CMP Hellcat
#1651
IL
Hi HOOKMUT I have the os 108 in my hellcat and have set the cg about four and three quarters inches back from leading edge . I balanced inverted with gear retracted . Is this good or do i need to change it? please send me you figures and throughs on elevator and ailerons. Thanks TOM
ORIGINAL: hookemut
Hi,
A comment wrt the flying qualities of this Hellcat model:
Do not let your model's cg be aft of value specified in the manual-it is very sensitive in pitch and an aft cg just leads to big trouble! Also, heed the throws called out.
The Great Planes AccuThrow Deflection Meter is extremely valuable in both zeroing and measuring throws on all surfaces-which btw are not flat surfaces.
On my OS 1.08 the Hellcat goes like a scalded ape!!
Jim
Hi,
Jim
#1652
My Feedback: (59)
CA
ORIGINAL: BentMetal
Know what you mean Randy, can't wait to see how it handles with the scale wing. I'm predicting good scale performance, since the stock wing makes it fly like a trainer almost.
As some of you know, I sculpted my own pilot (and made a silicone mold) for this plane, although I never got motivated enough to cast more for other people. I did score some featherweight casting resin that's used to make floating fishing lures and things, it's super light. I wanted to cast a few with that stuff to see how they work out. Hollow casting the pilots is to much work, and I think they could be made lighter with this new resin even if they are cast solid. The resin is mostly filled with a sort of Micro-Balloons or something, cool stuff.
Luke
Luke
[8D]
#1654
NJ
What paints are you all using for the tri-color(1943 - early 1944 scheme) Hellcat ??? [email protected]
#1655
Canopy Question -
Guys, With Lukes Canopy are you manually sliding the main section back or do you have it hooked up to a servo?
I will be attaching mine tonight-
Thanks!!
Thanks!!
#1656
@warks62;
First off, congrats to this absolutely gorgeous Hellcat. Much better looking than mine, really. What I noticed with your paintjob is the same effect I noticed on mine. In the broad sunlight even the dark blue brightens up quite a bid. Take your time with the maiden flight. Everything must be perfect for that. No compromises.
Good luck
thevirginian
Good luck
thevirginian
#1659
Here's a question for you guys...
When I fly my Hellcat I have a hard time getting a straight and level track. It's very touchy on the elevator as if it is sort of porpoising a little. It's not totally out of control, just hard to keep straight and level.
I've reduced my elevator throws as much as I care to go.
According to the plans, the CG should be around 25mm. Does this sound like a tail heavy situation?
Thanks, Chris
Thanks, Chris
#1660
My Feedback: (140)
Chris I haven't flown my modified one yet but my stock one did the same thing. I added an extra 2 oz of lead to the nose and made no differnece. I finally put about 25% expo on the elevator and then it was good. It takes very little movement on this plane for a alltitude change. It has a large elevator which I think is part of it. It worked for me anyway.
Randy
Randy
#1662
My Feedback: (140)
flyfisher431, expo is actually expotential. It slows down a servo in the first part of the movement but full is still full. The 3d guys use it a lot. So long as you have a computerized type radio it will have it in it. Read in your radio manual on expo it will explain it much better than I can but I will try. Lets say a servo moves a 1/4" of travel with 1/4 stick movement. With 50% expo that same servo will only move 1/8" with the same 1/4 stick movement. Now this only approximate not actuall measurements. But as you move the stick further the servo will start to catch up with the stick untill full deflection on the stick is full on the servo think of it as porportional. That way when you want full elevator you still have it but the first part of the stick will be much less sensitive depending on how much expo is dialed in. Like I said the book will explain it much better. Some warbird pilots don't believe in it but I do but it is something you have to try and see if you like it. I only use it on a plane if I think it will help and the Hellcat is the only one I use it on except my B-25 I use it on the nose steering so that it is less sensitive on take off and landing but I still have a load of steering if I want to make a real tight turn.
Randy
Randy
#1665
My Feedback: (44)
AND Bent Metals' too!! love the rivets on both replicas real nice now to ask a question which I'm sure is some wheres in this here thread that being :"How do you do your rased rivets specifically is it RC-56 a form of water based white glue-
Thanks for any answeres and again nice HELL CATS[sm=49_49.gif]
#1667
AK
warks62,
Don't sell yourself short. That was a great explanation and I'll for sure read up in my manual. I just recieved my new Spekrum DX7 and that is going to be my principal radio for all my new planes. Right now I'm preparing to start work on a GP P-6E Hawk and the Hellcat is the next bird after that. This build thread is a gold mine of information by the time the Cat comes out of the box I'll feel like I've already built two. I'm a true beleiver that experince is the best teacher, even better when it is somebody elses. [sm=idea.gif]
Thanks again
Ben
Thanks again
Ben
#1668
My Feedback: (12)
I use a hypodermic oiler made by Gaunt Industries near Chicago. Website is www.gauntindustries.com . I use the Hypo 25 and a 2 oz. bottle with Titebond diluted 25%.
