- Cheapest site online to but a Raptor 30
- Graphics for R30/50 Canopy?
- 30 to a 50 - Blades and Boom??
- airplane engine in heli
- First Time Flying|
- Raptor V1, V2 whats the difference.
- clutch problem
- AFPD R50
- Raptor 50 V2 Servo Installation Question
- Raptor 30v2 os37 with Hatori 415??????
- GOING NITRO
- Flight Sim for raptor 50?
- Thunder Tiger TG-8000 Gyro Questions
- Which pipe on Rap60 with Hughes 500 Defender?
- Raptor Ver1 - Ver2 Parts interchange
- When Should Certain Components Be Replaced?
- V2 50 assembly question #2
- Raprot V250 assembly question#1
- Thunder Tiger 39H with a YS .45 tuned pipe ???
- Raptor 30V2 to Raptor 50V2 questions for all!!!
- Raptor 30 V2 hover problems
- Raptor 60 or 90 for MD-500 fuse
- Is this a good deal.
- Raptor 30/50 canopy mount grommets?
- What size battery, and what format R50v2
- Bad Bearing On 3rd day of flying
- Raptor 90 for Rc simulator Reflex XTR
- Raptor 90 SE with a OS 70
- Flybar control lever ball link location???
- First Flight for me any my Raptor 50...
- Governors
- Metal Tail Drive Pulley
- UPGRADES FOR 50V2
- Fut GY240 GLITCHES.......
- G4 CF's?
- What is wrong with my 30????
- 7 point pitch and throttle curves...
- JR8103, GY401, RaptorV2 30 setup/config
- Unanswered question...
- raptor 30
- Post first flight attempt gyro help please
- OS 70 to 90 Raptor Conversion
- Mavrikk cnc fan upgrade
- jr 8103 heli radio ?
- Driven tail on a 30 V2
- Newbie question
- Raptor 30 V2 Swashplate question
- Rear Servo Mount for R50v2 - Questions
- how do throttle curves work
- 3D rotor speed poll...
- Raptor 50v2 Cluth engaging at very low rpm
- Worlds shortest life span
- TR servo on the tailboom... is this set-up any good?
- Raptor 50v2 Construction Diary (Pictures/56kWarning)
- My new Raptor 90SE
- will aiplane radio work for heli
- 30V2 or 50V2 for a beginner?
- OS .50 Hyper head
- servo Question ? FOR RAPTOR
- Servo Torque for raptor 60
- tt70 vrs os70
- head dampers
- first flight question
- RapE E-Conversion
- raptor shake
- COG of Raptor 30 v2
- Having a problem with pitch of main blades
- Difference between 30V2 and 50V2
- Raptor 50v2
- Raptor 60 fan info wanted.
- CAN I PUT AN OS .70 SURPLASS 4 STROKE AIRPLANE ENGINE IN TO A RAPTOR 60???
- Raptor 30 UAV
- I may still need some help
- Could you measure your Carbon blades for me?
- Anyone Around or Charlotte that could Airbrush my Canopy
- Raptor 60 Clutch Liner
- Cyclic Pitch??
- Which washout hub for R50?
- Heli books
- Newbie here, Hello
- Engine tuning
- Fuel Question
- raptor 90 se -vs- jr vigor cs
- tail rotor input servo ?
- Rear Servo Mounting..
- Radio Comparison
- raptor canopies
- Please Help?
- Heli Helper
- raptor 30
- Possible Clutch problem need help
- Considering Raptor 30
- need help with a 401 gyro
- Pitch Help.
- new engine for raptor .30? need 3d juice!!
- O.S. 61 not idling well
- Thr and Pit curves for Idle up 1 and 2???
- Raptor V2 assembly questions
- Putting a prop on a TT39H engine
- twitchy raptor 30
- How much should I sell it for?
- Ball link... Main rotor balance...
- Crash!!!!!!!!!
- Raptor 30 V2 Decal Sets (rotorgraphics / others?)
- TT39 Running Bad
- Futaba 3010 servos
- Best engine for Raptor 50?
- First Heli... Few questions
- Raptor 30 V2 Bodies
- Simple new guy question
- First flight report
- Raptor 60V2
- Why do I keep coming back............
- Raptor 50 whip antenna mount...
- Tuning OS 70
- raptor 30v2 problems
- Glow Plugs
- OS 70
- Wood Blades
- servo type- Raptor 60
- Raptor 50 or 60?
