Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 04-12-2011, 11:22 PM
  #526
dubd
dubd's Avatar
Default RE: C-ARF Ultra Flash build Thread + Video
ORIGINAL: dirtydingus
Hey Dave (and others),
Just finished my Ultra Flash and I have a concern, the plane sits level on the ground and when I test ran it today I noticed the tank was running out so I shut it down. I then drained the rest of the fuel to make sure it was all out. I picked up the nose and another 16 ounces came out. Is this normal, or should I remove the rear brace and drop the rear of the tank? I am running a 120 SX so I need every drop of fuel to count. I guess my question is does the plane fly with a slight nose-up attitude, allowing the tank to drain properly?
Jim Record
Yes, this is normal and well documented in the "classic" Flash threads. I am running a P-160SX and have a dozen flights on my UF without any problems. You will always have some fuel left in the main tank. I previously had a classic Flash with a P-120SE and over 300 flights on that plane without any problems with the tank.
Old 04-13-2011, 01:35 AM
  #527
gingerbatics
Jim
Absolutley normal! The UF does fly with a nose down attitude. On a P120SX I have the timer set 8 1/2 mins and there is alwasy plenty left for a go around. Timer starts gear up to gear down.
Flew mine twice yesterday evening, and she's magic! Most of the flight at half power with full power in the verticals - awesome!
Both me and a mate of mine have dialed out a bit of landing flap to 3 1/4" for a better landing profile and now she's fantastic off a grass patch.
Regards
Adam
Old 04-13-2011, 11:39 AM
  #528
dirtydingus
dirtydingus's Avatar
I filled both tanks to capacity and then drained the system through the UAT just as the motor would with plane level and retrieved 88oz of fuel. Pretty poor for a 112oz system. I then dropped the rear of the tank 1/4" and tried the same method again and retrieved 96oz. Better but still not acceptable and that is as far down as the tank can go without hitting the duct. Does anyone make a properly shaped tank? There is just something about unusable fuel that bugs me. Why carry it around?
Jim
Old 04-13-2011, 12:13 PM
  #529
Dave Wilshere
Jim
You have a felt clunk in the main fuel tank? The stock set up works in flight 100%. With a felt clunk and the system as designed I fly 9 minutes, mixed speed, no air in the header, P-120SX...1000's of Flashes flying so it works fine!
Dave
Old 04-13-2011, 12:26 PM
  #530
igorcar
Hello Guys
http://www.youtube.com/watch?v=ZrRE_...eature=related
Speed pass 5:00
Old 04-13-2011, 12:31 PM
  #531
dirtydingus
Hey Dave
I am using the felt clunks in both tanks and the wing tank is completely empty after draining. The main tank however has fuel that you can see up in front. I realize it's probably not a problem causer it's just a little unsettling to drain a tank and still have a pint of fuel sloshing around. Seems like comp arf would have remedied the issue early on.
On a different note, I am doing the maiden tomorrow. Overall I am very happy with the plane and would consider it a fine ARF.
Jim
Old 04-13-2011, 12:39 PM
  #532
dirtydingus
Igorcar
That is some fine flying! What is that Flash powered with?
Old 04-13-2011, 12:47 PM
  #533
dubd
dubd's Avatar
Jim, this issue has been discussed to death in the classic Flash threads. Perhaps you'll find a solution there.
Old 04-13-2011, 12:53 PM
  #534
dirtydingus
Dubd
Thanks and I admit I haven't spent enough time on the CF thread. I'll do some catching up tonight.
Jim
Old 04-13-2011, 01:10 PM
  #535
sailing1
My Feedback: (134)
I just built a sump into my main tank and use a heavy Dreamworks clunk. Sucks every drop out.
Old 04-13-2011, 01:19 PM
  #536
dirtydingus
Hey sailing1
How about some pictures? That's what I was thinking of doing and if yours works well why reinvent the wheel.
Jim
Old 04-13-2011, 01:22 PM
  #537
ricardinho
That makes sense..do you have any pics of how you did that..that sound like a good idea....
Old 04-13-2011, 06:50 PM
  #538
sailing1
My Feedback: (134)
There are probably a couple of pictures of my sump and some others on the Classic Flash threads. The only one I have handy is this one. Basically I just added a sump to the back half of the main tank. This brings my total fuel capacity on the main tank to 104 ounces. I am not using the wing tank. With my Rabbit I was flying 8-9 minutes with probably 35 ounces left. With the Cheetah I am flying 7 minutes with maybe 15-20 ounces reserve. As you can see, I am not using the full bypass and have no problems at all with enough air for the Cheetah.
