PDA
View Full Version : Thunder Tiger - Raptor 30, 50, 60, 90
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. Multigov Setup
  2. Weird throttle servo behavior
  3. Engine Mounting question
  4. Newbie, what should I get
  5. tt39 non starter
  6. 120 or 140 degree ?
  7. First Flight Tomorrow
  8. Is this a good receiver for my Raptor 50??
  9. 30 clutch
  10. Raptor 30 wah wahs
  11. Receiver battery help for a Raptor 50??
  12. Raptor 50 O.S. 50 SX Hyper Engine Problem
  13. Can I use this servo for the throttle on my 50?
  14. Raptor 50 V2 TDM Head Question
  15. OS 37 engine purchase
  16. Raptor 30 Engine swap
  17. tail servo
  18. raptor 50 titan trouble
  19. total pitch too low how to make more
  20. Raptor 30 roll rate???
  21. TT39 Issue
  22. Thunder tiger pro 39 muffler gasket
  23. govener or rev limiter
  24. Is this raptor a good deal?
  25. Tail chinese weights
  26. question about enough voltage to fly my titan....
  27. What engine?
  28. Stock cooling fan removal tt pro 39 engine
  29. Head Speed Trouble and Tail Drift!!
  30. How a Rotor head works
  31. Stock TT 50 Pro-H
  32. Is it possible or worth it 50v1 to 50v2 conversion
  33. Any fliers near Cheyenne WY?
  34. What should I get?
  35. 0S 50H VS TT53 REDLINE ENGIE
  36. battery- 4.8v
  37. Revolution brand, flybar control rod issue,
  38. Raptor 30 v2 to raptor 50 titan
  39. Stock TT Rappy 50 Tank and Engine mount
  40. spektrums AR7100R heli receiver
  41. R50 blade pitch issue, needing help,,,
  42. Raptor 60 Gear ratio
  43. Converted R30 to R50 shaking tail intermittantly.
  44. Harrdened flybar
  45. Lost part and bearing
  46. raptor 30 to raptor 50 titan
  47. new raptor
  48. Tx to RX compatibility
  49. Raptor 50 Canopy extension
  50. OS37 mounting in a raptor 30, question.
  51. Raptor 90 3d Question
  52. Where to purchase raptor 30 landing skids Montreal,Quebec araeaCanada
  53. Gyro and Radio question
  54. titan pitch range...
  55. raptor titan in a plane?
  56. 2nd tt-39 rod failure during initial ground runs.
  57. New Raptor 30 engine break-in question,
  58. Racheting Tail Servo, New Raptor 30 V2.
  59. New Raptor 30 V2 rtf issues, need advice.
  60. Carbon Fiber Blades
  61. multi blade or flybar less heads for R60/90
  62. futaba 401 tail drift right
  63. Raptor 30 or 50?
  64. New to Raptors, need help. Engine related I think.
  65. Engine help please.
  66. Raptor 90 Advise
  67. For Sale?
  68. Titan 50 value
  69. Raptor 30 Composite blades
  70. raptor 30 fuel line setup
  71. Raptor 30 - putting an OS46 without Upgrading Heli
  72. Raptor 60 vs. Raptor 90
  73. Spektrum DX6i For raptor 30 V2
  74. raptor 30V2 29bb vs 49bb
  75. 1/20 scale pilot figures for Titan Cobra?
  76. What next?
  77. YS 20/20 nitro in a Raptor 90?
  78. advantage of push-pull collective
  79. please help, JR servos taken out on rap 60
  80. O.S. 50 HYPER
  81. I have an issue here....
  82. 90 3D or 90SE?
  83. CSM SL 420 Smart Lock Gyro
  84. 60v2 lx max .61, surges and make the tail go nuts.
  85. OS 50 engine cutoff when throttle applied
  86. NEW Electric Pilot here
  87. Raptor 30V2 making noise at idle ?
  88. Rapter 30 v1
  89. OS 50 sx-h (not hyper) carb
  90. Helicopter found
  91. raptor 30 help
  92. Getting into bigger helis...a few questions...
  93. i give up
  94. HS for a raptor 30 v2
  95. Speed up my spin please :)
  96. Engine problems/setup - please help
  97. Raptor 30 help...power
  98. Raptor 30 V2 RTF Combo
  99. question about antena Rx...
  100. t.t. redline .53 info
  101. 20% Nitro Issues on Raptor 30 V2
  102. OS 50 engine problems
  103. Kasama tail case/grips?
  104. New to Raptors HELP
  105. Swash plate HELP
  106. Raptor 50 servo's
  107. Loose bearing
  108. OS 50 SX engine cutoff when throttle applied
  109. Beginner 3D servos
  110. Raptor 50 Ceramic Brgs.
  111. GWS Gyro
  112. raptor 30 V1 and V2 whats the diff ?
  113. Stolen Raptor 60 W/OS70 & DX7
  114. OS 50 engine cut off...
  115. R90 Tail Glitch in the air, Landed safely
  116. Couple questions Raptor 30v2
  117. Raptor Titan/ Hyper 50 question
  118. What should I get next?
  119. o.s. .37 question
  120. raptor 30 comes down with no input
  121. Rappy 60/90 Spindle dimentions
  122. exhaust upgrade
  123. where can I get?
