PDA
View Full Version : Thunder Tiger - Raptor 30, 50, 60, 90
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17
  1. NEW Raptor 50 V2 COMING !
  2. Os Carb Tt39
  3. Flybar lock for Raptor
  4. Raptor 30 V2 TT39 & gyro questions
  5. New Rapter 30 V2 on the way!!!!
  6. RapV2 (30) weak spots?
  7. Raptor 60 Flew By Itself...
  8. need set-up help with raptor 30 and jr 8103
  9. raptor v2 30 prob
  10. Can I use a Fma Co-Pilot with a raptor?
  11. Raptor 30 HELP
  12. simple converting question
  13. GV-1 installs?
  14. Raptor 30 One Way Bearing Problem.
  15. Need Raptor pictures for my Website Gallery
  16. Raptor 60 in a Fuselage???
  17. Raptor ARF or not for a newbie
  18. My First Hover Without Training Gear!!!!!!!!!!!!!!!!!
  19. Raptor 30 V2 and TT header tank....
  20. Header Tank
  21. Newbie decision
  22. raptor 50 t/p comvination
  23. R50 V2 setup for Futaba 9C
  24. reverse rotation
  25. Out Of Track Condition
  26. 30 vs 30 v2
  27. Tuning problen on a TT .39
  28. Four stroke Raptor?
  29. Nubee Needs Help!
  30. Newbee question on Flybar.
  31. raptor 30 wont turn over help
  32. First hover
  33. Does ACE fix Heli-craft TT39?
  34. gv-1
  35. quertion about tuning a TT .39
  36. My first Raptor V2
  37. New Raptor 30 v2 website
  38. R50v1 How to fix woof poof
  39. Dumb question, but i am a newBee
  40. Raptor 60
  41. Rap 50 w/ gy240?
  42. TT39/CP15% compares to OS32/CP30%
  43. Running in cold weather
  44. Flybar Bearings removal?
  45. Os .46 Fx-h Tunning
  46. aftermarket canopies
  47. Raptor 30 Hover help
  48. Engine lugging on Raptor 30
  49. Rap30 engine tuning.
  50. Setting up my Raptor 30 V2
  51. Need Raptor 30 upgrades,cheep
  52. best place for raptor upgrades ?
  53. Help!!! OS 32
  54. Getting Raptor 60....Any Upgrades?
  55. Opinion's of TT 39
  56. Broken crank in .50H
  57. Raptor 30v2 driveline irregularity
  58. Raptor 30v2 remote glow location
  59. Raptor Problem's
  60. To oil or not to oil.....
  61. Good muffler for V2 TT39 ?
  62. tt39 tuning
  63. raptor 30 and 410 gyro-bad tail wag HELP!!!!
  64. Raptor 50 V1 vs. Raptor 50 V2
  65. Raptor 50 V2
  66. Starter Clutch Slipping?
  67. Tail Question
  68. Can I start my Raptor with a drill?
  69. Heli-Kraft feedback
  70. Two batteries on my Raptor 30V2 TT.39 ?
  71. first Heli
  72. Killer question- honest answer wanted;
  73. larger tank for raptor v1
  74. Thunder Tiger Carbon blades for Raptor 50V2
  75. Raptror 30 upgrade?
  76. TT.39 and nitro, how much? Before and after break-in.
  77. Fan Hub Removal
  78. Need Advice / What to buy - Raptor V2 60 OS70
  79. How do i increase the compression rate?
  80. When should I attempt Autos and piro autos!
  81. Over my head?
  82. Rx antenna
  83. How much nitro?
  84. Raptor 50 V2 - Assembly Problems
  85. Who needs head loaders.....
  86. New Raptor 50 V2
  87. Broken TT50 main bearing.
  88. Raptor 30 V1 upgrade to V2
  89. Difference between a Raptor 60 and 60 V2
  90. TT .39 Won't stay running, Help!
  91. Lets see ur raptors
  92. R30V1 and R50V2 Blade grips move inward/outward.
  93. raptor 30 v2 tail shake and twitch
  94. WOW !bad try
  95. Raptor 50 V2 Bearing Count
  96. v1 canopy fit v2?
  97. Problems with Raptor 50 V2
  98. Flipping the Grips - Good or Bad?
  99. Elevator Linkage Replace or Upgrade?
  100. Raptor 60 v2 main gear binding
  101. Servos for R30?
  102. LOOKING FOR RAPTOR 30 for sale
  103. buy buy buy
  104. TT50 in Raptor 50 V2
  105. R30 V2 Clutch
  106. What the difference between V2 30 & V2 50 ?
  107. second bearing on pinion gear modification, R60
  108. GY240 & Futaba FF9
  109. What upgrades would you like to see for the Raptor 60?
  110. Raptor 60 and GV-1
  111. Raptor 60 minimum servo torque?
  112. raptor 60
  113. Raptor 60 V2 building
  114. Canopys for Raptor 30 V1
  115. is this 30 v1 fixable?
  116. Does TT 39 fit in a V1 30?
  117. Thunder Tiger 39 - Engine cooking!
  118. Raptor 30 Upgrades
  119. Blades and Flybar paddles?
  120. gyros for raptor 50
  121. pics of my first flight!! 15 mins ago...
