PDA
View Full Version : Thunder Tiger - Raptor 30, 50, 60, 90
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17
  1. JR radio and futaba gyro
  2. Gyro and Servos for the Raptor 50 V2
  3. TG-8000 Gyro? Tail rotate :(
  4. wanted raptor
  5. are rapters easy to put together
  6. First attempt of faith
  7. where to order on internet?
  8. Raptor 60 Scale Fuselage
  9. Look what the UPS Man brought! [Raptor 30 Build-Up Pics]
  10. Raptor 30 tail pitch fork upgrade?
  11. Engine question.
  12. Raptor 30 V1 is BOUNCING
  13. Throttle Jockey / Raptor 50 / JR 8103 Help
  14. ANYONE USING 570MM BLADES ON A RAPTOR 30.
  15. Raptor 30 V2 Vs Nexus 30 type S
  16. Raptor .30 Paddles
  17. helo got the shakes!!!!
  18. R30 V2 tail pushrod guides (be careful!!)
  19. Muffler on raptor 30
  20. belt drive on raptor60
  21. 4 Stroke in a Raptor 30
  22. canopy for my 50 v2.
  23. Question on aftermarket parts
  24. Newbie Here with some questions.
  25. Engine for my Raptor 30
  26. TT 50, TT70 Engine
  27. BOOM Strike!!!!!!!!!!!!! HELP
  28. We need a good cheap Schweizer canopy for the Raptor 30/50
  29. R30 V2 drive belt tension
  30. Pitch up in rolls.
  31. Futaba 9chp settings for beginner!
  32. Advance setup for Realflight G2 Help
  33. TT vs Mavrikk blades
  34. OS .32 Muffler
  35. Question about osx 50 engine
  36. Raptor Down! Raptor Down!!!
  37. Just got my raptor 50 v2..Where's the locktite?
  38. Tail rotor pitch.
  39. Raptpr V2 parts
  40. tt 50 or OS 50 ???
  41. Raptor Parts
  42. Lifting Capacity of a 30 v2
  43. Fuel Residue Removal
  44. 60 v2 or STD90???
  45. Raptor 30 ,Tail Rotor Belt
  46. r60 auto hub????
  47. engine speed when idling down
  48. what are the diffrent?
  49. Tools for First heli completion
  50. Canopy Painting
  51. R60 Clutch
  52. TT 60 Discontinued?
  53. bad glow plugs
  54. Raptor 30 V2 Gyro Question
  55. Best way to upgrade to V2?
  56. TT PRO 39 engine
  57. Servos for Rappy 30?
  58. What is the best buy - Raptor 50/V2 or Sceadu 50/Evo?
  59. raptor v2?
  60. Hobbico Gyro
  61. Shake/Vibration on a Raptor 50 V2
  62. What glow plugs for OS50 in Raptor 50 V2?
  63. Governor with pitch curve?
  64. Buying a 60 heli - Raptor 60?
  65. Blade Balancing
  66. Futaba 6xh ( ff6)
  67. Main Rotor Shaft Collar
  68. Raptor .30 V2 Blades
  69. Raptor .30 Clutch
  70. CSM v10 Raptor Specs
  71. ANy JR X-378 Fliers? Need Advice
  72. Flight of the Raptor
  73. How to tell what Version you have?
  74. raptor 50, bulding pictures?
  75. Parts question - throttle arm
  76. New R60 question
  77. Raptor 30 W/ 4 Stroke Engine
  78. Raptor 50 v2
  79. raptor 60 conversion to a 90.... should I ??
  80. Servo for the JR460T HH
  81. Raptor 50v2 Mods
  82. Thunder Tiger FS-91s Compression isue
  83. Raptor 50v2 servo installation
  84. Grunching sound!!
  85. Raptor 30 Blade Breakage
  86. Hatori SB14 or SB16?
  87. Raptor 30 pitches down in FFF
  88. Raptor 30-V2 binding, what is it??
  89. Good PRE-BALANCED blades for raptor 30?
  90. FMA Co- Pilot -Raptor30 and Futaba9c
  91. Aftermarket graphics
  92. Tail Rotor Grip Set
  93. Raptor 30v2 VS Hirobo shuttle Plus
  94. GY401 gyro question???
  95. New Heli Pilot . . . Assembly Questions?
  96. Raptor V2
  97. Balance in Raptor 30 v1
  98. Raptor 50 V2 Question
  99. Raptor 30v2 Gyro Servo
  100. should i get a raptor 30?
