PDA
View Full Version : Thunder Tiger - Raptor 30, 50, 60, 90
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17
  1. first verticle roll
  2. WHAT GREASE to use with auto clutch r60
  3. Header Tank???
  4. instructor/advice needed in Philly or central NJ area
  5. Every pilots nightmare
  6. First auto = First crash
  7. woooohooo!!! :)
  8. BOOM VIBRATION
  9. Tail blade breaking off in flight.
  10. Raido setup for Futaba T6EXHP Rap 50 V2
  11. Clutch bell and liner
  12. Progress report
  13. please help me
  14. raptor 50 flight
  15. My first auto
  16. clunk line.
  17. Crashing mistakes
  18. tt39 tuning problems again.
  19. Fitting carbon blades
  20. mixture setting TT50
  21. Head speed & pitching up
  22. Raptor supplies here in San Diego CA?
  23. Great day today!
  24. Replacement clutch for 50V2
  25. Air bubbles
  26. Measurements for Blades
  27. OK Servos to Begin W/on 50v2
  28. another new Q?
  29. need help with my rapy 50v2
  30. Fan
  31. os 37 throttle linkage
  32. Activating Throttle hold when governor is on
  33. Raptor tail boom
  34. raptor 90 airbourne again
  35. Carb and fuel tank
  36. Collective binding?
  37. Fitting raptor 30 muffler.
  38. WHERE DID YOU MOUNT UR GV-1 ON UR R50 SE HELI?
  39. Newbie problems with Raptor 30 v2
  40. Anyone like to smash galaxies into one another?
  41. need help!! the sooner the better
  42. tt39 . underpowered ?
  43. Raptor 30v2 Upgrade Parts
  44. Clutch liner glue
  45. help please
  46. Best Heli Starter Setup...?
  47. Advice needed.....again
  48. question about 401 found my answer got to love the internet thks anyways
  49. Wanted to build. What should I do?
  50. How to make fuel
  51. replacing bushings
  52. Pleae help w/new raptor 30 questions!
  53. Mavrik Parts
  54. throttle
  55. R30v2 Tailbox question...
  56. 12% oil
  57. Rudder problem? Is this normal...
  58. Fuel Mixture's ?
  59. How many RPMs should the main rotor maintain during 3D maneuvers!!
  60. Worth rebuilding?
  61. Which Gyro for Raptor 50 SE
  62. Who makes the best metal R90 head???
  63. water damge
  64. Starting a Nitro
  65. Holy Throttle!
  66. Hardware Questions ?
  67. 60 tail bevel gears - Metal?
  68. Any Pic's ??
  69. Good Suppliers ??
  70. Kill switch
  71. What rotor RPM is best for Idle Ups?
  72. Best auto pilot for Raptor
  73. GV-1 Governor Help
  74. Raptor 30 Question
  75. First Rappy 30 flights-Some issues!
  76. test flight
  77. raptor 80
  78. Raptor 30
  79. Check your heli again and keep it visible.
  80. Undercarriage....which way round??
  81. Wooden blades repair
  82. ES 539 V's nes 4131 as replacement???
  83. OS 91 C S spec
  84. Raptor50V2 Arriving today! Tools? Advice? Building Table?
  85. stuped Q
  86. Was it a good day or a bad day??
  87. Main rotor bolt torque?
  88. Some help would be nice!!!
  89. Raptor 60 Radio
  90. Blade Types-Wood, C.F., Fiberglass????????
  91. Step 2
  92. any winter preps I should do?
  93. Thunder Tiger MD-500 Photos Wanted
  94. 60 tail system to 30
  95. Raptor Decals
  96. painting canopy bumper colour
  97. odd question
  98. raptor 50/502/10x set-up
  99. New to heli world
  100. Rotor speed
  101. G2 sim on 55" TV
  102. Raptor 50 goes inverted
  103. What pipe???
  104. servo life
  105. tt pro 70
  106. [Advice] Raptor 30/50 or Trex450?
  107. Rappy 50 Clutch Problem
  108. Power recommendation for Rappy 50
  109. Raptor 60 paddles?
  110. Raptor 90 build question
  111. cool power 12% heli fuel
  112. 60 Rap first flight
  113. Conopies
  114. Auto's with Maverick 550's
  115. Purchasing Raptor 30 or 50 Online
  116. Need help on the EVOR 30 - (basically a raptor 30)
  117. Cool Power 5% . Is it ok for tt39.
  118. 401 GYRO
  119. who can tell me the largest agency of model in Europe and America?
  120. Anyone who knows this guy??Frank schneckenburger
  121. TT PRO 39 ENGINE
  122. What starting equipment is needed for Raptor 50?
  123. 9252 servos rock!!!!!!!!!!!
  124. 50 exhaust on 30
  125. rappy 60 muffler
  126. Comments about fine tuning a Raptor 30V2
  127. New Raptor 30 V2 401 gyro setup
  128. Raptor 90SE
  129. V2,SE or Hyper
  130. raptor 30v2 - 50 elec conversion questions
  131. gyro wire routes.
