- First Auto's
- Raptor 50 First Flight
- Furious with Thunder Tiger's crap parts
- thro-rudd and thro-ail. mixes?? need professional info please ATN HELI PILOTS
- MD 500FLYS !!!!!
- Flyboy in Plane crash
- raptor 50 clutch?
- Installing cooling fan on engine Raptor 50v2
- Engine mount bolt broke off.
- Raptor 50 V2 engine mount
- Tail servo
- I want the best camera for my heli any sugg.
- Fuel will not suck up pipe to start engine now.
- OS 50
- JR XP783 Radio Setup
- Auto boom strike.
- After-run engine oil
- Throttle curve again
- Engine shaft/ Clutch binding...please help!!
- heli seems to fall out of sky
- New rappy 30
- R50/R60 Engine Question
- inverted bogging
- raptor 30v2 tail drive pulley-check your set-screw!!
- Custom Canopys
- R50 V2 canopy clearance issue!!!
- header tank install question
- HOVERING
- IDLE Up
- Raptor 60v2
- Servo Upgrade
- Stuck 50V2 clutch
- scale huey fuse for sale
- where to buy
- Gyro 401 AVCS - NORMAL HH
- How To Balance a Heli???
- Raptor 60 Tail Blades Size?
- OS 61 SX-H Needle settings
- TT-39 Break In
- Raptor 60 starting shaft will not turn
- Almost RTF !!!!
- Tail kicks left while hovering
- TT50 low end needle mod
- Engine Temp and mixture setting
- OS Max 50SX-H 2-Stroke Ringed Heli Engine
- jr radio
- bought the wrong fuel tank
- R 50V2
- raptor 50
- Raptor 30 V2 Clutch / Bearing
- 30 or 50
- Crashed today
- Difference between Raptor 60 and 60 V2?
- First Loops
- Bought raptor 60, peice together the rest
- glow plug relocater question
- Thanx to you guys , this happened
- tail keeps spinning
- What Size Mast Tickness
- thunder tiger .36 Temp
- Best Gyro/Servo Combo for Rappy 70?
- MD 500 !!!!!!!!!!!!
- engine
- Flew my Raptor 90SE
- Raptor MD 500 Decals
- Raptor 30 10X settings
- heding lock gyro ?????
- Where i can buy a raptor 50 in New York? Queens is better
- is tail servo noise normal?
- GV-1 Gov set up for Raptor 30
- tt 39 muffler leaking
- kinda simple collective question
- What would you recommend
- Raptor MD 500
- 60 Tail rotor
- New blade, heli shake
- Raptor 60 V2 Screw kit???
- I can't believe it
- OS 50 tuning question
- common crash parts Raptor v2
- G3 Starting out heli
- set up questions again
- New Raptor 30V2 Pilot
- Mixture
- Which gyro is better?
- washer
- R50 V2 wah wah's!!
- Raptor 60V2 or 90SE
- Getting a R50v2
- Is this a problem?
- servo link arm problem futaba T7chp
- Raptor 30 v1
- Right swashplate?
- Which one?
- scale fuse for rappy 90?
- electronics pics anyone?
- Problems with clutch
- 3d question
- did I flood engine
- Raptor 30 boom length
- Painting the Raptor 30 body
- Newbee and expert maneuvers
- 30 to 50 conversion is it worth it?
- Reflex sim/ reality check
- Powered up Raptor for 1st time
- What Gyro/Radio for a Raptor 60 V2?
- Raptor manual question
- Raptor 30v2 - Need Help!
- Futaba GV-1 Governor???
- Important up-grades?-Raptor 60V2
- Raptor60V2-Tail Torque Tube,pinned ends???
- Raptor V1 upgrade to 50 V2 Help
- Finally got the bird.
- Raptor 50v2 and a good radio
- hex starter?
- Raptor 60 paddle help
- using the jr 8103 with the gy-401
- Raptor 90SE head speed???
- Tail rotor blade max size
- need a good flight sim
- Play in tail gear-main shaft?
- RAPTOR 30 v2
- raptor parts
- Just got my raptor 30 V2 TT39
- RX Battery Connections
- First auto today...
- Control Movement Issus
- What Transmitters do you guys use w/.....
- Raptor 30 OS32 Engine Mount Question
- Kudos to TT and their Raptor
- Which Blades?
