- Backwards troubles again.
- Raptor 60 roll and climb rate
- strange sound
- Loss of power when inverted on Raptor 50
- Raptor 30 vs Raptor 50 vs E-flite blade 400
- WHEeEEee... Autos R FUN!!!
- im having trouble with 401
- Logictech 6100 with 90
- Aecrobatics/3D
- Auto'ing in grass
- OS 50 SX vs 50 Hyper
- Hydro lock on the OS 50 SX Hyper
- Starting a 90SE
- Extension manifold for OS 50 SX H
- Raptor 30 V2, Noob friendly?
- O.S. 50 Hyper & Me
- most powerfull engine
- blades for Raptor 30 V2
- New 50 titan owner has questions?
- Mavrikk grip bearings
- what's kind of these metal Rotor head ?
- Tools for Raptor 50
- Scale bodies for Raptor 30 V2
- hatori or muscle pipe?????
- Raptor 30 or Raptor 50
- Raptor 39V2 with Gasoline Fuel
- rap30 help with repait kit
- 90SE rotor head
- Futaba 6v Tail Servo
- Raptor 90 - G770 3D gyro
- burnt up my servo
- Auto - ing
- New antenna set up
- Kasama's new Raptor head
- Should i sell? Please help. R30V2
- adding additional battery pack..two 2600mah packs
- has somebody tried or knows this combo????
- Main Spur grinding
- Raptor 50 Blades
- raptor .30 rotor head shakes
- When to rebuild?
- Richer or leaner for more nitro
- Parts to check before Raptor startup…
- Overhauling tt39
- Governor interference
- Very sensitive to fore aft cyclic
- ESC as voltage controler
- is this a bad engine
- Sevo Advice for a Newbie!
- from woodies to CF blades....
- what should I do?????
- Help with tracking blades
- Raptor 30 V2 still clicking.
- Is it my clutch?
- Maiden time!! Raptor Rapture!!
- Tail fin
- Raptor 30 Parts V1 to V2
- Raptor 30 upgrade
- Raptor 30 Main Rotor Blades
- Pitch Servo
- Nitro fuel in Germany
- O.S. 50 Hyper & Glow Ignitor
- Where not to buy parts
- raptor 50 v2 for realflight 3.5
- Raptor 30 V2 ??
- Raptor 30 clutch question.. Please help...
- Forced Autos
- Raptor 90SE Headspeed problems
- Kasama or Mavrikk
- Raptor 50 or 30
- Clutch R30V2
- Ball Links
- Belt life
- How to tell difference R 30 V1 & V2?
- question about needle closing
- Gyro suggestion ???
- engine problem raptor 30
- Raptor TT 50 pro motor problems
- Backwards Titan
- DX7 radio
- Rabid Raptor
- Wind Speeds
- My Raptors
- Raptor start shaft
- Who needs an R60 clutch?
- Raptor 90 servos???
- using 4.6 instead 6v
- GYRO??
- Raptor 30 ??
- Raptor 90 starting and vibration questions
- question about tuning..
- Raptor 30 Got the shakes
- Ray's DVD Carb. Mod.
- Upgrade pipe for .39
- 30% down to 22.5 % nitro with my 50 sx hiper
- Glow igniters
- Exhaust port brown, OS 32
- Anyone using A5 plugs in thier Hyper 50?
- Is it a V1 or V2 ? (Raptor 60) pics
- Inverted with Wood Blades
- What is your engine's needle setting?
- Raptor 50 or 60? Which to buy?
- TT 39 30% nitro
- Rap30 High Pitch Noise
- 20% fuel
- Raptor 60
- Raptor 60
- Full Throttle or Idle?
- Autorotation
- 1st inverted hovers!
- question about the raptor bell
- DX7 servos
- regulator placement
- TJ PRO atv values
- Most Popular Battery?
- Broken Header Tank Bracket
- Raptor 30v2 to 50
- Crashed a rappy 50v2
- advantages with CCPM....
- PLEASE HELP! Cant get my engine started! Raptor 50
- What are those on your skids????
- tail boom for the raptor 30-50....
