- * Supercharging // High nitro mix// Nitrous System
- Plug selection
- Storing an engine?
- OS 18 TM Rod
- Removing Clutch Assembly
- AXIAL TUNING PROBLEM!
- just a question
- breaking in axial .32
- trinity adam drake .28 platnuim
- Ofna Force .28 pipe and header
- cheap engine
- whays the fastest, best engine for an rc10gt?
- .28 axial,How should the clutch bell be screwed on?
- os .12tg
- ofna colt.12??
- Head Bolt Stuck and BLOCKED!! Help!!
- picco p3 .28 break-in
- Need new clutch for .18 cvr-p on RS4 3
- 3.3 needle help
- wierd stability issues
- SH M28 P3 Will Not Start On Break-In!
- Pull Start help!
- Warm It Up
- axail .32
- Picco >28 P3
- new engine
- LRP Z.28 Pipe
- Dyno ratings from Xtreme R/c
- Fix For RB Supercharger
- Mach 427
- LRP .28
- Ofna force .26 carb needles/pullstart
- Is there a definitive run in and tuning guide out there?
- great service for all nitro motors
- Lrp .28 leaking
- Lrp .28 leaking
- is this good
- Axial 28RR
- Novarossi P5X Problems!
- E-BAY bargain engine ??
- RB WS7III - conrod
- Different Types of Glow Plugs
- STS D30M and shims
- Best filter for 1/8 buggy?
- os.18 cv-r or trx 3.3 for revo
- Force 28 and HPI Nitro Star K4.6
- TTR Pro .28
- what do i need?
- OS V-Spec .21 fuel confusion.
- Slipper clutch slippign bad with picc .25 max
- Cooling Idea
- Byron Fuels - 3000
- Fuel spitting out of glow plug hole!
- o.s. .12tg
- 2.5 to 3.3
- Which Engine to get???
- Carb problems
- Dirt problem
- crank shaft replacement for the STS 28
- Zero Nitro plane fuel in car engine
- Just bought an OS VZ-B .21 V-Spec. few questions
- how to take take a crankshaft out?
- short vs long glow plug
- Lrp Z.28 spec3 vs STS .28
- rush evo help
- MR .12 Ninja racing engine...
- Slipping Flywheel Problem
- Outerwears new nitro prefilter lineup?
- OS .15 cv-r Tuning Problem
- WHO'S THE BEST ENGINE MODDERS?
- Picco .28 lsn 10.5 ???
- STS .30 specs
- Jammin JP3 pipe runs REALLY HOT!!??
- Making a Roto-Start direct drive
- all about superchargers, warning, long read
- xtm 24.7 concern
- My picco .26 hydralics
- AXE Rossi Mamba question
- Smart Maxx Engine Swap
- rb tm523, what do you think?
- pcr 2027
- 2 questions
- RB Innovations Supercharger
- kyosho carb on a smartech?
- .46 and over what the best bang for the buck?
- Coverplate
- picco p3 .28 anyone run this motor
- Bearing problem
- Porting, and biggest engine size
- Ofna Picco Plug Question
- Looking for advice on engine mounts
- FR .27 specs??
- Please help the nitro newb. XTM 24.7
- Help with Jammin X1 CR
- Dyno Drag Races
- Stock V-Spec Dyno Graphs
- Motor Saver Filter to the Rescue!!!!
- OS .18 CVR VS TRAXXAS 3.3
- Your opinion on my next big block engine
- Ninja MR21 B01T? When, where?
- whats the best engine running temp.
- rossi head bolt screw stripped out of block...
- HELP Remove sturborn carbon coating on engine
- After run oil for air filter?
- ARGHHH...HPI 3.0 Still Wants to Run Rich!
- Help me choose an engine !
- need help with my new jammin moter
- Need a little help with bearings
- big block hype or not
- is this whats wrong?
- Novarossi P5 starting problem
- RB concept S3+jammin X1 flywheel????
- xtm 28 motors, dosent make sence
- 1/5 scaled
- sirio .18 piston & sleeve
- STS D30M
- help with this nova after run!!! I think
- Hpi Nitro Star 18SS
- First timer to nitro, best break-in method?
- STS .30
- .21 Vspec break in.. No, first time starting...?
- IS THERE ANY HEAD BOLT TORQUE SPECS?
- What gives??
