 KingTech K-80 >
KingTech K-80
KingTech K-80
Old 02-12-2011 | 05:36 AM
  #401
jonkoppisch's Avatar
My Feedback: (162)
Default RE: KingTech K-80
Anyone know when the kero version is coming out and how much?
Old 02-12-2011 | 06:14 PM
  #402
Will there be a kero start conversion for the current propane start engine?
Old 02-13-2011 | 06:37 AM
  #403
My Feedback: (21)
Hello guys,
I believe Barry from www.Kingtechusa.com said the Kero version of the K-80 would be released this spring. I also think he said that there would not be a conversion as the internals of the propane start do not accommodate the kero start.
Barry will chime in on this I am sure.
Joe Lewis
Kingtech
K-80 Owner
Old 02-13-2011 | 07:22 AM
  #404
I got an e-mail from Chuang telling they will be realeased by the end of February after the Chines New Year Holidays.
They are waiting for the new compressors to be able to release it out.
Marcelo
Old 02-13-2011 | 07:45 AM
  #405
My Feedback: (162)
Any idea on the price? I have a nib superbee that I'm thinking about selling and going to the rabbit or k80
Old 02-13-2011 | 09:13 AM
  #406
If I am not wrong they rose about US$ 90.00 for the Kerosart.
Marcelo
Old 02-13-2011 | 01:38 PM
  #407
marquisvns's Avatar
ORIGINAL: Jetpilot24
Hello guys,
Joe Lewis
Kingtech
K-80 Owner
Joe is right. The existing K-80E propane start could not be converted. We are still tweaking on the K-80F before it will be released and the price will be $1,850.
Barry
Old 02-15-2011 | 06:09 PM
  #408
Just to be sure , when registering my new Kingtech, the serial number is engraved in the rear of the can correct?
Old 02-15-2011 | 06:24 PM
  #409
marquisvns's Avatar
Yes Justin, and we have your registration of #494, thank you and enjoy it!
Barry
Old 02-16-2011 | 07:07 AM
  #410
Barry, if you remember, it has been some time now, i spoke with you about doing some R&D for you and Kingtech, I missed your call and work had me very tied up, I am busy even moresonow thati run Hares Hobby Shop. That is a full time job by any means.
I am very excited to be getting my first Kingtech,and cant wait to get her going. Thanks for the quick reply. Looks like the development is coming along nicely.
Old 02-16-2011 | 07:11 AM
  #411
''Any idea on the price? I have a nib superbee that I'm thinking about selling and going to the rabbit or k80''
< Message edited by jonkoppisch 2/13/2011 4:23 PM >
Is it a Superbee II ??
Old 02-16-2011 | 07:27 AM
  #412
My Feedback: (162)
Sent PM
Old 02-16-2011 | 09:50 PM
  #413
lookilook's Avatar
I was wondering if anybody made any changes to decrease the time of the spool up. does this affect any other parameters of the engine?
Old 02-17-2011 | 06:08 AM
  #414
lov2flyrc's Avatar
My Feedback: (24)
ORIGINAL: lookilook
Spool up as in acceleration delay or spool up during the start sequence?
Old 02-17-2011 | 12:02 PM
  #415
lookilook's Avatar
hi Todd ,is spool up as in acceleration delay....its my first jet and after flying most of the timefrom a dry salt lake i begun to fly from a local club and the runway is kinda short and i do ''go arounds'' to find my throttle settings and i sometimes feel that i needher to speed up more earlier.she isperforming excellent as of now and i dont want to change any settings if it will disturbher behaviour. thanks
Old 02-17-2011 | 02:29 PM
  #416
lov2flyrc's Avatar
My Feedback: (24)
You can bring the Accel Delay down to around 8, decel down to 3 without affecting anything but throttle response. You might want to play with the curves in the ECU as well; you have Full-Expo, Half-Expo and linear settings to try.
Todd
Old 02-18-2011 | 12:20 AM
  #417
lookilook's Avatar
Great Todd, thanks, i fly linear now, accel delay 9 and decel 4, will change them and see how it goes.</p>
Old 02-20-2011 | 05:13 PM
  #418
Hey guys I tried starting my engine today but had some issues, it isn't getting fuel for some reason even though when I do a pump test with the fuel line disconnected it pours out in a steady stream with no air bubbles. I'm using a regulated valve on the coleman green propane bottles and it definitely has ignition just when it goes to fuel ramp nothing happens, it will reach 9800 rpm but it's only running on propane and when it times out it reads "Weak Gas" on the GSU? it doesn't say anything about that in the manual so can you guys give some advise to a turbine rookie please it would be much appreciated. Regards Justin.
Old 02-20-2011 | 06:58 PM
  #419
marquisvns's Avatar
ORIGINAL: JLink125
Hey guys I tried starting my engine today but had some issues, it isn't getting fuel for some reason even though when I do a pump test with the fuel line disconnected it pours out in a steady stream with no air bubbles. I'm using a regulated valve on the coleman green propane bottles and it definitely has ignition just when it goes to fuel ramp nothing happens, it will reach 9800 rpm but it's only running on propane and when it times out it reads ''Weak Gas'' on the GSU? it doesn't say anything about that in the manual so can you guys give some advise to a turbine rookie please it would be much appreciated. Regards Justin.
Is this Justin? You wanna give me or Todd a call?
Barry
Old 02-20-2011 | 07:23 PM
  #420
Yeah Barry it's me Justin, I e-mailed you about registering my engine, Ill give you a call tomorrow.
Old 02-20-2011 | 07:27 PM
  #421
Hi Justin, i am Justin also so lets not get confused.
Have you checked the pwm rate for the fuel pump? if the start rate is low enough it wouldnt have time to ramp up in time, but it would be very low to cause that. sounds like the pump is good but how much flow you have is the question. If the fuel is flowing into the line at startup then it may be a different problem alltogether.
You dont by any chance have the lines reveresed in the quick commects, i.e. kero line in the propane and propane in the kero by any chance?
Regardless, you best option is to give Barry or Todd a ring, very knowledgeable and quick to help.
Thanks , Justin Malone<br type="_moz" />
Old 02-20-2011 | 08:07 PM
  #422
Yeah lets not get confused, I'm Justin Link. Fuel and gas lines are correct, it will run on the propane but when it goes to fuel ramp I noticed that no fuel is flowing into the engine, I do have a ball valve on it but I made sure to open it prior to starting. What rate should it be at? I'm running a box stock setup so it's set at whatever the factory put it at, the pump seems weak to me though, when I initially tested the pump to fill the line it took quite a while to suck up anything then when it finally did it moved pretty slow to the cup I was draining into.
Old 02-20-2011 | 09:11 PM
  #423
Here is the info I pulled of the GSU
Pump Start Point Auto+2
Pump Start Ramp008
Glow Plug Power2.1V
Start Gas070%
Starter Power at Ignition090
Ignition Max RPM5,000
Min RPM3,000
Preheat Time2.0 Sec.
RPM Gas Off23,000
Starter Power at Fuel Ramp110
Start ModeAuto Gas
Old 02-20-2011 | 09:25 PM
  #424
this unit, where did it come from?
Also what fuel pump is on it? If it has a black fuel pump, its a stock kingtech unit, while if its a flightworks unit it will say so on the unit.
the settings look like it should run so im not sure. i have seen a few fadecs go bad from extended pump testing. If the pump was slow to start and pumped poorly you may try breaking it in but i just dont trust a questionable pump.
time and time again i trace problems back to the pump.
Old 02-20-2011 | 09:31 PM
  #425
I picked it up from Dreamworks and it has a Flight Works pump on it.
