewall?
Old 02-12-2010, 04:37 PM
  #6270
kaboomski
1"
Old 02-12-2010, 05:15 PM
  #6271
twn
twn's Avatar
Tater1, I did a 1" hole on mine and I have no fuel coming in through it.
Great looking setup so far!
BTW something else you might want to do is solder a small 1/8" brass tube into the plate that is on the bottom of the carb with a barb and run a piece of fuel line from it to the inside of yer fusalage. I had to with my dl50. Something with airpressure levels changing, my engine ran no so good without it.
I had to drill the hole a bit bigger for the brass tube. I used silver solder.
The plate has an existing hole in it but putting the tube on it puts the outlet inside the fuse where there is less pressure changes (I think this is how it works) some people run the tube into a film bottle inside the fusalage.
Old 02-12-2010, 05:39 PM
  #6272
tater1
Hello Tom: thank you for the help,will do those mods,by the way send me your Phone Number via e-mail,be great to talk.All the best.
Old 02-12-2010, 07:52 PM
  #6273
tater1
hello Tom:
that little hole on the bottom of the carb plate is directly below the throttle linkage.Can I rotate that plate so the hole is on the opposite side?
Old 02-12-2010, 09:52 PM
  #6274
twn
twn's Avatar
u can try. for me I had to run the line right into the fuse, I just left the line open in the fusalage. I think there was too much turblance in the cowl. It was wierd, periodcal loss of power, once I ran the line it was great. I have that dl50 in my 79" extra 260 now. I'm currently thinking out a new power source for my ultimate. I want much more than 50cc, something in the 60cc range...
Old 02-13-2010, 01:15 AM
  #6275
tater1
Hello Tom: I did not explain clear enough,I mean that I will still solder the extension to the carb plate hole,and run a line back into the fusilage,just wondered if it would make a difference if after I solder the tube extension,can I reinstall the plate so that the soldered on tube is opposite to the original location,ie,rotate the plate 180 degrees.