- Throttle problems
- R 60 MR thrust bearings kaput
- R30v2 First Crash
- first loop ends in hole in the ground
- Sticky Tail Rotor Pitch
- Paddles
- Does any one know about converting a Raptor 60 V2 to a Gasoline Helicopter?
- threading antenna?
- servo buzzzz
- raptor v1/ v2 difference ?
- Blade RPM's
- Funkey 50 size Airwolf/Raptor V50
- What Sevos?
- Play In Rotor Head
- Expo/Dual Rates
- Rx Pack
- What is the Best RC Heli Mag
- heads spinning at 1800 but tail rotation is slow
- Header Tank??
- Raptor 50v2 clutch problem
- Do you need a governor
- New to Helicopters
- Do base loaded antenna's work as good?
- lov'n life!!
- Raptor 30 50 or 60 ???
- Raptor 30 V1 on 9303
- Clutch shoe bolts broke. Why?????
- GY501 w/ 9253 on Raptor 90..wagging?
- governor spring flight problems
- periodic shake while hovering
- Bad Shakes Wile Hovering
- Raptor V1 V2
- Which servo to Raptor 30 V2?
- Half roll to loop??
- Forward Flip
- Autorotations-Advice needed
- Building a Raptor 90 from scratch How hard would this be?
- R50 V2 shaking during spool up!!!
- Checked runout...now what?
- Balling up the Raptor - Crash Video
- What temps on a .50 SX-H Hyper?
- Overspeed on the head?
- Observations flying yesterday, R50 V2
- HeliG & Maverick Upgrade Parts
- Lesson Learned!
- Parts left over???
- PAINTING BLADES ON A RAPTOR .30
- How can I determine a bad servo?
- First time for everyone...
- RAPTOR 30 v2
- Throttle Jockey pro acting up
- Combining original Raptor 60 with V2 parts
- raptor tail kick
- tt39 engine help
- will this work with this
- Help needed seeting up idle - up1 on R50V2
- R60 first flight !!!!!!!!!!!!!!!!!!!!!!!
- raptor 60v2
- when to change Ball Link?
- FIRST FLIGHT (Raptor vs. G2)??
- raptor collective pitch arm
- HELI PRACTICE TABLE ???? newbie
- Raptor 50 with os 50 hyper clutch slipping???
- raptoe 30 v2 engine probs
- Raptor 90
- Autos with Raptor 30 V2
- Maximum size Blades for a Rap 30 V2
- Suggested Servos
- .52 four stroke on .30 raptor?
- Raptor 60 ARROW ??????
- What's wrong with this picture?
- Stalling servos/swash plate and engine bogging on R50 V2??
- R60 Tailshaft pin
- Scale body for a Raptor 30 v2
- remote glow adapter
- Carbon Fiber or Fiberglass Canopy???
- JR GT490 gyro
- Rotorhub broke off my Raptor 90 in flight
- Header Tank causes lean run Help?
- I bought as a First hely a Raptor 60 V2....Help!!!!
- HOVER WOBBLE
- Raptor50 with os 50 Hyper
- R50 V2 w/TT50 bogging down???
- Jr Reciever
- Rap90 (OS) starting difficulty
- best fuel
- Where can It be downloaded the Raptor 60 V2 Manual?
- Tethering the Heli
- Engine temp question on Raptor 50v2/ os.50?
- gyro question
- Can I use a Futaba GY-240 on a Raptor 60??
- 50 V2 Manual anyone?
- What's in these bottles?
- 4th newbie flight almost bad loss, any clues welcome
- Raptor 30V2
- Can use a Futaba GY-240 Gyro on a Raptor 60..?
- First time hovering ! Now need parts....Hellp needed
- Raptor stating trouble. Engine shaft wont turn
- Raptor 30 setup questions
- 30/60/90 Fuel consumption question
- Dumb Question
- TT 39 Engine
- R50 V2 glow plug extension???
- Throttle curve for a Raptor 50 and OS 50 Hyper
- raptor 30
- Raptor Revamp
- need a setup for raptor 50 and eclipcse 7
- Raptor 60 kit assembly??
- Has anyone had this problem with Raptor 50v2?
- R50 built in Pitch Gauge Question?
- Pitching up in FFF???
- Newbie: how to setup throttle ?
- Raptor 60 Flybar Subassembly
- Best gyro for newbie
- Engine washer.. Yes,,, or No?
- 90 Conversion
- tail trim
- worth while upgrades
