the hyper st PRO thread!
#301
Hey PBW, i guess if u just bash get the xtm backplate. less equipment to carry ard. im still trying to figure out what to do with the center diff mounts. tested the braking just now i guess the stock brake pads just dont cut it. i'll try the jammin fiber disc and see if its better.
btw, guys, whats the standard length of the pressure tube(exhaust) for the hyper st?
#302
Pictures pending, i'll send them to your mail....but for what i'm looking at the pictures, you are braking more the rear tires than the front tires....you should pull the arm that pushes the front pads more to the back, i don't know if yoy understnd me...but in another way...from the servo goes a stick that pulls the stock that push the fron pads, that stick you should put it a bit backwars, or pull it more to the engine side, then the rear one you could push it a bit backwars, so it could brake a bit better. Real cars brake in average 70% front 30% rear (for a reason of weight transfer), 5% more or less, (now with the abs brakes these could be a bit modified but is always in that range)
Maybe that way you could improve the breaking of the truggy....
#303
ORIGINAL: low_blow_joe
hey guys.. heres what i've done to my hyper st RTR.. ok dont chase me away to the RTR thread please.
guess the pro-thread got more hits. hahaha. btw ive planted a jammin .28 together with a tsais M32 hard anod truggy pipe. managed to run it yesterday, man the combination rocks! the truggy handles good, and turning is as good, if not better than a crt. I use to own a CRT i sold it cos waiting for the X2 to be launched.. and meanwhile got this hyper st to relieve my truggy craving. Ive done the hyper8 battery mod, used 8.5 engine mounts and also upgraded to cnc knuckles. I switched to a hyper 7 front brake cam, didnt like the stocker and use a cnc hyper 7 center top diff plate. still got problems with my braking. the plastic flex real bad. i can even flex it with my fingers.. i intend to race this truggy and my driving style is i do alot of hard late braking.. i guess i need a solution to this.. anybody can help me out. thanks in advance
#304
ORIGINAL: rologti
#305
Hey guys I know its not the Pro version but I am getting the RTR version in pretty soon and would like to know what you guys think of the MacStar 28 that comes with it? what do you guys think should be on the top of my list of upgrades? thanks guys
#306
ORIGINAL: rican25
btw, will the new '0' offset LPR tyres fit the hyper ST?. or should i get the half offset. i prefer '0' offset but unsure if it will touch the arms when steered..
#307
I've spent most of this morning installing the engine(LRP from my Muggy..) and trying to get the linkages all set up..
I HATE LINKAGES.
Anyway, I need to go find an alu Hitec servo arm for steering, AND I guess also the servo arm for gas/brakes as the stock one doesn't work on my 5945 either.. I've been experimenting with different plastic arms that came with previous servos, but none seem to work or have the right holes or whatever... Question is, should I also get alu for that too? Thanks..
I HATE LINKAGES.
#308
OK, well, it's all together now.. Only think I have yet to do is sort out the linkage... Got it set up so it works, but there's too much brake drag at idle... I'll have to figure that out somehow.. Also, just have plastic servo arms on for the time being.. Need to threadlock a screw or two, then it's ready to go...
Now that the engine and everything is in, it is sagging a good bit more, so I guess 60 wt was about right - just need to put in some spacers if I'm going for some air..
Here're a few pics...
(I'm waiting for an XTM backplate to come from the States so I can put the Mach in.. It's got the LRP from my Muggy for the time being..)
One question - when I hit the throttle servo, there seems to be an awful lot of flex in the carbon servo plate... Normal??
Thanks..
Thanks..
#309
hey PBW, check your EPA for the throttle.. make sure its not forcing open the carb when u pull the throttle. mine set abt 70 %. nice paint job btw.. nicer if u can adjust the white balance of ur cam..
#310
Hey, I just experimented with the EPA - set it to 80, then 70, then 120... None of the above made any difference... Brakes are still dragging at idle..
I would say I must just have to loosen the scews holding in the brake discs, but I did that on my Muggy too, and still don't have any brakes...
ps As far as the camera, it's my cell phone, which is still newish so I don't have it all figured out yet.. The day really did look like that though..(typical northern Europe grey..)
#311
Here is some short footage from last weekends race. I'm running the yellow/orange Hyper St Pro.
http://www.pro****-racing.org/NCRC-Test-128-85.html
#312
Been fiddling with the linkages again, and think I have it narrowed down to the rear brakes.. Seems no matter what I adjust, whether on the truck or the radio, the rear brakes still drag.. Been looking around looking for close up pics of the center diff with linkages, and saw one pic where the guy had bent the little looped pin that the linkage goes into on top of the center diff... Might try this next...
There is no drag when I hold the gas.. When I brake the braking is too hard and abrupt..
Front braking isn't yet perfect either, but there's no drag with moderate but not strong braking..
If somebody could post a close up pic of their linkage looking right down over the center diff and throttle servo, that would be cool...
Thanks..
Thanks..
#314
Sorry, can't help ya.. I filled mine basically nearly to the top, so that they would still fit together without having oil goup out all over the place..
I didn't threadlock the screws though.. Is that bad??
And I have a new question too..
After MUCH fiddling, I think I got the gas/brake linkage sorted..
But now to steering - I just bought an alu servo arm for steering, but it's several mm shorter than the arm supplied in the box... What does this mean, and if anything, what should I do about it?? Thanks..
#316
FL
ORIGINAL: PatrickBW
#317
HELP!!
Just building my first diff and Ive hit a problem already!
There is a shaft which drops through the diff case and then through the drive shaft, but it doesnt look secure - like it may slide out and interefere with the diff case, Is this right?!?! Does it need securing in the middle somehow?
Sorry for the crappy photo
#319
ORIGINAL: vnmsgt
I had a problem with my hyper not steering lock to lock with the shorter steering arm and I have a spektrum with the settings set all the way up for most steering. I bought a longer one and now it is fine. The longer the arm the more throw it has to move the wheels more side to side.
ORIGINAL: PatrickBW
It's unfreakin'believable that a $100+ servo like the 5955 comes with such a cheap-a.ss C.RAPOLA screw in it...
Still don't have it sorted - AND my finger's busted, soon to possibly shed a fingernail....
Is it normal that alu servohorns are so hard to fit to the servo?? What a PIA....
#320
Ok, next problem
At the crown gear end of the diff the manual says to put a 13x16mm washer between the drive shaft cup and the bearing - But the washer is big enough to slide over the top of the cup, is the manual wrong?
#321
FL
ORIGINAL: PatrickBW
I am having one H.ELL of a time setting up this d.amn steering... I think I do in fact need a longer servo-arm.. As well as a new servo-screw..
ORIGINAL: vnmsgt
ORIGINAL: PatrickBW
#323
FL
ORIGINAL: droidswarm
Please give me a hand - Ive got a half built diff!!
#324
Hey guys I know its not a pro but I still need some help with my Hyper ST. I just leafed through the instructions and saw the little ammendment page they sent along with the truck and I didnt see any instructions to where to set the carb for the first time, it didnt say that its factory set or not that I saw at least. any help would be nice. thanks in advance.
#325
FL
ORIGINAL: rican25
