PDA
View Full Version : Car Nitro & Gas Engines
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. Need parts for your stock engine? Found the place!
  2. Any way to quiet the exhaust on a nitro engine?
  3. how check compression
  4. tuning help!
  5. Quick qustion
  6. What do I use to clean my nitro motor?
  7. Clockwork Modified Werk's B5 Dyno
  8. striped head/backplate bolts on a vzb
  9. Carb Problems/Air leaks
  10. Best rustler 2.5 exhaust
  11. TRX 3.3 clutchbell
  12. My TRX 3.3 bearings
  13. Is this fine with my RB WS7
  14. hyper st rtr macstar crankshaft???
  15. Bearing Leak
  16. How to tell if your engine is broken in?
  17. newbie here...planning to buy hpi nitro rs4
  18. just a straight swap for head button?
  19. OS .18 Shuts Down
  20. Best tune for 100 degree weather?
  21. trouble with engine
  22. Samba 4WD vs. JetPro tuning pipe
  23. LRP 28 carb hold-down bolt
  24. NOS systems
  25. bearing removal
  26. Mac Star 28 p/s
  27. How to find timing on an engine
  28. carb leaking??
  29. lrp .30 low speed needle
  30. kyosho .21 has me stumped
  31. Whats the best pipe for RB WS7 III?
  32. NITRO ENGINE RUNS IN REVERSE ROTATION
  33. proper nitro engine supercharger?
  34. machstar 28
  35. What does this mean?
  36. which carb
  37. firestorm broke first start
  38. Sportwerks Mayhem Electric Start problem
  39. Nitro engine won't start
  40. hpi S25
  41. LRP 28 vs 30
  42. What glowplugs should i use in RB WS7 III?
  43. Is my Sirio Engine Turbo or not.It eats my OS.8 Glowplugs
  44. crankshaft worn ?
  45. Rayaracing..Still operating??
  46. Basics engine tuning?
  47. LRP 28 spec 3
  48. HPI MT2 g3.0 Tuning Trouble
  49. Opinions on truggy engine...?
  50. GT2 Engines?
  51. Witch electric starter for my Picco max .26 on Revo?
  52. Is Changing Fuel Brands The Problem.
  53. RB B9 and B10
  54. Kyosho GXR18
  55. Clockwork Website?
  56. Nitro Engine Temps
  57. any info on these motors
  58. OS .28xz rotostart conversion
  59. Losi Mach 427
  60. What happens when your g-clip decides to eat your engine
  61. LOSI 454 with LRP CARB vs LRP 30X truggy motor
  62. old nitro
  63. Super hot engine temps
  64. Reviving the mighty Sirio .23 (need help)
  65. Bearing for OS .28
  66. Nitro engine won't stay on?
  67. Axial .32 Question...advice needed
  68. ?breakin questions?
  69. Electric or Nitro? E or T Maxx?
  70. Torn throttle plunger thing...relevant?
  71. nitro breakin
  72. Paris Racing .21?
  73. Dynamite .26 motor
  74. dynamite .26 Idle setting ???
  75. Nitro engine won't turn over?
  76. cutaway model
  77. Picco .26 Max engine cuts of when using more than 1/3 throttle
  78. HOBAO 21 3P Turbo Engine
  79. Tuning with a restrictor
  80. Cheap Engine Bearing Removal Tool
  81. Substuting Methanol for Denatured Alcohol
  82. engine choice
  83. Dynamite .26 factory setting !
  84. wondering what you guys think
  85. Extreme Rc Mods Picco Family Video
  86. UNRULEY 3.3....HELLLP!!!
  87. engine stand
  88. Please Help! engine question
  89. Evaluating Connecting Rod Play
  90. Toronero .21 vs JP B5-n .21 !!
  91. force .28 question?
  92. please help!!!
  93. Dynamite Mach 2 .28 Rebuild
  94. Team orion wasp .26 help
  95. Need Help! clutch and flywheel???
  96. Traxxas Nitro Stampede 3.3
  97. finding starter kit for my PRO-21R Thunder tiger
  98. Nova 21-4 vs RB C6
  99. Bought my first Nitro Truck today.
  100. Zenoah G290RC, which seal's?
  101. Dynamite Buggy .21 Mach 2
  102. where can i find a sh .28 6 port
  103. how to 'revive' engine thats been put down for a while
  104. ported, polished pro .15 tuned pipe
  105. O.S. .25xz ???
  106. Finally.....Bad fuel
  107. Engine modifier Eric Selesky passes away
  108. .18 nitro engine stays slightly out of tune, help!
  109. LRP .28 idle screw
  110. my modded OS.28XZ CRANK....work in progress
  111. Axial .32 Help
  112. kangaroo motor
  113. Fastest .28 or .32
  114. can he be serious!!!
  115. Searching manual or factory settings for Picco .26 Maxx 21223
  116. wasp .18? good?
  117. Help on a vintage O.S. Max 10 strip end rebuilt
  118. NINJA .28 vs. OS .28XZ head to head
  119. old old old old old old KYOSHO GX12 ENGINE - GLOW PLUG?