  122. Wow!!! Check This Out!!!
  123. raptor 60v2 must have upgrades
  124. Raptor 60 Up grade parts????????
  125. Raptor 50 clutch problem
  126. Small Problem, Please Help!!
  127. First time hovering Raptor 30v2
  128. Strange Noise Please Help
  129. TT39 Very Little compression !
  130. 30 V2 5 Point curve settings ?
  131. help with damper rubber sizes please
  132. Raptor and Tiger Shark Fuselage
  133. explosive blade fluttering
  134. bearings
  135. Electric Raptor 30?
  136. ordering from cyberheli
  137. arf raptor v2 question
  138. bent boom!
  139. Real Flight G2 with Raptor 30 & 60
  140. Sticky Carb
  141. R60 one way bearing lockups ??
  142. Raptor .30 Tail Oscillation
  143. Raptor Beta /prototype 580 blades tail rortor and etc
  144. Tt 36 Whats Up Whats Up With These Engines
  145. Night Flying Blades and Lights
  146. Raptor 30 Shakes
  147. New TT Raptor 60 Metal head and grips.
  148. Another tt36 ????
  149. 50 Conversion Mounting Question
  150. Helicopter Radio setup
  151. r30 with funkey a109 agusta
  152. Good Servos & Gyro for R30 V1, RD6000?
  153. Best Blades for Rappy 30 V1
  154. Rappy 60 Arf or kit???
  155. Raptor 30 V1 vs. V2 frame
  156. Forum Newbie
  157. TT39 Engine Overspeeding
  158. futaba gyro w/ jr receiver?
  159. r30 rear tail assembly
  160. Raptor 30 V1 Canopy vs Raptor 30 V2 Canopy
  161. Whats the deal with parts?
  162. Can someone post some R50-V2 Pictures?
  163. Raptor 60 V2 ?
  164. V2 Pro Build/Assembly
  165. Wesson pipe on Raptor 30 V2
  166. new to forum
  167. Raptor v2 30 sport vs pro
  168. Electric Raptor (RappE!) 50 V2 FLIES today!
  169. rudder and throttle wicked reaction
  170. Raptor 30 V2 ARF updates ?
  171. Raptor V1 manual in PDF ?
  172. Low freqency vibrations on Raptor .30! Any suggestions?
  173. TT39 Engine HELP
  174. Words of wisdom
  175. Clutch bell on Raptor
  176. Centurys Raptor Clutch
  177. Shakes
  178. Servos For A Raptor 60
  179. Any of the Rapto 60 Upgrade a must have?
  180. r30 quick fix
  181. Slipper clutch for autos
  182. TT 36 ate some metal
  183. grass snagger on the V2 tail?
  184. RAPTOR OWNERS>> PLEASE HELP!!!
  185. Radio Whats Best For Raptor
  186. Rappy owners advice PLEASE!
  187. Raptor 50 Blade choices
  188. Raptor 60-ys-80-clutch Problems
  189. metal fan or plastic ??
  190. Ordered a Raptor 50 V2... Anyone else?
  191. NEED BEARINGS for Raptor 30
  192. Raptor 60 or 90 without GV-1 .
  193. .30 V1 Gear ratio for GV1
  194. need tips on raptor
  195. Raptor Main Frames: Please Help!
  196. Raptor 30 w/tt36 carb cleaning?
  197. New style low end needle valve on TTpro 36H
  198. raptor 30 throttle bind
  199. Raptor 30v2 got the shakes!!!
  200. Bought a used Raptor 60. What should I look for?
  201. Liner replacement
  202. Remote Glow Plug
  203. Raptor 30 v2
  204. Raptor 30 lubrication
  205. MDS 38-H engine
  206. TT39 power specs?
  207. Raptor 50 V2 released today?
  208. Raptor 50 V2 now available
  209. Quick UK Fan Wobble
  210. TT 36 pro heli engine piston
  211. Raptor 50
  212. Raptor .30 engine question
  213. Futaba GY401 Gyro Setup - Please help
  214. Raptor 30 to V2
  215. Tired of an oily dirty hellie !
  216. Raptor 60 TT engine Breakin
  217. Raptor 50 Thoughts?????
  218. Team Raptor
  219. Raptor 30 V3????????
  220. Tt R30
  221. Raptor 60 w/ YS 61-S
  222. raptor30 v2 fuselage and engine
  223. Creeping Raptor........
  224. Raptor 90 Booms
  225. frame repair
  226. Raptor 60 V2 thoughts!!!
  227. Raptor 50 Discontinued??
  228. Increase for the price of raptor parts?
  229. Thunder Tiger field box
  230. Fly-bar mixing ratios
  231. Raptor 50 building questions
  232. Raptor 30 V1 Main Frames
  233. govener on rappy 60?
  234. Learning to hover
  235. Raptor 60 To R90
  236. OS 50, CY muscle pipe, no governer. What's your curve look like?
  237. Raptor 30 - Century Bell 222
  238. Is it a good idea
  239. Raptor Tuning TT39R
  240. Weston pipe for Raptor 30 or Good pipe
  241. Jet Ranger Fuse For Raptor 60
  242. upgrade washout base on R50?
  243. metal washout base?
  244. Raptor custom canopy ?
  245. Rappy 30 and the V2 clutch Q.
  246. Raptor .30 V2 manual online anywhere ?
  247. Raptor Group
  248. CCPM Raptor?
  249. CyberHeli's new Raptor 60 metal head
  250. Rap 50 blades
