 U-Can-Do 3d 46? >
U-Can-Do 3d 46?
U-Can-Do 3d 46?
Old 01-07-2006 | 01:55 PM
  #3926
Default RE: U-Can-Do 3d 46?
gjeffers...
Great looking photos. I love your weather. If I was to show pic, it would be all white or brown with with spots and we'd have heavy coats...if I was to show pictures. Is that you in the canopy? Great looking planes by the way. And...nice flying.
Crank...
I thought "struts" were a form of walking after you did a low inverted pass...gjeffers style.
Rob...Nice profile. Do you like flying that more than UCD?
Bud
Old 01-07-2006 | 02:42 PM
  #3927
rclement's Avatar
ORIGINAL: gjeffers
always put the peanut butter on the bottom of the plane CEEGEE and youll have no landing probs
here are some christmas day flying pics of me and my son[8D]
Ahhhhhh.........[:-] So that's the secret...... It's finally out of the bag....... I knew I was doing something wrong [X(]
Nice pictures Gary. I'll have to take my camera to the field more often. Is that an Elvis troll doll? [X(] Very cool.....[8D]
Old 01-07-2006 | 02:48 PM
  #3928
rclement's Avatar
ORIGINAL:
Bud
Uhhhmmm..... AAAaaahhhhh........ Well of course not. After all this is the UCDo thread......
By the way I'm building an OMP Edge profile kit. It's being modified into a two piece wing. I'll post some pics soon.
Old 01-07-2006 | 07:11 PM
  #3929
Damn, Doug, you beg the question: which "model" flies higher?
'Nough asked.
Jack (laughing)
Old 01-07-2006 | 07:33 PM
  #3930
CofG
my rudder servo is in the fuse
i'm using a pull-pull set up
38
ID:	382979   Click image for larger version
ID:	382980   Click image for larger version
Old 01-08-2006 | 01:46 AM
  #3931
38...
Nice pics of the ST. I think most are going with the P/P rudder servo. It balances better unless you have a very heavy engine like the OS160, Saito 180, Mag 180 or gas. I'll bet yours will fly great.
Bud
Old 01-08-2006 | 08:33 AM
  #3932
CofG,
with the p-p you only get 2/3 the rudder you would get if you put the servo in the back
but i'm using a lipo and i need all the weight in the front
38
Old 01-08-2006 | 09:59 AM
  #3933
i just got my seccond u can do it done im new two this site . i love the plane os 60 fx has some power i crased my last one 8 times and it always came back two life my friends call it the u can glue it. be careful of the tail ripin off mine broke on the first high speed inverted flight thank god for 2 elevator servos it was hard 2 land with the servoarm holding the whole left side of the tail forcing the planeup and down violently i sugust u put braces on the leading edge
Old 01-08-2006 | 09:00 PM
  #3934
38...
On the ST I've seen, the rudder was pull/pull and the deflection was clear until it hit the elevator. But I've also heard it doesn't matter that much because the rudder has so much athority that it will high alpha knife edge with about 1/2 throw. The plane can snap pretty easy though so you have to be a bit careful.
Your build looks really nice.
It snowed today, about 6 inches. Bummer.
Bud
Old 01-09-2006 | 03:21 PM
  #3935
Question for you experienced guys: how much air has to go through the cowling to cool the engine?
I've heard that the size of the intake/outtake is NOT that important. What IS important is the RATIO between the two: if intake = 1, outtake must = 3.
Is that correct? Anyone else have ideas on how to do that so the engine doesn't over-heat. 2 or 4 stroke makes no difference I hear.
Jack
Old 01-09-2006 | 05:04 PM
  #3936
gjeffers's Avatar
jack, the bigger the better, just make it look nice, and the ratio should be 3-1 out.
since this pic i have cut more out of the bottom, although i never had a overheating problem
Old 01-09-2006 | 07:34 PM
  #3937
Jack 211...
I think even more must be cut away than in gjeffers photo. I've seen pictures where the entire bottom is cut out. It don't look bad and it's the best thing you can do to get your engine to run better. Get the hot air around it out and away. Open the cowl up. You won't be sorry,...or so I've heard.
