- Raptor 90SE Build Question
- JR 921 Rx "brownouts"
- tppacks.com
- Raptor 50 Titan SE build questions
- raptor 50 v1 to v2
- jr 8103 gyro gy520 cant program
- raptor 30v2 to 50?
- WHat fuel for a RL53
- TT39, yes beating it to death
- TT39 FAN
- Mavrikk parts for 30/50V2
- Fly Bar and Blade set up help
- Raptor V2 Red Bull Stickers
- Raptor V2 Settings
- The CSM sl420 gyro YES!!!!!!!
- thunder v2 inverted flight
- How to clean my new muffler?????
- Raptor 50v2 Guide Pulley replacement
- Raptor 30, whats it worth used?
- Raptor 30V2 pitching
- thunder tiger pro 39 engine
- Horizontal fin vibration
- 620mm Blades too much load?
- Alien command will it fit my 30 v2??
- Newbe needs some tips!!
- Raptor 30 upgrade parts hard to find?
- boom sizes
- Red Line 53H Crap
- raptor 30 scale
- trex 600 landing gear works!
- Where do I find four blades head and tail
- Engine bearing noise
- raptor just spinning
- trex fins and raptor fins
- help please raptor 30
- Buy a Raptor 50 Titan 600$?
- trex and raptor canopy enterchange?
- What Power for the receiver
- raptor 30 vs 50 tail boom
- Multigov pro
- JR G770T Gyro fixed
- TT 53 Redline leaning out
- Raptor 90 SE vs 3D
- R 30 W/ os 46 bogging really bad
- Looking for new Titan 50 canopy
- Stiff Tail Movement
- should ball link expander be used...
- Is this normal?
- RAPTOR X50 TITAN?
- raptor 30 trim
- raptor 30 tail problem help please
- raptor 50 parts
- TT39
- New to helis
- 5 or 12% nitro
- Rotorhead speed
- Raptor PICTURES
- You know what this engine? TT PRO 46-H
- Battery for AR7000
- RAPTOR 30 VS 50
- Battery question
- Fixed position hovering
- TT Raptor setup with 9CAP question
- pro .70
- piston
- thunder tiger pro.70 need online psrt source for new sleeve and ring
- raptor 50
- carbon blade repair
- A new Tiger ?? X-50
- head Dampners R60
- TT Titan Clutch disengages
- Raptor 30 2.4G SC
- Mini Titan ESC
- wich governor to use with raptor
- Raptor 30 exhaust question
- NEED ADVICE ON HELI
- first loops and rolls with raptor 30
- buying raptor 30 v2 rtf
- headspeed tachs
- Gasser for Raptor 50
- Sometimes you get lucky!!!!
- raptor autorotoion gear
- Raptor 30 to 50 conversion
- raptor flybar
- Raptor 50 V2 Upgrade
- Raptor Question !
- 55HZ-H Hyper
- Watch out for the raptor 30v1 and 30v2 tail case!!
- Looking for radio advice for my raptor 50
- raptor 50 cluch question
- raptor 30v2 combo
- See what happens when you stray ...
- Raptor 50SE
- help raptor 30 scale fuselage
- Raptor 50 Tail rotor pushrod clips
- Ultra lite paddles
- Raptor 30 V1 with OS 50?? Need some help
- raptor 30 new to helis
- fuel for tt 39
- raptor e620 problems
- Cheaper Gyro's 401 nockoffs - what's wrong with them!!
- Raptor 30 V1 Clutch always engaged after rebuild
- going in circles
- Best Rudder Servo for Raptor 60
- plastic covering on stock blades
- Raptor 50 Titan
- HT Evor 50? (raptor upgrades)
- Thunder RAPTOR
- NEW 50 SE
- Raptor upgrade parts
- continuing os engine probs
- first flight on raptor 30
- Raptor 30V2 strange sounds.
- What do you guys think this is worth?
- raptor 30 V1 vs. V2
- Looking into a nitro bird. need adivce
- tt.39 breakdown
- transmitter choice
- canopy raptor 30 question
- Nearing Maiden Flight
- Futaba S3151 Servo for Rappy 50
- Aftermarket rudder servo mount
- Raptor 30 what verson
- mini titan swash levelling and pitch adjustment
- Raptor 30, Adjustment Problems.
- .50 engine question
- Looking to purchase a Raptor. Please advise.
