PDA
View Full Version : Thunder Tiger - Raptor 30, 50, 60, 90
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17
  1. TT 50 not idling
  2. blade balancing
  3. Important Question
  4. Spektrum DX-6
  5. ys for raptor 60
  6. burnt out clutch liner
  7. thunder tiger heli engine
  8. 1 more problem!!!!
  9. Raptor 30 Wont Lift
  10. Starting a new raptor! help!
  11. setting up pitch curves
  12. Webra Engines?
  13. Raptor 30 v2 and Spektrum 7?
  14. TT Raptor 60 w/TT70 engine
  15. Spool Up Question
  16. Please recommend a good blade balancer
  17. raptor spins in circles
  18. Recommended paint for FRP canopy?
  19. New Mini Titan 325
  20. Turning around the under carriage??
  21. local hobby shops
  22. Raptor begginer curves
  23. Flame-out fest 2007: What am I doing wrong?
  24. can i buy just the bearings for the wash out assembly or do i have to buy the whole assembly?
  25. Fitting elevator a-arms
  26. Head speed
  27. Quality brand of grease for bearings?
  28. Titan, SE or maybe the 90..?
  29. RAPTOR 90 CLUTCH LINER QUESTION.
  30. s9202 good on the tail?
  31. Raptor 50
  32. Budget Raptor
  33. Setting up JR 9303/Raptor Titan and 401 Gyro
  34. Raptor 50 swash type for DX7
  35. Infinavation Dampeners
  36. Raptor 30 settup?
  37. Popsicle stick trick?
  38. MOVED: raptor g2 manual
  39. ROBBE - FUTABA FX-18 SOMEONE HELP
  40. GoodDealz.com ?
  41. Raptor Sport bearings?
  42. Pitch settings for all modes??
  43. Governor Question
  44. Titan Canopy Same as V2?
  45. Rx 4.8V Ni-CD battery.
  46. Questions about a raptor 30 V1
  47. Raptor 90 Body
  48. lexan canopy...
  49. RAPTOR 60 OSSZ 70 BREAK IN INFO!!
  50. hi tec 635 servo in a 50
  51. Engine Linkage Arm
  52. Metal geared vs Plastic
  53. New Raptor 50 owner
  54. Raptor 90 Se first flight
  55. starting backward
  56. Hi Tec 6957 or JR 8311 Titan 50
  57. New on helis questions
  58. Rappy 90 with new YS 91
  59. Need Help tt-39
  60. Jesus!
  61. Where can I get gaskets and O-rings for a TT36 engine?
  62. will a raptor 50 crash kit fit a raptor 30
  63. Crashed my Titan
  64. Head Damper life
  65. HOW LONG SHOULD A CLUTCH LAST?
  66. whats the difference?arf/kit
  67. Maxx product RX packs?
  68. Blades turn at idle
  69. JR Servos for Titan Raptor
  70. Backup Hardware suppliers?
  71. what rx pack is best?
  72. Best Pipe For OS.37 In Raptor
  73. Metal head block yes or no ?
  74. servo gears
  75. Kasama Tail Grip Assembly!!!!
  76. Raptor 50, 60, or electric?
  77. Best Charger investment?
  78. need help with dx7!!!!!!!!!!!!
  79. Who makes YS?
  80. My screw is not loose it's gone!
  81. wrong blade for a R60?
  82. Loose your Raptor in El Cajon?
  83. Raptor 60 engine temperature
  84. Tail rotor setup, Rap 60?
  85. webra 75
  86. Strange fluttering sound every once in a while on an almost Brand New Raptor 50SE
  87. Raptor Spinning Problem
  88. R30 Refuses to run on OS#8 plug
  89. covering horizontal and vertical fins??
  90. ask about gyro 240 with size 50
  91. all about crashing
  92. raptor 30v2 servos glitches
  93. Over confidence equals dented pride.
  94. Hover Trouble
  95. Trex or Raptor 30/50
  96. first flight!
  97. Open tail box upgrade
  98. New to the Forum!
  99. Clutch bell bearings??
  100. how to get higher head speed?
  101. Super Upgrade Question
  102. 401
  103. os37 problem
  104. what kind of grease to use on one way clutch?
  105. YS OR OS???
  106. Kasama head for christmas WOOoo
  107. balance
  108. 30 v2 Question
  109. cg
  110. Viper head on .91 OS
  111. Raptor 60 clutch bell too tight?
  112. It Begins!!!
  113. OS 70 not making power, what can I do
  114. Titan 50
  115. raptor body
  116. 4 stroke for Raptor?
  117. 90 Raptor Engine pump question ?
  118. Raptor 30 pro vs sport
  119. Which Transmitter to Purchase??
  120. Servos & Gyro for .30 and .50
  121. Raptor 30 or Raptor 50??
  122. SE 90 fast forward
  123. WOOD BLADES
  124. DX7 with GV-1
  125. RAPTOR 30V2 ENGINE PROBLEM
  126. a new face for a raptor 50v2
  127. anyone he have a trex that flies a rap 50?
