- Wrong Spindle
- First autos
- raptor90 engine question???
- Throttle servo recommendations
- WHOS GOING TO 3D MASTERS?
- Raptor 30 Tail Blades
- Goofey tracking problem
- GYRO PROBLEM!
- Raptor 60 V2 Best price online??
- Nitro Content
- Wrong blade root size?
- Recommended headspeeds
- Titan Tail Belt
- break in question...first tanks slight problem...
- Raptor 30 V2 - Where to get parts from China or Taiwan?
- slugish tail
- New Head Required?
- ANALYZE MY CRASH!
- doing the raptor 30-50 conversion...
- RAPTOR VISIBILITY!
- what version raptor is this?
- 30 vs 50
- raptor v2 canopy on a v1...possible?
- Newbie just got Raptor 50
- SLOW RUDDER
- R50 Titan body tilts to right but still hovers??
- 600mm on a .30
- Fuel Question
- thunder tiger raptor 50se v2, parts needed
- New Raptor Titan
- Chirping Blades
- motors just stops ?
- BLADE BALANCE R50
- Raptor 30 nose drifts left in heading hold
- DX 7 for a raptor 50... is it good?
- number of channels for governors
- Raptor 30 tail blades
- Not half the battery I thought it was.
- If not the clutch sprung out, what else?
- Whats it worth?
- Raptor 50 engine confusion
- This is for advice right?
- how to post a picture
- Raptor 50 CF blades
- week motor???
- R50 Titan rear tail unit/rotor shaft questions
- Which dampeners to go for??
- Static??
- 2 BOOM FAILURES IN R60-90
- v1 or v2
- never done this
- tuffstruts for titan 50
- Raptor 50 Titan Discussion
- TD tail hub, grips landing gear
- Titan blades wont fold
- Advice: Best way to apply decals
- aftermarket tailcase
- Mini Titan E325 and gyro mount
- titan stock tail ? new canopy
- Best place to purchase raptor e series??
- Painting R50 BODY
- metal frame posts...loctite or no?
- Fuselages
- Put a charge in your Raptor
- Futaba GY401 Titan 50
- G500t gyro, DX7 problems 821 servo
- Good beginner thunder tiger setup...
- canopys
- Raptor 50 engine alignment problem
- max headspeed on stock plastic blade grips
- TT PRO 39H running temp
- RAPTOR 30 PARTS CAD FILE
- Raptor 60 Build Tips...
- raptor .30 v2 PRO VS raptor .30 v2 sport
- favorite starter?
- SHE Flies!
- Gyro 611 ???? Help
- Radix 600's??
- Engine maintenance/care question
- Raptor 30 fuel
- Redoing the Raptor 50_Pics**
- Digital servo voltage tolerance
- GV-1 problems
- voilent shake
- Futaba 9252 on Raptor 60
- Titan 50-some questions(BarracudaHockey)
- Fly bar paddles
- R50V2: Engine mount bolts snapped off during flight
- Gear Ratio for Titan
- Servo ?
- upgrade for raptor 50 titan??
- change from V1 clutch to V2?
- Bell Hiller adjustment
- SETTING UP NEW RAPTOR 60
- Os 91 c spec with pump
- noob titan .50
- Raptor 60 Pinion Gear Assembly Question
- Gyro Help,..
- canopy question
- OS 37 SZ-H Running Rich
- weird wobble? ? ?
- Raptor 3 Interference
- cool canopy
- dampner lube
- mavrikk metal head ?
- Suggested Thottle Curves
- Piro flips!
- PINNION GEAR
- Pleeeaaase?!??
- Poorley Raptor 50
- Erratic servo probs
- servo consensus
- Funkey Jetranger help!
- Dupli-Color Mirage?
- Raptor v30-Tail Hub replacement
- Raptor V30- Second Flight
- raptor 30 noob setup
- best servos and batteries for raptor-90 for 3-D
- Governor Question
- HOOKING UP RADIOS
- best servo's for a 30?
- raptor-90se collective pitch frame
- Can you look at this heli and tell me if I should get it!!!
- upgrade question
- Raptor G3 Downloads
- best sim?
- On board battary meter
- OS 55AX in Raptor 30?
- 600mm blades
- Torque tube conversion for Raptor 50???