- Raptor .30 Parts availability
- os engine problems
- Clutch for Raptor 30 Version 1
- More collective pitch?
- Radio for mini titan
- Raptor 50 troubles
- Raptor 30 questions
- Raptor 50 v2 upgrade???
- 600 or 620 blades?
- tracking ?
- pitch guage usage
- R30 Bad vibes
- titan 401 gain wire
- Late Start?
- cyclic servos
- raptor 30 muffler
- Which governor?
- Raptor 50 Clutch
- battery requirements for digital servos
- UPDATE - FLYING GEEZER
- Raptor Rolling Question (Mainly For BarracudaHockey)
- Is it worth changing the servos?
- Raptor 50 tail dippinghelp
- 90 SE upgraded tail housing
- Servo recommendation please
- raptor 60 clutch
- engine upgrade
- throttle servo
- Blades for a Raptor 30
- Raptor 60 Carbon Paddles and Tail Rotor
- 50 titan upgrade
- Heli 30 vs 50 Raptor and Gyro and Servos ... Need Some Guidance
- Raptor 30 v2
- New Raptor Canopy Mounting
- Got my Titan :D
- Raptor 30 upgrade help
- dx6i and dx7
- Raptor 30 V2 HD Video
- Which R-30 cooling fan?
- Drops like a brick?
- eCCPM for Raptors free upgrade
- Anybody have or know where to get stickers for raptor 30?
- 30 V1, dire straight's for a clutch.
- What battery to use?
- Raptor30v2 Tail problem
- Raptor 90 3d frame problem
- Raptor 90 3d bolt question?
- New Titan SE
- RAPTOR 30 BUILD
- new Raptor 30 with os 32 sx need settings
- R50V2 Clutch/gear problem (stuck)
- battery pack
- Raptor 30 w/o.s 32
- is it worth getting a raptor 30?
- Fuel Line
- NEW to nitro!
- Which engine governor do you recommend?
- Thunder Tiger TG7000 Gyro with Futaba issues....
- Raptor 30 v2 radio?
- What is this govener thing
- OS MAX-50SX-HringHyper
- Some issues with my R50 Titan help is appreciated
- raptor 50 titan upgrades
- 3d newb with rap 30.
- R90 MAIDEN
- Scale fuselage for Titan 50
- Raptor 50v2 gyro?
- governor?
- Raptor 30 with a OS 50?
- What do i lube my one way with?
- titan mixing/upgrades
- HEAD TEMP
- Stock blades (R30V2) lost coating-2nd flight!
- RAPTOR 90?
- JR G770T Gyro troubles
- gyro weird stuff
- raptor autorotation
- clutch engaging early
- 50V2 set up
- RAPTOR 90 PROB!
- Parts Inquiries / Raptor 50V2........
- 30/50 Main shaft
- Raptor 90 FlyBar
- Solved - Raptor 30v2 Mavrikk Carbon Rear Servo
- Raptor 50v2
- First 50 Heli
- dx6i throttle cut
- Blades
- Mush out on rolls?
- R90 ADVICE!
- new raptor e550
- Hop Up Carbon Frame 50 v2
- Raptor 30 v2 servos SSV-9766MGs
- Canopy Inquiry
- hellfan upgrade
- RAPTOR 90 ENGINE
- Fuel Question for OS 50 Hyper
- Raptor 30 to 50
- Servos for raptor 50
- Raptor 50v2 with OS50SX
- Raptor 60 or just a Compatible Heli?
- NiCd or NiMh? Raptor 30
- DX6i...AR6200...G401
- Nitro Heli for a high school student; raptor 50?
- What size tail blades?
- How good are the raptors for noobies?
- os hyper glow plug/ tuning
- rap 30 tail blades
- Raptor 50SE V2 pinion gear help
- Receiver Battery and Regulator
- Raptor 50 vs. 90
- which v1 and V2 parts are compatible or are not the same ?
- os hyper tuning
- Raptor 30 pro-39 engine adjustments/ fine tuning
- new servo for raptor titan
- Which Transmitter?
- R30 v2 Kit build question
- Newbies R US - Hints and tips?
- Guys where is the cheapest place to buy Raptor 90se ?
- A little Titan manual confusion p 25-26
- Upgrading Raptor 50v2 Head
- How to mount whip antenna
- Servo Suggestions?
