Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
Top Flite Cessna 310 posted
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 08-04-2007, 10:51 AM
  #2026
COL J
Default RE: Top Flite Cessna 310 posted
Hello,
Where did you find the lady pilot figure?
Old 08-04-2007, 01:59 PM
  #2027
Bill D
I to will be using Saito 82's. The 310 is on the board . It has not flown as yet so I am unable to to tell you how well it flys. Size wise the engines should fit . If you get to the engines in and ready to go please send me a EM on how well these engines fit and ran.Thanks Bill Downs. [email protected] FOREVER
Old 08-04-2007, 08:09 PM
  #2028
handyman_alw_
My Feedback: (14)
handyman_alw_'s Avatar
RD
I have a fuse with minor damage and i think a half of a wing that would be fixable with the right person.
Allen
Old 08-04-2007, 08:29 PM
  #2029
timothy thompson
rk i have one apc 15x8 and ordered 3more. everyone is telling me i will do better with those that the wood zingers.
Old 08-05-2007, 03:20 PM
  #2030
timothy thompson
with the apc 16x8 984 watts 50amps 22.4 v
87watt/lb not too bad for a heavy twin
Old 08-05-2007, 06:00 PM
  #2031
timothy thompson
WITH ZINGER 16X8 1070 WATTS. GO FIGURE
Old 08-05-2007, 06:37 PM
  #2032
TonyF
My Feedback: (92)
Hi Michael,
The Evolution .52's fit perfectly, no issues. I find the power to be very good. I have had one or two engine out's but they have always been on the downwind leg so I didn't have to try to climb with one engine, just maintain and then descend to a landing. I had no problems handling the model in that situation.
I put 12x6 APC's on it this weekend and I think that's the prop for this set-up. I'm using the Bisson Pitts muffler with the Lex-Aire extensions. They seem ideal.
I'm on 21 flights so far, and loving it!
Tony
Old 08-05-2007, 06:54 PM
  #2033
Bill D
Al I didnot receive your EM only a a msg that you had sent a reply. Please send your past reply. Re saito 82'
s .Thanks Bill Downs
Old 08-05-2007, 10:50 PM
  #2034
timothy thompson
flew tonight with one zinger 15x8 and one apc 15x8 best flight to date nice and fast no yaw issues . I might have a bipolar 310!!!
i will put two zingers on and paint the flat black with yellow tips for the scale look or maybei should leave it alone
BTW shes electric
Old 08-06-2007, 10:08 AM
  #2035
RK-Aircraft
My Feedback: (81)
Tim,
It very important that you ordered the "e" type props. The standard apc will do you no good. The camber at the root of the "e" props and the taper is what makes these efficient. You will see that this is not the case with conventional props. So dialing in the diaxpitch only, will not give you the right numbers. Are you using Motocalc?
Old 08-06-2007, 10:14 AM
  #2036
RK-Aircraft
My Feedback: (81)
Tim,
If you paint the props, be sure to balance them after you are done painting. I have used clear enamel spray on the back of the "light" blade to balance a painted prop without scuffing out xtra material on the "heavy" blade.
Old 08-06-2007, 01:35 PM
  #2037
timothy thompson
they are e props. no difference in performance between the two
Old 08-07-2007, 04:49 PM
  #2038
Fearless Freddie
Has anyone flown their TOP FLIGHT 310 off grass field yet?
FEARLESS FRED
Old 08-07-2007, 05:38 PM
  #2039
herm
electric?.. very interesting.. what was your duration and how many mah did it take to recharge the batteries?
Zinger props are a waste of time in electrics.. any kind of APC will be nice, sport or electric (except slow fly props).. if you want a wood prop try the master airscrew series, Tower sells them.. rework them a bit, sharpen the trailing edge, smooth out the leading edge then thin down the airfoil shape a bit.. then rebalance carefully. Just as efficient as APC but much less prop noise at the 1000watt level.
Zingers are good if you rework them, good starting stock but lots of sanding dust.
Do you think 1000watts per side is enough?
Herm
ORIGINAL: timothy thompson
BTW shes electric
Old 08-07-2007, 07:09 PM
  #2040
jaycam
Dick Petit flew his off grass for his reveiw video on the other forum type website that deals with "groups" of "RC" pilots. It flew very well.