  128. Where do you guys buy your raptor parts??
  129. raptor 30?
  130. Making Extra Lube Points on Raptor60!
  131. Quick Help
  132. Cyclic servo's
  133. My raptor titan!
  134. 9ZHP FOR CHRISTMAS!!
  135. HERE IS MY NEW RAPTOR!
  136. What else? Please
  137. RAPTOR 30V2 AND FUTABA 7CHP?
  138. S3050 for Raptor 60?
  139. what else do i need?
  140. is the dx7 radio good match for raptor titan 50?
  141. RC heli shops around Duluth, MN
  142. Raptor in Spokane
  143. Buying an ARF 30 V2 kit from HK...need some advice, please
  144. 30 vs 50
  145. aluminum rotor head
  146. Engine Question
  147. tail pulse problem
  148. Rapid side to side rotation of tail R60 with TT70
  149. 30V2..BELT RIGHT?
  150. Second Heli. Raptor 30V2 or Titan 50
  151. KASAMA HEAD OR QUICK UK HEAD
  152. should i use the ttr 50?
  153. MD-530 Defender Fuselage Cockpit Kit?
  154. PAINTING RAPTOR BODY?
  155. which one
  156. Raptor 30 V2 and Raptor 50 V2 canopy/body
  157. Need help w raptor set up from start to finish
  158. Screeching noise when starting?
  159. Raptor over-rev
  160. Need help on a Raptor
  161. STARTER EXTENTION?
  162. Standard s3004 servos for rappy 30??
  163. Collective servo falls apart!
  164. Titan 50
  165. Rappy 90 with the new YS engine
  166. 425bb servos?
  167. Raptor pics
  168. Os 50 Hyper
  169. TITAN, SE, Standard????
  170. Fuel Filter
  171. how mutch oil??
  172. Titan Fan/clutch Question
  173. Fluro colour heli canopey
  174. Raptor 30 Tail Noise
  175. Loose Tail Boom
  176. Quality pitch gauge?
  177. Curves and blades
  178. Pitch curves, and other assorted quandaries.
  179. Larger tail rotor?
  180. Unusually high hover engine throttle% on R60
  181. Tail Servo Wag
  182. What kind of gaskets do you use?
  183. Blade Balancing
  184. TT39 quitting in flight..
  185. Do they make RTF helicopters
  186. JR Radio with Futaba GY502 and GV1
  187. 9254 caused lock out and crash
  188. CNC Alum. Fan for Raptor .30
  189. !!!NEAR DISASTER!!!
  190. Pipe for OS .37
  191. Trickle Charge
  192. titan question
  193. Rays DVDS ??
  194. Throttle Jockey Pro?
  195. Kasama Washout pin
  196. Oiling groove In Auto Clutch. Raptor60
  197. Thunder Tiger funfly dvd
  198. Changing to SEALED DIRT FREE bearings
  199. IT MADE IT!!!
  200. Raptor TT50 motor problems
  201. Evolution .52
  202. Digital Servos
  203. How well Thai 's helicopter pilot fly RAPTOR 50 ?.. check clip VDOs here
  204. Tail goes left
  205. Servo question
  206. OS C spec engine
  207. OS 90 vrs TT 90
  208. Raptor 60 and Hatori SB70 question
  209. OS50 Hyper question
  210. engine question
  211. nite flyin
  212. RAPTOR V2 VERSES TITAN?
  213. Raptor50 SE Vs. Raptor Titan
  214. Kasama, TDG, Quick UK, which one?
  215. I WANNA BUY A TITAN 50.
  216. cool power 15%
  217. Thats one bunney hop for man, but inverted flight for mankind ;-)
  218. futaba 401 question
  219. Fan question
  220. futaba servo
  221. a couple of General Questions
  222. tail blades
  223. raptor 30 w/ os 50
  224. OS C spec 90, help if you can
  225. Cyclic servos
  226. First Raptor in the bag ;-)
  227. Gyro Question
  228. Raptor Pilot Wanted
  229. 222 R50 Pics
  230. GV 1 governor
  231. Sanwa RD6000 setup for 3D flight
  232. Raptor Titan
  233. Help With Engine
  234. Need help with electronics on Titan
  235. Fan and clutch runout
  236. 1st Crash on nitro :(
  237. O.S 50 hyper extreeme cranking times!
  238. Raptor 50v2 to electric
  239. .30?
  240. GY611 setup ?
  241. R50 tail question
  242. O.S 50 Hyper
  243. Building Titan 50
  244. wrong cyclic pitch input
  245. Loop sequence
  246. Wich blades
  247. Length of PV0057 Frame Spacers (S)
  248. Quick World wide head on R 50 Help!
  249. Tail Blades question ?
  250. Main shaft bearings in Raptor 50 gone bad.
