LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
#1552
NL, CANADA
RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Ok, I don't know much about this, but do you mix the fluid with the grease that your gonna use and put it on the diff gears or use the grease to seal the diff so nothing will get in the fluid and just put the fluid on the diff gears? Sorry LB, but I don't really know much about this stuff.[]
Need to look over this thread more often![:@]
#1553
Nah, I just made things up as it goes myself..
I use the grease to kind of seal the fluid, if you will.. so on the edge, I use some grease, and in the middle, I fill it up w/ the silicon fluid.. and when I put things back together, some of the grease will get squeezed out, and I just clean those up..
Not saying it is the way to go.. just how I did it.. ha!
#1554
NL, CANADA
Sounds great thanks! I got some excellent grease, so I might make a LSD diff.
But as I said before, I'm sticking with bushings around the truck, but I really would like it to be fully ball raced, those rubber bearings on ebay where you can get full set for it, I was thinking of picking one of those up, but since the price is in U.S., I have to pay it more in Canadian![:@]. Also, the guy that sells the bearings have to charge me more for shipping![:@]. This is why sometimes I hates when buying out of country, have to pay more for shipping mostly.[:@]
I found regular bearings that fits well at my LHS, but they are not rubber sealed, so gonna rust mostly, but I did mention rubber will rust, but IMO, I don't think really they rust, since they are sealed with some kind of piece of rubber or plastic attached at the sides of the bearing.
But these seems ok, as what is being said from this seller, but they are not cheap!:
http://cgi.ebay.com/RC-Bearings-KYOS...3286.m20.l1116
Bushings are ok for vehicles that are pretty slow like these, but would be nice for BB's for smooth tranny movement, but using bushings, better grease them. If not going in snow or any wet conditions, I can use standard BB's so no worries about rusting, but what is so fun about the Blizzard, when not going in snow? Right? These are meant for snow and other extreme terrains!
#1556
One thing to remember bearings that are sealed have grease inside them. The grease will keep water out. You mentioned putting grease on the outside of them to keep out water but the grease inside them will do this. Some sealed bearings have removable seals so you can clean out old grease and put in new grease when needed. I think you would be very surprised how rust resistant bearings are as long as you do not let them sit in water.
In Canada look for a bearing supplier. Measure your bushings and order the bearings from them most the time at a cheaper price too. I have a few places I was going to order bearings from that are not a hobby supplier. You can pick what kind of bearings you get, how good of a seal, stainless, etc. All you need are the inner and outer diameters of the bushings they will replace.
Edit: I just looked at the bearings you found on ebay. My opinion they are junk for the price they are asking. They have a ABEC 1 rating, this is the lowest tolerance spec for precision bearings. If you are going to go through the trouble of upgrading to bearings I would go with nothing below a ABEC 5. Alot of people will tell you ABEC ratings do not mean much but in my experiences the higher the ABEC rating the better a bearing works. Not all bearings are created equal and ABEC ratings are a good way of weeding out the bad ones and finding the good ones.
#1557
NL, CANADA
Well, I don't know if they are bad or good, but I am working so hard to found the rubber seal BB's in around Canada. The only ones I found are BB's with plastic like material or fiber glass that is on both sides of the BB, they will do a good job keeping dirt and dust away from the insides of the BB, but they won't work against water, they will still get in the BB. Guess it's last resort, bushings. [:@][:@][:@]
#1558
ORIGINAL: Mad Racer
http://cgi.ebay.com/Kyosho-EP-Blizza...3286.m20.l1116 I think you're mind gaming yourself on bearings. Most go with this seller ... cheap & fast shp'g. Read his info and pick the set you need. All I do is blow the blizzard off and take it inside. No problems at all.
#1559
NL, CANADA
Yeah, I was thinking of moving to that one, but I don't understand what the seller means by building combos. You know?
#1560
ORIGINAL: Mad Racer
#1561
NL, CANADA
I don't really know what the seller is meaning by that, but I guess he/she is probably the best to get BB's from. Since those BB's are rubber sealed on the sides, no water can get inside the BB right? But will there be rust on the round parts on the BB?
#1562
Build your own combo just means you can choose and pick how many metal shield ones, how many rubber shield ones, what size, etc. Instead of the pre-packaged stuff he has...
#1563
Click on the big red "here" in the auction and it takes you to a site that describes all the bearings available. You can get metal shield, rubber shield, colored shields, steal balls, ceramic balls, even stainless balls. This allows you to pick and choose the best bearing for its specific application vs, just buying the assortment the seller has made up.
#1564
Just buy it from walastore on eBay. He have everything from abec1 to ceramics at reasonable prices. You can pick metal shield or rubber versions.
#1565
NL, CANADA
ORIGINAL: Cross
#1567
I got my EP DF 300 today. Trimmed and painted the body orange. Put a XL-5 ESC in and left the stock motor. Put the rest together and tried it out. I see what everyone is saying about the diff lube. Right side only wanted to move until I adjusted the steering trim. The stock motor actually had pretty decent go to it.
#1568
Got 6" of snow yesterday.. so the Blizzard got some workout this afternoon!
http://www.youtube.com/watch?v=7- -n_wTyNXU
RCU is not allowing me to post the proper link.. so you just need to copy and paste the 2 above (I broke it off in the middle) and you will get to the video..
Looks like "- -" is being translated into "_" by RCU.. [sm=confused.gif]
#1570
Hmm.. Try again?! It somehow gave me a different link when I uploaded it.. it should work now!!
#1571
ORIGINAL: Lunchboxer
http://www.youtube.com/watch?v=7n_wTyNXU
#1572
Thanks SecretSG! I think I am slowly learning how to use the camcorder a little bit better.. instead of the automatic mode, there's a mode to let the camcorder calibrate for the white balance.. so I think the video I did today is slightly better than before.. (well, if you don't mind the shaky hand + off focus when trying to look for the Blizzard.. !)
I guess we don't really get that cold.. my 3PKS seems to be okay.. ?! Maybe I just didn't pay attention..
Yeah, my Blizzard was working really well.. I can lock the track or turn very very gradually if I wish.. the combination of mechanical changes (pads + LSD) and electronics (exponential setting on the 3PKS) makes it very easy to drive.. !
#1573
NL, CANADA
Ok, it works now. Thanks. Great video. That is some hard pack soft snow!
Just started to build mine, what a pain, it's not that it's hard to build, it's just that I can't find and remember where I put my tools too!!![:@]
I only found some scredrivers, but I needs my Tamiya liquid thread lock, but can't seem to find it!!![:@]
#1574
NL, CANADA
I never had time to order the fluid, anyways, I don't think I need it, but I'm sometimes thinking of will it leak out of the diff gear box. Also, using bushings, but greased them at least, pictures soon to come.
#1575
QC, CANADA
Hello all,
First of all Happy New Year for all the Blizzard enthusiasts !
My cat is now completed so here are some pictures :
It's running a Sidewinder + 5700MM and it should see snow for the first time today.