They cost $2.50 each in quantities of 6-11. This Dave Platt's discovery.
#1669
My Feedback: (140)
Thanks Hal I will also take a look because trying to come up with the needles is real bummer. I keep hoping to come across someone who is diabetic to get some needles but no luck. I make sure that the one and only needle I have is very clean after use. I see now what the Heroine users go through, LOL!!!!
Randy
Randy
#1670
NJ
Guys--I appologize if I'm missing something in using the "threads" here. I've "posted" several questions about putting together the CMP Hellcat and associated 80 " inch Jap Zero. I see many other responses , and believe I may be mistakingly missing / not being able to access a "pile - of -responses" somewhere here in cyber-space if I'm looking in the wrong place. Seems pretty simple, as I look at the title of the aircraft -- ie" cmp Hellcat ", but have yet see anything in response to my questions (and I think they're somewhat intelligent questions...., an expert builder may not think so..whatever..??). The questions have been mainly pertaining to the (1) Sierra retracts installation (heard no answers in reponse to my multitudes of questions/ and advocating input on that area of construction, (2) building up the wing after gear installation (spar buildup, glassing the skin, etc. ) and input on (3) successful use of various priming / painting the aircraft. These are just a few. I am a somewhat experienced builder---but I'm never done "learning" , as with full scale flying...however, I'm at a loss here with where to look for my (hopefully) multitudes of answers I'm awaiting for. There are some beautiful Hellcats here---and want to join in on the fleet of completed aircraft. I'm a better builder than an e-mail/ rcuniverse user---someone please set-me-straight on what I may be doing wrong. ?thx--ed "sark"
#1671
My Feedback: (140)
Ed Sark, try reading this thread from the beginning you will find every answer to what you are asking here, plus maybe some more that you haven't even thought of yet. There are some great pictures posted showing step by step everything that has been done. Just start at the beginning and you will find a lot of great information. Luke and Hal have posted some great build pictures along with many others. There are some great pics of the retract install with Sierra's.
Randy
Randy
#1672
NJ
Randy at Warks 62--Thank you for setting me straight.....Just read it..( I'm "crossed eyed", I just got in from work this morning----late red-eye) Randy --now I see how I have to go back, way back on the 'thread' to see ,...I was in need of remedial rcu universe help ,...ya just broke the code ...Now----thanks First of all, to individuals who built these Hellcats>>>---commendable work...unreal. Many of the crewmembers, ordinance men, mechanics, aircraft deck-handlers , and pilots / gunners of my Dad's Pacific Carrier, The Yorktown(CV-10) have a keen interest in the emulation of these planes they worked on , flew and strapped ordinance on >>>they would love to see these online, or I can print/ mai the photos if you e-mail em.....l---I cannot get these to go print from RCU ot to frwd e-mail from rcu to them-----If you want to e-mail me photos of your work directly ----you guys do greeeat work here >> and I can frwd to these guys , all in their 80's and 90's. There are pilots of the CV-10 Yorktown from Air Group Three and AG 88, from late '44 and '45 --they would love to see these remakes of the planes they flew....When you talk to '
em at the reunions, the hands start flying through the air, "air action".... The greatest generation.....
Randy--thx..Lukethx..----I just got your canopy kit...radial...great work---Thank you!!!!! Edward A. Sarkisian nlooking for e-mailed photos I can forward to these WW2 vets, guys.... Sarks757 @aol..com
#1673
NJ
heh Richard L---I have the os 1.2 for the cmp hellcat---would you let me know what you think---ready to break in the 1.20 os fs...lots invested into that engine. Yopu mentioned the Hellcat would be nose heavy with that engine and the alum mounts. Seems though we can always 'easily' move the cg aft>>anyone comment..batteries, etc, to slightly aft of the wing area in the fuselage. What fue tank did you use??>>>>>>And esopecially what orientation didn you mount the engine?> Head at 90 degrees to starboard, or head at "6'o'clock"?? If you ran the engine head at 6 o clock, did you run into hydraulic lock problems>>>??Thank you--Edward A. Sarkisian
#1674
NJ
heh virginian----i'm finally learnin to reads this rc un thread follow up--copy your read on my earlier comment!!--nnnoooo problem, , man!! keep uo all the good work---sark
#1675
NJ
heh Fred--What spinner and 3 blade combo you using for the 1.20 os on the cmp hellcat. trying to keep track of what's where, by who, in reponse to who here on rcu. can ya just e-mail me a response--just in this morning---wanted to get to the field today. zero's out--redey. can you just e-mails me--?? [email protected]... having alot of troubel finding responses to multiple ' posts i've put out on sierra retracts, resupporting the spars, if necessary>>??the wing glassing-- have seen no rsponses. i've posted quite a few requests for info--ed sark