Old 08-07-2007, 08:01 PM
  #2041
jetnuno
OK guys,
Pick mine yesterday. Beautifull airplane and impressive box. I have already start building, because I took the time to READ THE ENTIRE THREAD in a couple of weeks ago. Very usefull. Thanks to everyone who posted.
I leave in a small country, so I was lucky enough to find a couple of OS 50 SX. New stuff takes some time to get here, so old stuff keeps longer time. I already got the Bissons mufflers, but would like to get the lex-air extensions. I have notested that the seller only sells to the US. Anybody knows where can I pick 4 of these or give me some dimension drawings to make these myself?
Also I am trying to take some of the lead up in the front but this is becoming a hard to do. I read something about that in a older post. I believe if I put the battery packs up in the front I can save some wheight by taking out some of the lead. Any ideas how to do that in a easier way?
Also there were some questions about the tight fit of the fuel tanks. I am planning to put another ones or is this avoided by scraping some wood and put some silicone? Anyway 420c.c. seems quite good for the .50. Something arround 350c.c., should work for 15 min.
I will wait for the Robarts and also planning to put the working doors with air cilinders.
Regds
Old 08-07-2007, 10:41 PM
  #2042
timothy thompson
petits was glow! yes
1000watts per side is fine.
22.6 lbs
my longest flight is 12 minutes today. took 2200mah.
it takes about 1.5 hours to recharge all. i balance them every other flight
Old 08-08-2007, 01:27 AM
  #2043
herm
how many watts are you pulling with the APC 15x8 props?.. and this power level is fine for flying off grass?, do you wish you had more?
If I understand correctly, you are using two 3s packs per nacelle in series, each pack is 5000mah so you essentially have a 6s 5000mah pack per nacelle.. and after a 12 minute flight it took 2200 to recharge one of the 6s pack.
Are you using one or two chargers?, yes one charger would take forever. It sounds like 5000mah batteries are too much, you could get over 20 minutes of flight time with them. You probably could save some weight with 3000mah packs and still fly 12 minutes. It is good to have an excess of juice.
is the flight speed adequate with the 15x8 props?.. they definitely have a lot of thrust to get off the grass.
Video would be nice to show electric deniers
petits was glow! yes 1000watts per side is fine. 22.6 lbs my longest flight is 12 minutes today. took 2200mah. it takes about 1.5 hours to recharge all. i balance them every other flight
Old 08-08-2007, 01:42 AM
  #2044
timothy thompson
correct i have an electrifly 4 place charger and charge all 4 at one time then i balance the cells and go fly. i need a second set of batts to fly longer.speed is fine loops and rolls ok fly it like a scale plane no pylon turns
Old 08-08-2007, 09:58 AM
  #2045
algutkin
Herm,
Are you the same Herm that flies with Cubano?
Check over at the other site, RCGroups, conversion to electric forum, Cessna 310 thread, started by Bruff. Based on what I read, Bruff is the person that knows about converting to electric. After checking in over there you will see who did what conversion, and also who is an expert at what.
Sometimes, things posted just don't seem to add up.
Al
Old 08-08-2007, 10:05 AM
  #2046
Fearless Freddie
Timmy ,
is your plane too weak underdesigned to fly off a grass field or,what ?
Lets see waht you've done??
I do not understand your flight report ........ What is it you are you doing?
Old 08-08-2007, 12:01 PM
  #2047
herm
a little harsh Fearless?
Old 08-08-2007, 12:06 PM
  #2048
herm
Thanks Al, yeah that is me.. found the thread at:
http://tinyurl.com/yrtf4q
ORIGINAL: algutkin
Herm,
Al
Old 08-08-2007, 01:58 PM
  #2049
timothy thompson
fearless you have been reported, just keep it up. Are you so uninformed to realise pettit used glow and i am electric. i also have my own privite strip so i have no worries. 400x 400 asphalt
Old 08-09-2007, 12:35 AM
  #2050
algutkin
yes Herm, it turned into the Tiny Tim thread and it seems like we all are dancing through the tulips. LOL
It seems that one minute a guy knows nothing about electric conversions, the next minute he is an expert with 12 minute run times on 5000mah lipos and 110 Eflite motors powering a 24lb Cessna 310. Then the same guy turns 4 of us into the mods for laughing when he complains about being called by his own nic name.
What is wrong with this picture?
If anyone want electric information on conversions, try the other site, RCgroups, there are so many active threads in the conversion forum that are so full of info, that it's almost impossible to keep up.
Al
