PDA
View Full Version : Car Nitro & Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. TNX Engine 'Dinging'
  2. tamiya fr-15s glow plug
  3. .15 CV-X Hyper
  4. Axial .32 help
  5. What dremel to get for engine mods?
  6. Glow Plug for tnx 5.2r engine
  7. Storing new (Unopened) fuel in temps around 30F?
  8. Running in sub-zero temps?
  9. The "Drakes" heat cycle method from Xtreme RC?
  10. sts and go tech?
  11. Kyosho GXR28 ENGINE TROUBLE!!!
  12. Sirio 23 questions
  13. How many nitro mills do you own???
  14. O.S .18 TZ Pipe
  15. Run Times For OS 28
  16. ENGINE KEEPS SHUTTIN DOWN!!
  17. sirio .12 question
  18. O'Donnell High Performance Racing Fuel or Sidewinder World Champ?
  19. Black piston
  20. What should an engine sound like when properly tuned?
  21. Morgan Fuel - really no draining or oiling needed?
  22. having trouble with mgt 8.0
  23. fuel banjo gasket question
  24. Motor for NTC3, not sure if it will fit, type etc... help!
  25. Using a different carb?
  26. head shims
  27. O'neill brothers,Trusted?
  28. idle too fast
  29. fantom fr .12
  30. what is the point of after run oil?
  31. Shimming a head and removing head and backplate screws...
  32. Clutch Bell installation problems
  33. Sirio "Kanai EVO III" Off-Road Competition Buggy Engine
  34. Smartech 15cx
  35. Porting/polishing my engine, should I do this to the crank?
  36. What is this needle on my carb? (Pictures)
  37. PINCH TEST
  38. thunder tiger pro 21 ports?
  39. Please Help...N3 Glow Plug???
  40. novarossi plus 21-7bt help
  41. Thunder Tiger pro 28 LSN setting 6.5 turns or 3.5 turns
  42. First Time Startup Thunder Tiger ST-1
  43. Why a rebuild kit?
  44. Front Bearing Leaking
  45. What is the 4th needle(screw) that is never talked about?
  46. PROBLEM TUNE
  47. Quits when I pull glow starter
  48. Smoking Engine...
  49. HSN has seized
  50. Axial .28 idle problems
  51. Running 45 % nitro and head shims.
  52. Engine knowledge
  53. os 30vg help
  54. Mega MF21 OFR 5P
  55. Which glow plug should I use
  56. Idle speed mess
  57. New to nitro and can't get my new truck to start
  58. Mild porting on a low power engine
  59. MIP boost bottle... Does it work?
  60. Unleaded fuel.. can you use it?
  61. What header for a Picco .26 maxx?
  62. Length of stinger?
  63. O.S. vz-b engine case
  64. DIY Power increase thread?
  65. How much pinch?
  66. Resizing Sleeve
  67. hsp lsp needle where is it.
  68. Fuel mileage: V-Spec x STS MKII
  69. Please help, where to buy LPR Z.28R in Los Angeles
  70. AB Mods V-Spec on MSR 1005 dyno results
  71. Axiel 28 tuning
  72. 21 size..OS VG or RB Econo S3 for dirt oval
  73. best pipe for OS 21 VG?
  74. HPI .28 on a Inferno Truggy
  75. will my stock exhaust work with this?
  76. What is a good Temp range to run
  77. Question about SH 25/26 Engines..
  78. need help before i ruin my motor.
  79. Ofna Force .32
  80. acme truck,wheels wont stop spinning after starting
  81. lpg conversion?
  82. AB Mods V-Spec dyno results
  83. LRP spec-3 roto start
  84. Propinch -What you think or know??!
  85. Go engines
  86. exceed infinity
  87. What Glow Plug Should I use for my Mach .15RE?
  88. mega engines
  89. I think I wrecked my Engine...
  90. Make your engine last forever! almost.
  91. Anyone tried Sirio s27re?
  92. New buggie engine problems
  93. engine not starting
  94. Engine rebuild mistake....please help!
  95. WHO KNOWS HOW TO MAKE NITRO FUEL???
  96. VERTEX VX-18
  97. jpx .28 carb restricter
  98. Rotary Vs Slide carbs
  99. Needle settings
  100. TRX 3.3 sleeve removal?
  101. help with revo carb
  102. carb retainer
  103. LRP Z.28R SPEC3 Died!!!!
  104. Piston sleeve destroyed.
  105. xxx-nt
  106. OS 30VG cutting off after about 3 minutes
  107. OS #8 Glow Plug Average Life?
  108. RC10 GT engine replacement ?
  109. Where do send my O.S .30 VG-P(x) for porting etc?
  110. Any temporary fixes for 1 way bearings?
  111. this aint's suposed to happen to a OWB..
  112. how to tune a 18vx engine
  113. 2.5 jato
  114. Local Sleeve Pinching
  115. ROTO OR TIGER DRIVE ON AXIAL..WHAT FITS???
  116. average life
  117. crankshaft
  118. what would be a good nitro motor
  119. OS 15 CVR-X Vs 18CVR-X
  120. need help urgent!!plz
  121. Fantom FR27 Motor...I'm Lost! Help?
  122. Fuel mileage for 30's engines
  123. replacement cyl for cy29rc
  124. Where do the clutch bell shims go?
  125. help engine's won't run 2.5 3.3
  126. Crankshaft too short???
  127. HOW DO I REMOVE THE FLYWHEEL..PLEASHE HELP!!
  128. Question about engine temp measurement
  129. revo motor help
  130. xtm 457 engine tuning?