- Raptor titan 50 governor
- RCE-G500 governor f
- TT39 problems
- DS 821 in raptor 30 v2...
- Need help choosing gyro and tail servo
- Cleaning the muffler
- What was the Popping sound?
- Throttle Jockey Pro setup help Please
- OS32 or OS37
- is there anything wrong with these blades????
- Raptor 30 Tail Wag
- Raptor 50SE
- suggested retail price list ??
- O.S. .37 Installation?
- 30V2 engine
- Heli DVD's
- One-way weirdness??
- Where's the short............?
- Mavrikk Super Gear
- TT 50 v2 dampners ????
- Helicopter CG
- Raptor dealers
- New 50 Size
- GOVORNER ?
- set up raptor
- Futaba 6XHS setup for Raptor 30 v2
- sluggish rudder
- PARTS FOR TT 70 PRO
- Raptor 30 engine help
- Guys, I need help finding some 90 accessories please
- is there a big difference between 530mm and 500mm blades???
- Fasst Antenna in Raptor
- Raptor 90 3D Project
- Eclipse 7 tx settings for E550
- First 100 flights
- Conversion from a 30 to 50
- Will a Hatori 522 fit a Raptor 50 Titan?
- Got the 2.4GHz Itch
- Just Because we need a new Raptor thread
- idle rpm raptor 60, OS70
- "Revo vs. Raptor" video
- What is the easiest way to start my rap 90...
- 14MZ & Raptor50SE
- advantage installing the servo tail in the tail boom
- Dialing in my tail
- JR 8103 and Raptor 30
- Made in home (boom)
- help setting expos, DX7 and a raptor????
- tunning a OS 32
- $$$$ for 9303
- maintenance for raptor 30
- throttle/pitch curve
- Header tank mounting location
- Lipo RX battery questions.
- Plastic covering on main blades
- seized one waybearing on main blade. can it hurt anything?
- New fleet member
- TT RedLine PRO 53H
- Li ion for Titan
- Pipe for my 50H
- Raptor Titan Fuel Tank, how much does it hold?
- 550mm wood blades
- Pitch question
- Clutch question
- What Happened??!?!
- longer tail boom for a 90
- Possible trader looking for info.
- can I do this to my engine???
- ok im stumped
- Thor/Pitch Curve Raptor 50
- Ready to Purhase Titan50 but first
- os engine temp
- what about the OS 32?????
- Oil synthetic or castor
- servo setup?
- Best Simulator Software
- Online shops
- lost tail control
- Gyro question
- T-rex blades?
- Which servo please?
- Ball Link Sizing Tool
- need a little advice
- Chillin in South Florida
- First Nitro Hover
- paint
- Tail belt pulley
- Collective arm linkage
- help!!!! electronics question
- dampers?
- how much play do you have in your rotor blades?
- how to tell v2 30 pro or sport
- RAPTOR V2 .39 GLOW PLUG SIZE AND OR TYPE
- Clear coating a raptor canopy
- Need Help choosing the correct parts
- Weird Tail Behavior
- Raptor 30 V2 Pro upgrades help
- YS-91ST
- TT Raptor 30 V1 (Good Deal?)
- Raptor 30 from 4 years ago - Question - Getting back in the hobby
- Training Skid on Raptor 50 V2
- just bought a raptor...tell me what you think...
- FASST conversion for futaba 7C
- My first canopy modification...
- How many ch radio needed?
- violent 3d in raptor 30?
- what is the maximum speed a raptor 30 v2 can reach....
- tail assembly raptor 50se
- Gyro selection
- question about muffler....
- loosen head bolts.....
- raptor help
- pv0499 upgrade
- Raptor 50 V2 with OS 70 engine...Is this possible?
- NEED INFO
- Longer blades?
- raptor confusion...
- Equipment Failure while airborne!!!
- Couldn't wait, my 90 is flying!
- Extra Parts! Oh the joy.
- Servos, digital or analogue
- Ball Link Reamer Sizing Tool
- too much compression
- Head shims on OS 91, necessary?
- Raptor 90 Mods
- Muffler mounting problem
- New to Carbon Blades-help?
- Tail rotor flew off.