  132. Just got a Raptor60 to start with
  133. Emergency Gyro Release
  134. Rotopod anyone?
  135. First Major Crash...
  136. "goop" hitec servos
  137. Isn't digital digital?
  138. Raptor 50 Scale Bodies
  139. raptor 30 head speed.
  140. Twitchy Tail!?
  141. Replacing a servo
  142. most important servo
  143. Newbie question on a raptor
  144. TAIL ROTOR DRIVE BELT R30V2
  145. Raptor Helicopter Nitro can a gas Motor be put in
  146. Replacing the Clutch Liner on a Raptor 30
  147. Which servos
  148. Play in servo gears????
  149. Few 30 V2 Questions...
  150. Main Gear locked solid
  151. Stupid R60 auto clutch...
  152. Which tail rotor blades to get?
  153. Paint for TT MD500 fuse
  154. 550mm and 600mm blades ????
  155. Is GY611 too much for Raptor 50 SE?
  156. Looking for an RC HeliCam service in Miami
  157. Clutch issues? Begging for assistance, loosing hair over this one!
  158. how to speed up throttle servo
  159. LEARNING AUTOROTATIONS
  160. Adding tail weight
  161. Raptor 60 Gear problem
  162. Info needed to help set up raptor 50
  163. MD500
  164. Trex to Raptor Question??!!
  165. Raptor 60 V2 Main Shaft Installation
  166. Fuel for a Raptor 30 v1
  167. heli wont stay in hover
  168. Raptor 30 tail wagging
  169. How to start the engine alone?
  170. Raptor 50 starting shaft
  171. thunder tiger 39 engine problem
  172. problems in Raptor tails?
  173. Installing a 90. engine into a raptor 50.
  174. Canopy Brace?
  175. wash out link strikes fly bar (loop) rod
  176. Raptor tail gears stripping
  177. Raptor 60 & Scale Hughes body-What engine?
  178. Did i get a good deal? Raptor 30 V2 $932.00 shipped
  179. Beginner Blade Pitch Settings
  180. which direction should the main blades and tail blades be moving?
  181. Picture of Heli Parts?
  182. Question about raptor 30 V2
  183. Carrying a Raptor
  184. TT39 Engine tuning AGAIN!!!
  185. Raptor 50 Setup/Servos
  186. Airbrushed Canopy, Let me see yours, I need Ideas!!
  187. ROSSI 65 / RAPTOR 60
  188. Broken Tail Housing!
  189. Need Clutch Dia.
  190. OS 91 problems
  191. Strange hovering angle, how to fix?
  192. One way clutch freeze up
  193. Best Place To Buy Raptor 30 V2
  194. Longest hands off hover
  195. Slow pirouettes
  196. What part of heli to look at
  197. A humble request...
  198. Stripped threads in muffler
  199. TTR39
  200. Lubrication
  201. Raptor version 1 and 2 diferences
  202. R60 paddels
  203. Help with painting a fiberglass canopy
  204. head speed wow!
  205. Oh what servo to get?
  206. Setting up the GY401 and GV1 on a JR x347
  207. dyed a canopy
  208. Rev Max?
  209. Ahh the dreaded boom strike.
  210. How much Flight time a Raptor 50 can give you????
  211. Raptor 60
  212. Which Raptor 50 to buy?
  213. Hangtimes Hobbies is great.
  214. Which Raptor???
  215. 30 Raptor to pick up 1 1/2 lb camera? Possible?
  216. 3d Masters Champ
  217. Governors & 3/4 Throttle
  218. no tail wag
  219. what should be the best way of installing header tank?
  220. Homemade training gear
  221. Raptor 50v2 making new noise
  222. Drive belt question!
  223. Hitec Eclips 7 setup for use it whit a GY401 and a GV-1 Governor???
  224. Engine Temp?
  225. First Time
  226. raptor 60 servos
  227. Finally did some autos, and might have a bad bearing.
  228. Engine tunning
  229. Raptor 60 / Tail Turns At Spool Up
  230. bouncing
  231. Problems with TT39
  232. Raptor 30, Webra 35 should I convert to a 50
  233. Problem with Rappy 90 tail rotor
  234. Want to try some different blades this time.
  235. battery checker question
  236. Rapter .30 for sale!
  237. MAXX lights on my MD500
  238. few buying questions
  239. gyro problem?
  240. os 90 starting nightmares
  241. Rotor Head Speed
  242. anyone ever order from here?
  243. Carburetor problem
  244. FUEL QUALITY
  245. Scale body for Raptor 50
  246. Messed up thread
  247. Thunder tiger 36 pro engine 30 percent oil what glow plug?
  248. Futuba 9254 servo question
  249. OS 50 Hyper - Help removing piston
  250. Lucky Escape