- JR539 jitter
- Raptor kit with 29BB and ARF with 49BB?
- Oops. Damaged the engine before even getting off the ground
- Understanding the rotorhead.
- From woodies to what?
- Raptor OS 37 installation question
- static in tail?
- R 30 V2
- good deal
- Crash!!!
- Raptor Helis pIctUrEs
- Raptor 30V2
- New Raptor 50 about killed me!!
- Raptor 60 v2
- Raptor 90
- Thunder Tiger site
- Raptor 60 radio tray
- Raptor 30 V2 white plastic parts?
- Were do I get a heli
- Mavrikk Header Tank
- IR Pissed Revisited
- climbout
- Raptor 50!
- Raptor 60
- notchy bearings in tail
- Muffler For tt50
- Why Heli's??
- Clutch stuck
- Raptor part replacement addendum announced at ACE
- Lipo in Raptor 30 V2
- Clutch Not engaging
- raptor-50
- TT50 Break In?
- TT 50 Pro
- Thunder Tiger 39H Pull Start?
- dying engine
- Ace Hobby (Raptor Distributor)
- 6H carb on an OS50 SH-X/Raptor 50
- tt39 query
- Real Engine tests in a Raptor 60?
- is this alright for a raptor?
- Raptor 30 v2 Radio Settings
- Are these upgrading good for my Raptor50?
- Gohbee Stinger thread
- no where to land
- Two Batteries?
- Is this raptor worth it?
- Rotors "jerk" when spooling up
- Complete Bearing set ?
- Hummingbird to Raptor Flight conversion
- Screw sets for Raptors
- Stock Blade Balance
- TT Strikes again
- Oops, messed it up already
- 'Forgot to grease thrust bearings during assembly!
- Which screw
- Good deal for a re-beginner?
- Quick UK rotor head
- Ball linkages "tight"
- SHould I be worried about overspeed.
- Washout Assembly ...
- What servos for beginner - Rap V1.0 30
- Raptor 30 manual
- head over speeding
- Remote Glow Adapter install help
- TG8000 GYRO
- Jitters
- I R Pissed
- Raptor 30 -can it take a TT50
- strange vibration noise
- When to do the blades modification...
- Raptor 30 v2 pitch servo problem
- Can a R50 do the so called "Tic-Tocs' and are there videos on how to do them??
- Free 30 size raptor paddles NIP
- Raptor 30 tail boom construction question
- OS37
- Good price on 50 V2?
- 30v1 vs. 30v2
- Futaba 9001 or 3010
- Thottle Sticking
- Stained Pipe
- radio set up..did i get it right?
- TT39H Engine hassles...
- Thunder Tiger 50 Heli Engine Run In...
- Damper lubrication
- Electric Raptor
- help!!!
- Raptor 30 V1 clutch question.....please help
- Just a Quicky
- Starter shaft Will not spin counter clockwise
- Upgrade from 30V2 to 50V2 Gear Ratio's
- Raptor V1 30 Starter shaft keeps stripping
- Which Temp Monitor does everyone use
- maintanence
- Raptor 90 Setup problems
- Raptor 30 V2 Muffler is Crap
- Heli Setup - Your Guys Final Approval Before Ordering
- Serious wobble ...
- Can over-torque screw cause problems?...
- O.S. 70 setting way off from manual.
- Fingers or Thumbs on the Transmitter?
- Auto Hub making a noise?
- Raptor 60 rotor
- One-way auto-rotation hub locked up!!!
- Weight of Blades and Balancing...
- these servos any good?
- Throttle sticking?????
- raptor 50 + os50 engine.
- Raptor 30 V2 Flybar bend?
- New Raptor 30 V2 ARF and CSM SL 420 Gyro
- How to clean Raptor 30 V2 muffler...
- RAPTOR 30V2 BLADE TRACKING
- Raptor 30 problems
- Raptor 90 flight times?
- Raptor 30 V2 CRASHED!!! What could have happend...?
- 60V2 with OS70 questions
- Gonna get a Raptor 30 v2
- Raptor 30 vibration
- How long...
- New rappy 90 flew awsome!
- Aluminium rear servo tray.......
- 50V 2 tipping forward when descending?
- Two Questions...
- Raptor 50 Pay load and how to increase It?
- Raptor 30 V2 tail problems...
- Loose Exhaust on R50 V2
- Why dont they make it for the Raptors
- Raptor Baseplate
- New pipe on TT39H...
