 KingTech K-80 >
KingTech K-80
KingTech K-80
Old 02-20-2011 | 09:52 PM
  #426
Default RE: KingTech K-80
Definately call Todd. Let the gurus work their magic.
Old 02-21-2011 | 03:38 AM
  #427
My Feedback: (21)
Just had this video sent to me from a friend. It is a Reaction 54 with a Kingtech. Good combo for starting into jets.
http://www.youtube.com/watch?v=7ijWMze-VEE
Joe Lewis
Kingtech
K-80 Owner.
Old 02-21-2011 | 04:46 AM
  #428
I have a P-70 now, does anyone else that has a King tech ever had a a P-70? And if so whats the differance?
Frank
Old 02-21-2011 | 05:23 AM
  #429
Flynstuff's Avatar
My Feedback: (29)
Big difference.. The K-80 has more power By a couple pounds and the throttle response time is much faster than the P70.
The K-80 also has a lifetime warranty.
You can also run it on diesel and 3% oil so it is cheaper to run.
The P70 is a solid turbine, just old technology.
I think You would be very pleased with a K80
Old 02-22-2011 | 04:27 PM
  #430
I took my K80 in to have Barry check out the problems I was having and he had it diagnosed in about an hour, turns out the ecu was bad and he replaced it right on the spot! Barry is a great guy to deal with and put forth every effort to get my engine running properly, my engine runs perfectly now and I can't wait to get it in a jet now. Thanks again Barry for the great help and support! Regards Justin Link.
Old 02-22-2011 | 04:59 PM
  #431
My Feedback: (106)
Barry is spot on. I will be installing my new one sometimes this spring!!!! Roy
Old 02-22-2011 | 06:12 PM
  #432
AndyAndrews's Avatar
yeah, those fadec ECUs.... not a fan. The turbine is great though. Can't wait to see them come out with their own ECU.
Andy
Old 02-26-2011 | 06:46 PM
  #433
Okay guys, especially Todd and Barry. Got the unit set up for test, K80 e. Ready for the first start, step one - tx learn. well ecu wont learn anything. When trying to go through the tx setup proceedure, I cant get the fadec to recognize any throttle position.
By going into the second screen menu the signal reads 0000u and 100%. You know whats going to happen when it starts at this setting?
Checked out the radio. futaba 10c, checked both normal and reverse servo direction , and also plugged in a servo to the throttle port.
transmitter also works with all my other rx's and planes. Bad ECU? Bad Luck? Let me hear something good.
If you have the connections installed into the turbine and all leads plugged in the unit will attemp to start directly after you just cycle the screens in the tx learn menu. Consequently, If you dont have throttle channel control you cant stop the startup procedure.<br type="_moz" />
Old 02-26-2011 | 06:57 PM
  #434
Flynstuff's Avatar
My Feedback: (29)
Did you try checking the throttle connection to the RX?.
Also Futaba radios are normally reversed.
Old 02-26-2011 | 07:01 PM
  #435
Hi Jeff, I assume you mean the male to male from the ecu to the rx?
If so yes i did and I cant get any signal to transmit but the hdt will power up when the rx lead is plugged in so it must be getting power but not signal.
Seriously aggravating.
Old 02-26-2011 | 07:29 PM
  #436
You need to reverse your throttle channel first. Most of ecu are set-up for jr style signal
Old 02-26-2011 | 07:31 PM
  #437
Check to make sure the rx lead is plugged into the thottle port and not the aux port on the ECU.
Old 02-26-2011 | 08:15 PM
  #438
My Feedback: (60)
Hey Jeff - how u doin' bud? Do you know when the 140 is going to be out? Emailed and left a message for Barry but haven't heard back from him yet.
Thanks man
Spence
Old 02-26-2011 | 08:26 PM
  #439
Flynstuff's Avatar
My Feedback: (29)
Spence, hope all is well.
Barry is at the factory For the next couple weeks.
Im sure he will know more about the release date when he returns
You going to the field tomorrow?