BS
Old 01-09-2006 | 07:36 PM
  #3938
Man this thread is really clunkin' along. But there is no way it will top 4000 post before the weekend. No way.
I was looking and I thing there are only two threads over 4000 posts. Yak and Funtana. It would be cool to see this one get there too.
Bud
Old 01-09-2006 | 09:46 PM
  #3939
BeechTech's Avatar
Well lets keep it going. I flew my Showtime the first time on sunday, its going to take some getting used to how it handles. Very sensitive on the controls, and does a perfect knife edge.
Old 01-09-2006 | 10:30 PM
  #3940
gjeffers's Avatar
i came on board on 3-2-05, post 1303 on page 53, wow , nothing but a great time, thanks guys
Old 01-09-2006 | 10:32 PM
  #3941
BeechTech...
The Showtime is a very neat airplane. In many ways flys better than UCD. Flys prettier but not as much "fun". At least...so I hear.
Bud
Old 01-09-2006 | 11:22 PM
  #3942
nice cutout... looks clean.... what size engine is that?
Old 01-10-2006 | 05:37 AM
  #3943
gjeffers...
You have been one of the main contributors...and steady with much good information. Thank for your contribution.
I'm snowbound...looking forward to spring. Can't wait to fly again. You year round guys have it good.
This winter I don't even have a project. Just waiting.
Bud
Old 01-10-2006 | 11:43 AM
  #3944
rclement's Avatar
No year 'round here........ unless I get a float plane......[>:]
Hey, if I do all my flying inverted at least I'll keep the top of the wing dry.....[8D]
Old 01-10-2006 | 06:57 PM
  #3945
gjeffers's Avatar
ORIGINAL: rkutach
i have a 100 in that little hole
thanks for the kind words Bud, i say the same in return
CEEGEE. fly nothing but downlines and the rain cant catch it[sm=drowning.gif]
Old 01-10-2006 | 07:32 PM
  #3946
Rob Clement RC...
If you want a float plane I understand the UCDs are real floater....
Bud
Old 01-10-2006 | 09:50 PM
  #3947
rclement's Avatar
[quote]ORIGINAL: gjeffers
ORIGINAL: rkutach
Ohhhhh....... so that's the trick........ I can do that.
Old 01-10-2006 | 09:53 PM
  #3948
rclement's Avatar
ORIGINAL: CofG
Rob Clement RC...
Bud
Well if it keeps raining here all my planes will float away.....[>:]
CofG, What are you flying these days?
Old 01-10-2006 | 10:38 PM
  #3949
Rob Clement RC...
Right now I have a Typhoon. Not a very good airplane. I thought I could use it to train a bit in the winter for 3D, but I really don't like the way it flys. I'm trying to get my hands on a Mayhem 40 but it doesn't look like they'll ever be available. So really nothing right now. Well, almost nothing.
Whose gonna get 4000?
Than ks
Bud
Old 01-10-2006 | 10:58 PM
  #3950
Been thinking a bit about what plane I'd really like to get. Oddly enough one I've been seriously looking at is a Great Planes P-6E Curtis Hawk biplane. I think that thing looks really cool but it doesn't really seem like my kind of flying and I've heard bipes are difficult (time consuming) to assemble at the field. Sometimes my flight sessions are very limited on time (lunchhour). So I probably won't get one. Another I've looked at is a Great Planes Yak, but I don't like Yaks and it might be a little large. I thought about a Ultra RC Giles but I second guessed myself and didn't buy it. I'm pretty interested in an Aeroworks 60/90 size Edge. I might purchase one of those. And I've been thinking about a Giant sized UCD. I've researched the thread on that thing and it seems to be a sleeper. They talked about how agile it is for a large plane and how aerobatic it is. Flys much better KE than the smaller UCDs and is great with waterfall and flats. It's really got my attention. I don't have an engine for it but I guess my choice would be a OS160. And last but not least (some will be very surprised by this) a Funtana. I'd seriously but a OS160 in it. It's the perfect engine. The extra weight would make the plane balance much better and the power would haul the heavy beast around. I guess I just accept the fact it would be 10 lbs and power it accordingly.
But all of the above is just speculation and stuff I've heard.
Bud