  120. Losi 454 turbo head conversion question.
  121. Best carb to replace Losi 454 RTR carb?
  122. Tuned pipe
  123. Need Engine Help
  124. New Buggy Engine?
  125. SHOW OFF YOUR ENGINE COLLECTION
  126. Clockwork Modified OFNA JL 21
  127. savage xl and rotostart issue
  128. 28xz tuning question
  129. HPI Savage XL ( Engine break in)
  130. NEED HELP WITH OLD RC MEGATECH
  131. How do I fix a gummed up motor?
  132. new engine
  133. Nitro engine question
  134. New Axial .32
  135. Hpi s-25 front bearing?
  136. redcat earthquake 3.5
  137. Traxxas engines
  138. Engine & Transmission Tuning Questions
  139. I'm confused now.
  140. Just Wanna Clear This Up
  141. my engine blew up which replacement should i use?
  142. glow plug ignitor question
  143. m2c clutch 3 shoe or 4 shoe?
  144. rc carb
  145. Factory carb settings sirio 21
  146. trx pro 15 tuning help
  147. lrp.30 spec 2 question on pullstart elimination
  148. RB TM323 Setting
  149. TRX 15 Pro Crankshaft Bearings
  150. Solved please delete Hpi rs4 15FE engine help
  151. where to buy 12r ss sleeve and piston?
  152. Engine Bearing Play
  153. BB vs SB how to read?
  154. Jammin JPX .21 Questions
  155. Dynamite Platinum .18RE
  156. Engine rebuild/cleaning
  157. Can these engines be saved/repaired??
  158. Clutch bell not turning freely
  159. JLR picco .28 Turbo team in a savage
  160. Engine Recommendations
  161. picco red dot pipe
  162. where can I get hpi engine pistons and sleeves?
  163. how do the hpi 12r ss and hpi g30 compare?
  164. Axial .32rr sleeve/piston in a spec 1s
  165. O.S. 18TM-21TM manifolds
  166. twin engine conversion troubles and questions
  167. Breaking in the engine in winter
  168. The Future of Offroad Engines?
  169. OS Max RG Pull start
  170. Possible motor issue
  171. Can I use ethenol?
  172. probelm starting need help pleaseeee
  173. engine dies when glo is removed
  174. is it worth it?
  175. Carb Insert ?
  176. Super tartan ST 7G
  177. First test with 0% home made fuel
  178. 18tz problem
  179. High speed bog?
  180. Engine sizes??
  181. Clutch Springs
  182. Motor wont start after idling for 2 tanks.
  183. Head shim question
  184. k5.9 and owb issues
  185. compression calculator
  186. Dynamite Platinum Exhaust!!!!!????
  187. NOOB HERE! Got questions!!
  188. short and long plugs
  189. could a plug do this?
  190. best glow plug for a Mach 427 on 20%
  191. Associated Zr. 30 Motor ? Are they good or what ?
  192. lrp z28 spec3 truggy need help
  193. Starting HPI Nitro 3.0 Engine
  194. LRP Spec 3 Bump Start
  195. TNX won't run on WOT
  196. NITRO BREAK IN???
  197. Opened up ofna .26, found sand grain sized dings
  198. Dynamite SPD .12 any good?
  199. 2.5 problems
  200. HPI K5.9 Vs. Pro.28 ?
  201. Tune changes at 2/3 tank
  202. Refridgerating Nitro?
  203. Dusty and Muddy Cyclinder Head
  204. traxxas rustler mxt15
  205. first.21 purchase need help
  206. Spitting....
  207. lrp .30
  208. rc car tuning
  209. losi 350 of Mach 2 .21?
  210. Team Infinity .15
  211. Modifying stock exhaust?
  212. sh . 21c proper settings
  213. Help with ported engine
  214. DIFFERENT EXHAUST SYSTEMS!!!!!!!!!!
  215. Pull starter and one way bearing
  216. TRX 2.5 Glow Plug
  217. WHAT GLOW PLUG???
  218. Mabry Modified R/C Engine Mod Service
  219. Can Anybody identify this Piston and Liner:pics inside?!!
  220. CLUTCH???????
  221. best glow plug for slayer3.3
  222. Looking to Beef Up a Nitro 4-tec 2.5
  223. engine test stand
  224. T-Maxx #4908 Pics please comment
  225. picco.21 p3 basic settings
  226. WHAT IS A GOOD ENGINE?????????
  227. HYPER 21 PRO 8-PORT WITH BOOST. ANY OPINIONS!?!?!?!?!
  228. Pull starter wont engage??
  229. 2.5 to 3.3
  230. TAMIYA FR-15S PROBLEM WITH START HELP!!!
  231. Axial Multi-Position Easy Start Backplate AX0507
  232. T-Maxx 4908 Build *NEW PICS*
  233. Glow plugs for H2112 Hyper 21 engine
  234. v12 model engine
  235. Another Motor problem ?
  236. Changed the head button now want start ?
  237. Best mod shop for Picco
  238. Novarossi 21+4 Turbo Plug Help ???
  239. OS .25 truggy engie???
  240. Exhaust Manifold Gasket??
  241. Alpha Plus Engines ***Top Performance for under $210***
  242. Symptoms of a used up nitro engine??
  243. can u use a ???
  244. Open Header
  245. pictures of my highly modified Hyper .21!!
  246. Novarossi 5XLT vs Plus 4 vs Werks B5
  247. NOVAROSSI ENGINES
  248. Conrod for Ninja MR21 B01A
  249. mixing screw setting for stock .15RC10GT engine??
  250. Picco .28 plug suggestions
