RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 03-11-2008, 09:00 PM
  #3826
Pexeter
Default RE: Thunder tiger ST-1
These engines only last around 10 gallons? Man this hobby just keeps getting more and more expensive! Where do you think the best place to go is that would have screws that small?
Old 03-11-2008, 09:02 PM
  #3827
ericem
ericem's Avatar
ORIGINAL: Pexeter
hardware store,home depot, hobby shops.
trust me 10 gallons is alot of fuel.
@revo lol I am not married don't need to worry about that. Just my mom *****ing about why there are so many packages at the door
Old 03-11-2008, 09:06 PM
  #3828
JChrisjohn
JChrisjohn's Avatar
if you would lean her out a little that 10 gallons would be like 20 and 10 gallons last a good while, remember you are turning 30,000 plus rpm's be happy with 10 gal. you can mix your own fuels for about10-12 per gallon but you have to make like 12 gallons at a time since nitro only comes in min 5 gal. incriments, well at least where I am at.
Old 03-11-2008, 09:22 PM
  #3829
Darkfae
Anyone ever try running Proline MT's in the back and MTR's in the front? I noticed the MT's are a little wider. Seems as though it would work quite well.
Old 03-11-2008, 09:31 PM
  #3830
ericem
ericem's Avatar
Someone asked that question on the LSTforums! I wonder. If you had a problem loosing the rear end I can see it being a solution.
Old 03-11-2008, 09:45 PM
  #3831
Darkfae
I'm gonna try it. I have a brand new set of Bowtie MT's, and MTR's. I can always throw the crimefighters back on if it handles awful.
You can see how much more sidewall the MT's have.
ID:	901424   Click image for larger version
ID:	901425   Click image for larger version
Old 03-11-2008, 09:58 PM
  #3832
ItchyBum
I dont think that would work too well Darkfae. Technically the heavier tyres on the back will drag more and unload the front wheels to 12 inch dinner plates. It might also work well, worth a try since you already have the tyres
Old 03-11-2008, 10:28 PM
  #3833
chedster
Hey Jombo what hub extenders did you get?
Old 03-11-2008, 10:31 PM
  #3834
jombo
jombo's Avatar
who said starter box ...... there evil i tells ya anyway i got the stock motor back in and i am just going to run it this way for now untill i figure out how to get the bump start to work without melting the plactic contact plate.
Old 03-11-2008, 10:38 PM
  #3835
jombo
jombo's Avatar
ORIGINAL: chedster
there actually the mugen hexes and nuts to go with them it was around 50 bucks for the set
http://www.amainhobbies.com/product_...oducts_id/7535
we shall see if there worth it but they do make the truck stand out thats for sure
Old 03-12-2008, 01:18 PM
  #3836
grimespdx
Hey everyone, I was just wondering if a sts .28 would be a drop in for my st-1? someone is offering it to me in a trade, and I was just wondering if its a direct replacement or if not, what parts are needed to make it fit.
thanks
colton
Old 03-12-2008, 01:21 PM
  #3837
ericem
ericem's Avatar
Yup direct drop in. The .28 is not bad. It should be faster then the stock motor in different power ranges. Quality wise the TT .28 is much better built.
Old 03-12-2008, 01:25 PM
  #3838
grimespdx
well considering im trading away my 3.3 max possibly for that engine and a used savage. I might have to make the deal.
Old 03-12-2008, 01:44 PM
  #3839
ericem
ericem's Avatar
Sounds like a deal to me.
Old 03-12-2008, 02:07 PM
  #3840
chedster
Well I picked up a SW v2 and a TT 2035 pipe. Should be a step up from the axial .28. Almost bought the jammin .28 but the GF said I could get the SW plus a pipe or the only the jammin. It should be here tommorow, may break it in this weekend if studying for finals does not get in my way!
Old 03-12-2008, 02:33 PM
  #3841
madmax22
madmax22's Avatar
i dont like to run lean b/c its like rrrrrrrrrrrrrrrrrrrrrrrrrrrrr at idle. i try to get it a perfect as I can I hate bogging and slowness. I get mine to have a good smoke trail and a fast take off.
Old 03-12-2008, 02:36 PM
  #3842
ericem
ericem's Avatar
I usually run my high speed more lean and low speed more rich so it doesn't have that high pitched idle.
Old 03-12-2008, 02:38 PM
  #3843
madmax22
madmax22's Avatar
might try that.
Old 03-12-2008, 04:57 PM
  #3844
Pexeter
PLEASE tell me these need to be stretched over the wheels or they expand or get aired up or something. I bought badlands and as you can see they are way small, I got the ones for a 1/8 truck. I want to make sure these are the right ones before I open them:
Oh, and I found out where that mysterious screw broke off...maybe I should just super glue it back in, it wont thread because of the broke off part stuck in there.
Old 03-12-2008, 04:58 PM
  #3845
madmax22
madmax22's Avatar
looks like you got the buggy tires.
Old 03-12-2008, 05:02 PM
  #3846
Pexeter
ORIGINAL: madmax22
Thats BS, they were the only ones listed under 1/8 scale in the wheels and tires section. Im not blaming amain, but i've bought 2 ST-1s, accessories for both in less than a week. I ordered the right wheels with this order, didnt they think, I'd better check with him to see if this is what he wanted, these tires wont work with anything he's bought??
Old 03-12-2008, 05:38 PM
  #3847
chedster
Ya you want these ones, look under monster truck tires for all truggy tires on amain
http://www.amainhobbies.com/product_...oducts_id/7585
Old 03-12-2008, 06:18 PM
  #3848
ska8erj
hey im switchin to 30% odonnels from 20% odonnels.
and it wont start and im a noob at tuning so how should i tune it?
Old 03-12-2008, 06:19 PM
  #3849
JChrisjohn
JChrisjohn's Avatar
well my steering sucks now withe the shimms in the back it turns so shard it just flips over, I hope this does not happen when I swith back and add the steering mod. also when I run on my high traction surface,(really short grass) my fronts ballon bad, at least the front right, will it be better on dirt.
  #3850
madmax22
madmax22's Avatar
did you put the spacer things under the head?