Old 02-26-2011 | 09:15 PM
  #440
marquisvns's Avatar
Guys, Jeff is right. I'm currently at the factory in Taiwan working on engines and get to know our new 300kg fully computerized balancing machine that's going to be shipped back to the states.
Justin, please give Todd a call or write me an email with you phone number and let me know the best time to troubleshoot.
Spence, the 140s are coming along great. They are to be shipped out next week, and I will have them in stock in Cailfornia.
Cheers,
Barry
Old 02-26-2011 | 09:37 PM
  #441
Not a problem Barry, I have young children so anytime the sun is up is a good time to troubleshoot. by the way I think I have one of the faulty fuel pumps.
The wiring and tx issue solved i began the start sequence. fired up smoothly and ran very strongly.
Within 60 seconds the rpm was settled into a good 43000 rpm idle and then i ramped her up to the full rpm , which held for about ten seconds.
after a short time the rpm began to drop and i brought her back to idle. The idle now fluctuated between 43 and 60000.
I shut the turbine down and checked the cool down sequence. all good and i went to dinner.
After dinner I returned to restart and check everything out and this time was greeted with copious amounts of flame and anger from the exhaust..
It was enough that I allmost went for the extinguisher.
It went away very quickly and idle was regained smoothly, Within a few moments the idle became very irratic and i had a flameout.
I notices the bubbles in the line and decided that i may need to run the pump for a minute to check the flow. By performing a pump test I can tell you that the pump was getting hot and would only tricle fuel from it. It soon stopped altogether. I also checked the pump with a battery direct connect, no dice , no pump, no flow, pumped locked up.
So When i do a pump check in the menu I hear the fuel solenoid click on and off when the pump test function is activated.
Old 02-26-2011 | 10:04 PM
  #442
Just curious what was your problem with the wiring? Mosy likely too late but loosen the screws that hold the pump to the motor 1/8 turn and see if it will run.
Old 02-26-2011 | 10:06 PM
  #443
Talk About service! The man is in Taiwan and within 15 minutes of the last post Barry in on the horn and issue resolved.
I picked Kingtech for a reason and that reason is customer service. Things happen and its how they are handled that makes the difference between a customer and a fan.
i am a customer and a fan of Kingtech, Ultimate customer support, Thanks Barry
Justin Malone
hareshobby.com
Old 02-26-2011 | 10:10 PM
  #444
Problem with ecu was a broken signal wireinside the pin, a freak accident no doubt an easy fix, but the pump , not so easy.
Old 02-26-2011 | 10:17 PM
  #445
Don't worry barry will get it sorted ASAP and you will be very happy with the turbine.
Old 02-27-2011 | 04:30 AM
  #446
My Feedback: (21)
ORIGINAL: jmalone1982
Jmalone.
One more thing you might want to check. With Futaba and the ECU, You need to set your throttle travel adjustment or I think Futaba calls it ATV to 125%. Relearn the transmitter and give it another start. I understand the pump issue to and Barry will make it right for you.
Joe Lewis
Kingtech
K-80 owner
Old 02-27-2011 | 09:07 AM
  #447
My k80 was acting I'm a similar manner too, it was surging from 45,000 to 60,000 and would not go full throttle, turns out it was a bad ECU but like always Barry took care of it right away and I now have a great running and very easy starting engine. DEFINETLY a fan of kingtech and barrys service
Old 02-27-2011 | 10:27 AM
  #448
My Feedback: (60)
Thanks Jeff and Barry! Barry, please give me a call when you get back to the states.
Thanks fellas!
Spence
Old 03-02-2011 | 04:57 AM
  #449
jonkoppisch's Avatar
My Feedback: (162)
Will there be any of the k80 F versions at Florida Jets?
Old 03-03-2011 | 11:45 AM
  #450
My Feedback: (162)
Yes, no, maybe?
No one seems to be here or at kingtech
I'm interested in the K80
What is the difference in the flightworks pump and solenoids vs the original units from kingtech?
If anyone has one NIB with the flightworks pump I'd be interested.
I noticed that it also needs to be less than a year old or there's a $150 transfer fee...