- engine pinching??????
- vspec and werks b3 bottom end.......
- fixing a tuned pipe
- MT12 help!
- Sealing an engine
- looking for an engine for a 1\8 buggy
- help me please
- Test stand questions
- LRP .28 spec 3
- OS .21tm?..
- XTM 457 Pro Roto-Start question ..
- Nitro Star 15FE
- can i use?
- Why???
- Small-block glo plugs in a big-block?
- Will a 3.3 cooling head fit on a 2.5
- old nova .21
- OPS 21 Con-Rod Direction
- AXIAL .28 SPEC 1s BREAK IN runs very hot !
- Problems starting a 2.5R
- Dynamite TNT .12R CRANKCASE NEEDED
- b3 clutch bell issues
- rear bearing air leak??
- SETTING ENGINE TO RUN.
- Best way to start a motor that's been sitting a while?
- Is the traxxas 3.3 a good motor?
- OS Vspec pipe selections...
- 2.R to 3.3
- more power for savage x
- HELP PICCO .28 VS. LRP .28
- engine runnig backwards?
- Help! Stripped carbuerator HSN inlet
- Hellfire SS engine
- Help with an O.S. CV-RX .15
- Engine running very hot
- 1/16th scale Nitro Engines
- Sirio .18?
- EB MODIFIED 18 TZ FASTER
- RPM Pipe V.S. Torque pipe
- Will a TRX 3.3 fit in a HPI rs4?
- power
- 8ight-T RB tm928 question
- Problems starting warm engine
- Do I need a larger tank for club racing?
- Fuel econonmy difference between .21, .28, .30
- Am I missing something?
- Vantage Racing carbon fiber tuned pipes?
- SH .28
- Cleaning Air Filter
- big problem
- Calling all Racers, Bashers and Engine Modifiers...
- Tyres on my buggy
- Burning Plugs
- Mach 427
- Traxxas 2.5R
- How important is HP in .21/.28 engines? I'm shopping...
- Big tuning problem
- Werks B7 .28 performance report
- which clutch&header will Fit an os.18tz-tx?
- engine upgrade
- My First RC Experience..NEED HELP!
- Step by Step Procedure on How to Dismantle an Engine
- Modded STS 30 collides with MBX5T
- which engine for 3 different vehicles
- Good mid range competitive motor (.21) help
- Sportwerks .21 and Truggy racing
- Mugen MTX-4 VS Xray NT1
- OS .18tm HSN moving while driving.
- Question to a clutch bell...
- How do i choose the proper tuned pipe?
- o.s. 30 or sure fire 32
- nitro rs4 rtr3 evo needle set
- Sirio Monster .27 PRO HELP!?!?!?
- engine break in
- sts .28
- Another 'fastest engine' thread...but I know what I'm looking for...
- dynamite compression guage
- rc sloutions roll cage
- irattic idle problems!!!
- ported OS 18 CVRX
- for a one 8th scale
- I got an air leak
- Axial .28/pipes/plugs??
- Engine or Exhaust problem?
- Help with this Crono engine
- Ok another dumb Question
- which heat range plug
- Not getting gas?
- low tank leaning tips
- OS TZ .18 in 1/10 GS Vision Pro
- What are the symptoms?
- Important Info On The Ninja 28 Motor..........
- Oil %
- B-Mod Pro Team Cooling Heads?
- axial.32 info
- Rebuild Engines
- Questions about the O.S..21 VG
- Looking for an engine, trying something new.
- dynamite platinum 28 head shims
- O.S. 18TM e-clip question
- ST12R STS .12 engine
- Exhuast help
- What pipe with this motor?
- Werks carb screw locations
- What motor is this?
- Werks .28 clutch
- STS .30
- air filter
- Team Infinity motors
- fastest nitro engiene
- novarrosi/ top k12 motor
- Clutch
- Engine Moding
- PLEASE I NEED HELP BAD 3.3!!!!!
- After Run Oil
- Help, Jammed engine!!!!!!
- OS 30VG shim question
- STS engines
- Your favorite way to tune HSN?
- Looking for a used header to fit.210r.28 ?
- hyper .21 8 port?
- No more novarossi
- Big block
- Screw on SG Type Crank
- Engine tuning question - sputters at high but plenty of smoke
- Cleaning engine questions
- alternative fuels