Old 04-13-2011, 10:40 PM
  #539
Dave Wilshere
Hey Dave
Jim
Jim
Then you are fine...I've test flown dozens of Flash models, never been an issue. CARF have nothing to fix, please understand that there have been over 1000 Flashes sold, if it was a problem, it would have come up way before now on the UF. The tank design works 100% in the air, CARF don't "fly" their aeroplanes sitting on the gound, so draining the tank fully sitting on it's wheels is not an issue
I just took these shots, this is a 9 Minute flight, the guys that were at PMFC the day I flew this tank out will tell you I flew fast, slow, snaps, spins etc etc. Look at the tank level and UAT...I cannot see ANY bubble, so I could have flown another 30sec and used more fuel from the main tank...
Do you guys re mould BVM tanks when you build BobCat's and Bandits? nah, so why here...it's fine if you assemble the tanks with the equipment they come with and are designed for...
Dave
ID:	1593731   Click image for larger version
Old 04-14-2011, 12:00 AM
  #540
Rob Howarth
Dave,
Leave them to it. We know it works fine, just like all Flash owners and the majority of potential ones.
Mine's a good'un and works perfect.
Rob
Old 04-14-2011, 01:20 AM
  #541
dirtydingus
Hey Dave
Thanks for the input and it is well received. It would seem that you definitely know the Flashes well. I am a big fan of Carf and was in no way bashing them it's just a minor concern. I have the Comp Arf gee bee and like it alot. With hundreds of hard flights on it I can testify that they make well engineered product.
Now, off to the field for the test flight.
Jim
Old 04-14-2011, 02:00 AM
  #542
Dave Wilshere
Rob...QED hey!
Jim
Enjoy the test flight, it's a great model. Yes, I still fly Flash kit #1 (many pictures in the manual are my Red Cheque model) so I have a little experience
Regards
Dave
Old 04-14-2011, 03:44 AM
  #543
icicles
What an endorsement, number one, wow
I am thinking of a Flash and i here people say it is not a good first jet. I'm not trying to start something.
I already have a very quick Comp Arf Spark, so i can't see it being much more difficult?
Yes i haven't played with a turbine, but i reckon i can learn pretty quick
Thats what i am looking for, a challenge and learning something new
Chris
Old 04-14-2011, 04:44 AM
  #544
ricardinho
its a good second jet... all depends on your skill level.... its a very easy jet to fly..i had a classic flash and it was as easy to land as my boomerang elan...
Old 04-14-2011, 04:57 AM
  #545
Mavrik!
Hey Dave
Jim
Why not drain the main tank first and wing tank last? That way you will get every drop out of the main tank?
Mav
Old 04-15-2011, 11:41 AM
  #546
Dave Wilshere
No, the wheel has been invented. The tank set up works fine
Dave...in Scotland
Old 04-15-2011, 02:39 PM
  #547
dirtydingus
Hey guys
Maiden went great! One sweet airplane with no bad habits.
The only thing I changed was the amount of flaps for landing. I reduced it down to 3" which may be cut down even more.
200 mph is very easily attainable straight and level clocked with a ( real ) radar gun.
Jim
Old 04-15-2011, 02:55 PM
  #548
mtnflyer14
mtnflyer14's Avatar
Congratulations on the maiden! I just finished packing the Bobcat and UF in the trailer and am off to Phoenix tomorrow to spend a week there. Hope to fly 3-4 days at Speedworld where the temperatures are 30 degrees higher than here in Colorado Springs and the winds are 30 mph less!
Regards,
Gus
Old 04-16-2011, 01:45 PM
  #549
ricardinho
yes great job on your maiden...glad to see your happy.
Old 04-17-2011, 07:13 PM
  #550
gooseF22
gooseF22's Avatar
Ok, GAME ON..
The Thunderbird Ultra Flash Wing and Tail Kit arrived!!!!!!... Thanks Ray!!..
Observations...
The servo hatch is larger
The Flap hole is still in the wrong place, so I will have to tuck the servo like David did.
The mounts are beefed up
The main former is moved an inch outboard
The main holes are offset
No cups under the struts
Flaps are longer too
Servo slots longer in cover
Mount a bit larger (good for fitting the Dreamworks)
Big bag of hardware
Same quality finish
Time to get crackin...
Oh ya.... soon to be for sale: CF Tbird Wings and Tail....
ID:	1595432   Click image for larger version
ID:	1595433   Click image for larger version