  124. Muffler rec?
  125. Raptor 50 step 4
  126. s3151
  127. double link?
  128. Scale muffler
  129. clutch bell rotate not smooth for raptor 50 titan
  130. Raptor 30v2 OS37 100% throttle?
  131. im almost there need little help
  132. raptor 30 3 point throttle curve
  133. Best fuel for TT PRO-36H/39H(both trashed)
  134. futaba servo question
  135. It's over dead Rapter
  136. What fuel nitro% do you use?
  137. OS Max 61SX - Heim Mechanics for Raptor 60
  138. zenoah 23cc
  139. help before i bang it against the floor.
  140. Is the fuel im useing good?Glow plug question too
  141. dx6 question can you use it with a raptor 30
  142. why does my Voltage drop?
  143. charging my battery....
  144. OS 37SZ-H Muffler
  145. NO MORE WOOD BLADES
  146. how to set pitch
  147. 30% fuel
  148. questions about a 3d flier....
  149. Digital Servo
  150. JR770 3D setup guide.
  151. Battery question for my raptor 30
  152. Another Upgrade Opportunity
  153. Raptor 50 Metal Fan
  154. muffler choice
  155. TT 36 Heli engine - head gasket/shim install
  156. Has anyone ever used Helikraft??
  157. os .37 szh
  158. os .37 szh
  159. Everyone seems to like this fuel so I got some
  160. help with servos
  161. Question about setting a Raptor 30 up for 3D
  162. New to Raptor 30
  163. a doubt while taking the temp of my engine...
  164. What servos are better than what I have now?R30
  165. Thank you mr. president!!
  166. how to measure flip and roll pitch???
  167. roll pitch....
  168. the crash that broke my spirits..
  169. Raptor v1 what is it worth
  170. running 6volts
  171. Raptor 90 canopy
  172. My new video with the new OS.37 and tune pipe
  173. Wish me luck guys..
  174. Hobby Taiwan metal tail hub
  175. TT39 seized and a new tool
  176. Non heli engine
  177. What other size main blades fit the rappy 30?
  178. what happens if I do this???
  179. Titan rotor blades
  180. She flys awsome (hovering pics inside)
  181. My rappy is fixed/pics posted inside woohoo
  182. Fuel tank
  183. making a raptor 30 v2 roll faster...
  184. Titan 50 setup help.
  185. Problem with main shaft?
  186. Cost ?
  187. Raptor30V2 OS37SZ-H Hatori Pipe
  188. trim in HH??
  189. My first bad crash with my rappy
  190. Diagnosis of Raptor 30 Power Loss
  191. Gain vs Piro rate
  192. OS.37..What glow plug to use?
  193. Building Titan 50
  194. pitch angle setup
  195. D/R question
  196. tail horizontal fin
  197. I need cheap main blades for a raptor 30..
  198. Temperature (Raptor OS 50 hyper
  199. OS.37 qurstions?
  200. I took everyone advice about where to fly(video inside)
  201. new to the raptor
  202. rapter 620e or rapter 30v2
  203. Tail Trouble - I'm stumped!
  204. What fuel to use now?
  205. Buying Raptor 50 Titan in Singapore?
  206. GYRO's 240-401?
  207. Engine Help!!! TT39H
  208. Digital 3152 or 9202 Coreless servos
  209. Raptor 30 motor question?Is this true?
  210. My First Nitro !
  211. Jr 770 3D
  212. Upgrading my R30V1 to a R50,need help
  213. Some invert pics
  214. CY Wildcat
  215. Video of my first Raptor 30 flips/invert
  216. crap.. bad day
  217. Raptor 50 - Total Bling Job
  218. Raptor 30 turns left
  219. My first crash with my new Raptor 30 (video inside)
  220. What a feelin' :)
  221. HEADSPEED TROUBLE-LOSS UNDER POWER
  222. raptor 30 inverted autos
  223. RAPTOR 90 SE RTF
  224. Pics of my new painted canopy
  225. OMG,I LOVE my new RAPPY..video inside
  226. Buzzing Noise
  227. Raptor 60 clutch
  228. PAINTING MY MAIN ROTOR BLADES - 550MM WOODIES
  229. I did it flipped ,my raptor
  230. 2nd flight with Video of my Rappy with my new tail servo
  231. I got my new tail servo for my Raptor 30.Did I do good??
  232. Raptor 30 motor upgrade question?
  233. Heli trouble
  234. 50 v2 turned off
  235. Raptor 50 gear
  236. Whats a good tail servo for a Raptor 30?
  237. Clean all them shiney chrome parts with this
  238. Wobbling R50 at before-takeoff speeds
  239. Raptor 30 appraisal
  240. raptor 30 with a 50 size fuselage...
  241. Any opinions for this carbon blades?
  242. My first nitro and I need some advice please(video inside)
  243. what about carbon blades????
  244. Gear Ratio?
  245. New OS .37 problem
  246. Engine tweak
  247. IS this a good place to get the raptor 50?
  248. ENGINE HEAT?
  249. modify TT53 redline benzin fuel
  250. Losing parts midflight