  131. What do my pistons say??
  132. Sportwerks.26 v2 Savage Owners come here!!!
  133. Breaking an engine in with 30%?
  134. pipe input
  135. having problems getting truck started out of box new truck
  136. Genesis 7.7
  137. lrp vs picco .28
  138. axial .28
  139. os18 starting issues
  140. OS VG and VZ-B heads
  141. Picco 28 Carb
  142. What could be wrong with this gas engine ???
  143. Dynamite Platinum .28 SG
  144. KYOSHO FAZER SETTING
  145. lrp z.28 spec3 or z.28 spec3 truggy for lst2
  146. Stock needle settings for Werks .28 B7 Pro?
  147. Piston and Sleeve Pincher
  148. What % nitro can engines handle?
  149. clutch shoes for 0.15 Tamiya engine
  150. only hard coated jp-3 pipes?
  151. Carb not getting fuel?
  152. Is it safe to run a motor without a flywheel?
  153. Traxxas 3.3 Racing Engine
  154. Starting a bump start with pullstart cord?
  155. Anybody Running a Bumpstart Mach 427??
  156. how do 2 speed transmissions work
  157. Any CHEAP motor better than Orion Wasp .28 PS?
  158. Axial.28 vs Axial.28rr
  159. Axial 28spec1s OR Mach427(blue)???!?
  160. changing from 16% to 20% fuel?
  161. LRP lovers!
  162. what happend to it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  163. looking for a SIRIO ENGINE .12
  164. Adjusting my 15 CXP engine
  165. Future Of Nitro
  166. Engine Oil
  167. Nitro mix with Gasoline?
  168. Mugen Seiki Engine
  169. running rich question
  170. What is this 2nd screw on the carb?
  171. Increasing power
  172. What of those 2 engines makes more power and torque ?
  173. CARB SIZE MATTERS
  174. RB928 and what pipe?
  175. GO engines?
  176. OS engines, head swap?
  177. Dual fuel filters?
  178. Just thinking: Water cooled nitro engines??
  179. what fuel should i run?
  180. Picco 26 Big Block
  181. cannot prime motor
  182. Can RC engines overheat from idling?
  183. STS D21B D21T, same p/s?
  184. Header for US Engines?
  185. Difference between Adam Drake "Draked" and Un-"Draked"?
  186. Can i exchange parts on the Os 18tm or Os 18Tz engine versions?
  187. .27 sirio parts
  188. i want a cvec pipe
  189. Ceramic Coatings
  190. need help please with jato engine swap
  191. NeoBuggy says US Novarossi prices will drop.... but
  192. Do I need a new one ?
  193. Strengthening conrods?
  194. removal of shim from engine. good or bad?
  195. SSK Thunder Tiger Help
  196. Starter Box?
  197. my new axial .28
  198. MOVED: Exchangable Shells?
  199. Traxxas Roller Clutch Problem
  200. best engine for traxxas jato
  201. Need Help Im New...plz
  202. engine modding
  203. HOW IS THIS POSSIBLE
  204. Do you know this engine ?
  205. P7R Evo
  206. hows a worn out engine run ?
  207. Turbo vs. Standard
  208. OSROCKET Rocks!
  209. .28 vs .21 runtime what to replace my axial .28 with?
  210. Help with glow plug for mach .21 turbo
  211. diy nitrous oxide injection tutorial
  212. Checking temps on engine with Infered
  213. fuel injection
  214. BEST PIPE FOR RB MODDED PICCO .28 IN A REVO
  215. Ports
  216. engine install on a adam drake 2
  217. Diesel RC Car engine
  218. NIB Axial 28RR
  219. Engine compression
  220. cutting on a piston
  221. which pipe for which truck
  222. nova,os,ninja,rb?
  223. MACH 427 ?? PLEASE HELP ASAP
  224. Axial .32 Spec 1S
  225. Questions about TTR .50 engine on new MGT
  226. CARB HELP
  227. Sportwerks .26 v2 good/bad??
  228. removing dtx .18 piston sleeve
  229. picco 27 stock needle settings
  230. What pipe works the best for a O.S V-spec??
  231. SH 28 PRO V SH21 PRO HELP NEEDED
  232. ST 28 starting issue
  233. O.S. Max .21 RX-B 13810
  234. sirio .27 for t maxx
  235. go 25 6 port, any good?
  236. Tuning Help
  237. Will a leaky gasket on a .28 axial cause a bad tune?
  238. Axil .28 on a bump start
  239. Werks racing .21B3 or Dynamite Platinum .21SG or other
  240. RUN TIME ON A HPI FIRESTORM
  241. ULTIMATE 1/8TH SCALE BUGGY ENGINE?
  242. LRP spec 3 truggy edition
  243. Associated .28 Pro Engine
  244. ULTIMATE 1/8TH SCALE BUGGY ENGINE?
  245. Engine Ofna Force .32... Not ignite
  246. XTM Backplate with HPI Rotostart on a Mach 427???
  247. please help
  248. Nitro Engine Hotrodding
  249. pull start on a 3.3
  250. Factory settings for Nova CX12