  101. Paddle for Raptor 30/50?
  102. Raptor V1 vs. Raptor V2
  103. Replacement Blades for Raptor 50V2
  104. Glow plug extension
  105. Raptor 30 V2 manual - looking for a pdf file
  106. TT 50 setting?
  107. Raptor 50V2 Loose Tail Rotor Shaft
  108. Raptor 30 v2 or 50 v2 ??
  109. S.O.S. raptor50v2 engine mount problemo
  110. R 60 whit OS .60 enougth powered?
  111. Auto Rotation Pulley on RapV2? Tight?
  112. TT 36 Pro Needle settings
  113. help with tail blades rap 30 v2
  114. TT 50 power and climate change
  115. Fixing up 30V1... Questions.
  116. WHAT IS A GOOD HEAD SPEED FOR RAPTOR 30
  117. Main rotorblades tightness?
  118. broken side frame canopy mount
  119. Tail hold Gyro and Rudder Trim?
  120. Digital Servos and flip rate!
  121. Starter shaft spinning on Raptor v1
  122. Needle setting on TT39
  123. Carbon Tail Pushrod Kit from Quick UK
  124. Raptor 60 V2 me or the Heli???
  125. Servo setup 50 V2
  126. Raptor 60 won't start.
  127. Quick Easy Questions about Raptor 60
  128. Main rotor blade size question, help plz
  129. JR811 for a R50 - are they ok?
  130. perfect cheap 60v2 clutch fix
  131. Tiger 30 Starting problem with kickback
  132. Raptor 30 Glitching?
  133. R80 Elevator control screw keeps backing causing crash HELP!!!!!
  134. Main Blades not tracking on right side
  135. Can't Get My Raptor 30 Tail To Hold.... Anymore
  136. Main Rotor Blade...?
  137. Raptor 50 V2 Set-Up
  138. Raptor 30v1 aftermarket decals
  139. TT 36 Engine Problems
  140. Raptor 50 V2 - CCPM???
  141. Got some problems- Raptor 30 , clutch problem?
  142. Scale canopies for the 30 V2?
  143. Should i get this raptor?
  144. balancing
  145. Tired of my 50v2 pink stickers, help...
  146. R60 tail rotor gear ratio?
  147. 30 to 50 question, best way....
  148. YaY my rappys nearly ready ! But .....
  149. how many 80-90 engines in a 60v2
  150. carbon fins change flight?
  151. Raptor 50V2 - quick question on pitch servo arm
  152. raptor wants to go backwards on take off
  153. The rotor guide screw
  154. Big blade weight imbalance
  155. Please help me choosing a new radio.JR PCM9x and Futaba 9CHP.
  156. Servos for Raptor 50 V2
  157. 50 V2 Tail rotor backlash.
  158. LiL backward tilt prob on me rappy?
  159. Just got first Heli--Raptor 30 V2 ARF---Looking for tips and advice
  160. Tough Raptor 30
  161. Throttle Pitch Curves
  162. Helihobby price for raptor? Anything cheaper?
  163. Raptor 30 Question and FMA Co-Pilot
  164. lube bearings?
  165. raptor v1 and v2 whats the difference?
  166. Selling the .30V2 and buying a .50V2?
  167. Rate the Raptor
  168. Raptor 50 V1 clutch problem?
  169. 50 V2 main rotor grips ...where are they ?
  170. Radio Shack Infrared Thermometer Works Great! **repost**
  171. Raptor 30 v2 spins on spool up
  172. Actual Temperature for heli engine (TT50 and TT36)
  173. Raptors in Japan
  174. Raptor Sport or Pro?
  175. where to buy a raptor?
  176. Need HELP?? Links.
  177. Raptor 30 V2 strips my servos
  178. Which is a better engine for the Raptor 30
  179. Pitch Curves
  180. First Heli, TT Raptor 30, 50 or Jr Venture 30/46
  181. Just wonder will TT come out Raptor60 V3 with CCPM mode
  182. Anyone flying the metal head and metal flybar links on a 60?
  183. TT39 questions?
  184. stripped main gear in rappy
  185. Raptor 30 to 50 problem
  186. clutch liner/shoe gap
  187. Efficient upgrades(R-50/V-2)
  188. TT .70 4 sale
  189. what upgrades are worth it?
  190. Raptor50 V2 Tail Fin vibrating Pls help
  191. Raptor 30 Upgrade kit to 50
  192. Where can i get real model bodies?Help plz
  193. Looking for Raptor .30 V1 parts...
  194. Raptor 50 V2 Hover problem
  195. Best setup for beginner
  196. 30 V2 & irvine 36 ????
  197. Rap50v2 + TT50 Pro Carb Settings?
  198. gyros
  199. just starting out
  200. New Raptor Yahoo Group!
  201. Poper carb settings
  202. Help! Cooling fan will not fit on crankshaft
  203. Fuel&settings R 60 v2 /70 eng Xp8103h
  204. Tt 50 Or Os 50????
  205. TT 36 good?
  206. Pitch Range, Purpose or Preference?
  207. Raptor 60 V2 GV1 settings
  208. Blade tracking problem, Raptor 30
  209. (gy401) Tail shakes violently when reducing revs after landing.
  210. Raptor V1 Hover Setup
  211. Raptor 60 gear ratio
  212. Which engine for Rappy 30?
  213. TT 70 Fuel
  214. Raptor 60 Collective servo
  215. Raptor 30 starter wont engage
  216. Where can I find Raptor 30 parts online?
  217. Clutch Drag Vibrations
  218. Ocilation
  219. V2 60 needs better performance
  220. Blade Flutter/Oscillation on my Rap30V2.
  221. Best place to buy a crash kit for 50V2
  222. Raptor 30 Gear Mesh
  223. Shipping a Raptor 60
  224. Raptor 30 V2 Rudder
  225. Gy 502
  226. Throttle Jockey ATV adjustment
  227. tail glitches
  228. help!!! tt70 in a raptor 60 help!!!!
  229. Raptor 46 and Funkey fuselage
  230. R60 Main Gear
  231. fuel type on Raptor 50 V2 (and V1)
  232. Fuel Tank Question
  233. Max Power!!
  234. Tt50
  235. R60 V2
  236. Raptor 30 v1
  237. DTI clutch and cooling fan..Questions!
  238. new heli pilot (raptor 30)
  239. Throttle Jockey installation
  240. Raptor V2 Flywheel Question
  241. Weston Uk Pro-synth 2000 5% Fuel
  242. 30 to 50 Conversion question - from a caliber guy.
  243. Raptor 30 vibration questions (please help)
  244. newcomer choices..
  245. clutch question
  246. Burned up clutch in R60 Please HELP
  247. servos price
  248. Raptor 30 V2 + TT39 = Amazing!!
  249. raptor 50 servos
  250. Raptor 50 V2 Crash's Due To Fault