- Titan 50 maidened
- Got the DX-7...just need the bird
- raptor 30 with os 37 pipe question
- aero magnum 15% instead of 20% heli
- llClutch Engaging...
- Raptor V30 Tail Hub Replacement
- flight times with larger nitro helis
- RAPTOR 30 V2 CONVERSION TO 50
- Clutch Bell removal
- Idle trim question
- Tacho an Voltage functions on 9ZHP
- wobble
- Throttle hold tail pitch???
- Raptor 90 SE
- I'm new, Is this a good deal?
- Wobble question
- Best Tachometer??
- R30v2 canopy on v1 frame??
- Tail Supports(Colored) For raptor V30
- Got meself a 9zap WC2!!!
- GY-502 Gyro and 9254 - Opinions please
- Detailed Install of Fun for Raptor 50 Titan and OS .50 Hyper
- Getting a Raptor 60
- First Flight Raptor V30
- Tail Rotor Question
- nitro n00b questions
- Raptor 90
- Titan tail system help
- best beginner nitro??
- Cheapest V1-V2?
- T T 36 Heli engines
- Any advice on balt tension
- Help with Raptor 50 Titan
- annoying shake
- Raptor 30 On Floats
- E620 Pack's
- price for Raptor 30?
- Raptor 30-50 tail assy...help
- clicking noise in tail rotor?
- Cheapest Raptor Titan
- Dont know what to do...HELP Please
- swash plate and push rod question Raptor 60
- Cool Power 15% vs. 30%
- how to's
- What drill can I use for starting my Raptor 60?
- GV-1 With JR 10X ?
- To Fritz The Cat
- RAPTOR 30 USES HEADER TANK FIRST
- Help me with my Raptor SE
- Remote Glow Plug
- TT Raptor 50 V2 - Training feet oscillation
- Should I or shouldn’t I bother with this exhaust
- SPRING CLEAN MY 50OSH
- Raptor 50 Titan / Vibration by idle engine
- New Heli, trex600, raptor E620 or raptor 50?
- JACKHAMMER NOISE
- Engine tuning????
- Raptor 30 V2 Pro
- Best RC (or RC Best) TT Raptor 50 Head Replacement Parts - Opinions please
- Woodies covering
- raptor 50 for realflight??
- v2-50orv2-60?
- Mufflers
- Raptor 50 V2 & GY601 - tail always hunting...
- TT39 IDLEING
- 3d heli
- BEARING RE-PLACEMENT
- OS .32 muffler
- balancing the fan and clutch
- Whitch helicopter raptor 30v2-50v2-50 titan????
- OS 91 HYPER WILL NOT FIT IN MY R60???
- RAPTOR 50 REPAIRS
- Titan 50 Review online
- NEW Thunder Tiger Scale Bodies to fit the Raptor 50 AND 60/90!!!
- New Raptor 30
- Kasma head Assy Customer sevice!
- Problem with engine tuning
- Throttle Curve
- MECHANICAL SET-UP
- Cracked TT Blade????
- raptor 60 landing gear
- Raptor 30 Carry Case
- Moving up from TREX which Heli?
- Muffler?
- STARTING NEW 90 RAPTER!?
- What to feed new pet rappy?
- Wildcat fuel
- Raptor 30
- RAPTOR 30 CRASH AFTER NEW MUFFLER
- Rossi Heli Engines
- At Last success!!
- Governor Magnet Installation Question
- Set-Up Videos
- mufflers
- 9254 getting slow
- rappy 50 se
- Raptor 50 with os 50 hyper
- Raptor 30 V2 Tail Servo Rod
- Pitch Adjustment
- Raptor 30 break in
- rapter 30 with an OS.32 lacking power...go .37?
- How much cyclic pitch and roll degree?
- How much play in main rotor shaft up and down?
- Raptor G2 Trans Settings
- thrust washer on engine
- Tail rotor spins what way?
- CYCLIC
- gy401 question
- Raptor 30 or 50?
- Arizona Regulator
- Arizona Regulator
- hyper 50 running in
- WILL AN OS 91 HYPER FIT IN A RAPTOR 60???
- duralite & regulator
- upgrades required
- Opinions on these battery RX packs
- Vertikal play on the Clutch bell
- AH HA!!!
- Titan sweeeeeet!!!!!!!!!
- 1 last question!!!
